Changing the oil in the front Diff. QD2 - JeepForum.com
post #1 of 5 Old 06-23-2009, 12:47 PM Thread Starter
JMorash
2005 WK
Found out changing the oil in the front Diff was a bit tricky on my 05 wk hemi with quadra drive 2.
So listen to this.
I routed a tube into the fill hole of the diff after draining the old fluid.
Secondly i taped the tube to the nozzle of the gear oil bottle and tipped it upside down, letting it rest on my radiator. From there on the oil gracefully filled itself into the differential through the tube.
Secondly for those of you who want to do this on your own and dont own large allen keys. Go out and buy a 14mm bolt, and some nuts. This worked perfect for removing both the drain plug and filler plug. the bolt fits perfectly into the drain and fill plugs perfectly, all you have to do is wrench it off.
Heres some pictures to show yall what i mean.
Hope this helps. BTW the dealer suggested i use two bottle of friction modifier for each differential. Using One is ok as well
2005 WK 5.7L Hemi
HEMI Club Member #28
3.5 Rock crawler lift.265/65R17 Toyo AT SuperChips Flashpaq MDS delete
JMorash is offline
post #2 of 5 Old 06-23-2009, 01:24 PM
scottydog
2017 WK
Most of us buy a gear oil pump, $10, fits a gallon bottle of 75w-140. Local auto parts places should have the 14mm hex.
Be careful about too much friction modifier. Your clutch packs can start to slip. A lot of guys keep adding modifier little by little till it stops acting up in a sharp turn.
scottydog is offline
post #3 of 5 Old 06-23-2009, 01:28 PM Thread Starter
JMorash
2005 WK
I went to two napa stores. They didnt have the 14mm hex. As for the modifier, the dealer told me that two bottle is what they do. and theyre all about service. I hope. On the bottle is say anywhere from 2-5 percent modifier to be used in the diff alongside the 75w-140.
I hope the two bottles i dumped in there dont mess things up.
2005 WK 5.7L Hemi
JMorash is offline
post #4 of 5 Old 06-23-2009, 02:55 PM
Texas WJ
Texas WJ's Avatar
2005 WK
Yeah, that front diff was a pain. I was planning on going your route next time with the longer tube. I still haven't found a clean way to add transfer case fluid though.
My local parts stores didn't have a 14mm hex socket available, neither did Sears unless I bought a $40 set that I didn't need so I wound up purchasing the piece at a local heavy duty - commercial grade, tool supply company. Now, I just need to not lose it before my next change.
Never listen to this dealer ever again.
Texas WJ is offline
post #5 of 5 Old 06-23-2009, 03:29 PM
scottydog
2017 WK
14mm hex $3.30 www.amazon.com/gp/product/B000UVP0DG/ref=pd_lpo_k2_dp_sr_3/175-1436287-7512248?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=lpo-top-stripe-1&pf_rd_r=08JFRQTZB93MGF5GBEGJ&pf_rd_t=201&pf_rd_p =304485901&pf_rd_i=B000CDZQ7W
Most parts stores should carry the gear oil pump $10. You can even use it to pump oil out of the rear dif should you not want to pull the pan off.
Yea regarding friction modifier the "one is good, two is better" idea doesn't apply. I personally like the pre-mixed stuff from redline.
Changing diff fuild..few Qs. froggo27 ZJ Grand Cherokee Forum 7 05-03-2008 10:59 PM
Changing Oil in Rear Diff QM2Rick ZJ Grand Cherokee Forum 38 12-28-2007 05:03 PM
Changing Center Diff Fluid Endless Mike ZJ Grand Cherokee Forum 6 02-16-2005 06:33 PM
Help with Changing Diff. Fluids 98ZJBlack ZJ Grand Cherokee Forum 16 10-10-2004 10:28 AM
Changing diff fluid 97grand ZJ Grand Cherokee Forum 8 07-02-2004 11:55 AM
