To change the tranny fluid or not? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > To change the tranny fluid or not?
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSteering and more from Ruffstuff!
Unread 09-23-2014, 01:06 AM   #1
Clach
As some will know from my many posts on the N23 shocker, I have an O6 Overland CRD with 55k mi on the clock. The very occasional light thud when accelerating but nothing I am worried about in the box. Should I change the tranny fluid for preventative maintenance, or just leave it in there. How many here have changed it?
Clach is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 04:09 AM   #2
caulk04
2008 WK
I like to change tranny fluid between 50 and 60k, it's a good interval IMO.
Tint, Superchips, SRT intake tube, Gibson catback, catch can. One hardcore DD/kid hauler...yeah.
caulk04 is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 05:58 AM   #3
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Are you asking if you should change it now or wait 5K miles or just wait period?
I wouldn't go past 60K miles if I were going to service it. It's not going to explode or anything it's just a good time to do it.
~Mike~
My Build Thread WK
My Other Build Thread XJ
'01 XJ with some stuff
Sept 2013 Cherokee of the Month
'07 WK with some other stuff
~RED WK CLUB #7~
'11 KK with mostly stock stuff
'06WK our first Jeep with stock stuff - totalled and gone
JeepN4KC is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 06:50 AM   #4
Clach
I was going to change it now as I fear waiting much longer may do more harm than good. It has not been changed before.
Unread 09-23-2014, 07:24 AM   #5
caddydaddy
2007 WK
How does the fluid look? Any burnt smell to it? If it's dark and smells burnt, then you should be really concerned!
2007 CRD Grand Cherokee Limited 4x4
GDE ECO Tune, Turbo Resonator Delete, EHM
166,000+ miles!
caddydaddy is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 08:24 AM   #6
Clach
I have no idea how it looks tbh. How can i check on a sealed unit? I am aware there is a dipstick point somewhere around thr engine. As I said, i have had no probs with the tranny (touchwood)
Unread 09-23-2014, 08:27 AM   #7
caddydaddy
2007 WK
It's not sealed, it just doesn't have a dipstick. I bought one online to check the level.
Read this thread: http://www.jeepforum.com/forum/f67/p...check-1135591/
166,000+ miles!
Unread 09-23-2014, 08:35 AM   #8
RCS1300
2005 WK
I change mine every 30,000 miles which means a complete flush of the fluid not only the 8 quarts in the pan.
RCS1300 is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 10:19 AM   #9
Clach
Brilliant stuff. I suppose the question is now threefold; a) Leave the fluid in there; b) do it myself -unlikely tbh- or c) trust the only tranny shop for miles to take the time to follow the temp regulated steps to get the fluid level right. mmm!
Unread 09-23-2014, 10:22 AM   #10
Hendrix9
2007 WK
Just to clarify, he's got the W5a580 transmission, so it's not 8qts in the pan. Service is 4-6qts and an "overhaul" is 9.5-10qts.
If this helps ease your mind, I changed my fluid and filter at 100k and the fluid looked fine. I don't think it had been done before as I bought it at 60k with no service records.
2007 CRD QDII
4XGuard Matrix, GDE Eco Tune
DPF delete, RC 2.5 lift on 265/70/17s
Hendrix9 is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 10:54 AM   #11
caddydaddy
2007 WK
If you are to do it yourself, I will say that this was the easiest tranmission to change fluid that I've ever worked on! Using the chart for fluid level is not too hard either.
166,000+ miles!
Unread 09-23-2014, 11:18 AM   #12
LouC
2007 WK
Get an IR temp gun from Radio Shack to meadure your trans temps...
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 11:59 AM   #13
Clach
Cheers. I am UK based but I am sure there is similar, if not the same, over here.
