Change the stereo in Grand Cherokee 2007 - JeepForum.com
post #1 of 3 Old 08-03-2009, 10:24 AM Thread Starter
ekam
Hey Guys,
I have a 07 GC Laredo and I want change my CD/Stereo, i currently have the MP3 cd changer, but it doesn't have the iPod/Aux input and I would like to downgrade to the non cd changer player for jeep with the ipod/aux input. Is this possible? if, yes is it easy?
ekam is offline
post #2 of 3 Old 08-03-2009, 04:50 PM
4norris
2005 WK
I think what you are describing is the RAQ radio. The simplest would be to buy an adapter. You'll need one of these depending on whether or not you have the satellite radio option: http://www.logjamelectronics.com/piechryaux1.html
http://www.logjamelectronics.com/piechry04aux.html
This particular adapter is 80 bucks; it was the first to come up on google. There are probably others, maybe cheaper. Just search for RAQ input adapter, etc.
You'll also need a 2 dollar cord to go from rca to 1/8" stereo - http://www.amazon.com/3-5mm-Mini-Plu.../dp/B000FEHO0U.
As far as downgrading the radio, you probably could do that without a problem. However, the adapter would likely be cheaper; and you'd keep the mp3 cd changer capabilities.
Finally, the cheapest and most difficult option: I have heard of people tapping into the wires on RAQ radios that are compatible with the handsfree or satellite radio systems. These evidently have audio inputs in the harness already. You'd have to get the wiring diagram to ascertain the exact locations.
4norris is offline
post #3 of 3 Old 08-03-2009, 11:06 PM
dustb0wl
2005 WK
Originally Posted by ekam View Post
Hey Guys,
Changing out the radio is very easy. the bezel is attached via spring clips. Using a trim stick or other flat, sturdy object, get underneath the edge and pull outward slowly but firmly. It will pop right off. If I were you though, I wouldn't switch out the radio. I would get an ipod/aux adaptor from crutchfield available here:
http://www.crutchfield.com/p_541IPAC...er.html?tp=120
It's easy to install, retains your 6 CD changer radio, and adds a direct ipod interface. Chrysler used to make one just like it, but discontinued it for some reason.
Just my 2 cents.
2005 3.7L V6
K&N CAI
2.25" RR Lift Kit
255/70/R17 Firestone Destination A/T's
Bosch Iridium Fusion Spark Plugs
Akebono ProACT Brake Pads
dustb0wl is offline
Change the stereo in Grand Cherokee 2007 ekam ZJ Grand Cherokee Forum 2 08-03-2009 10:24 AM
CEL Grand Cherokee CRD 2007 tcmglx WK Grand Cherokee & XK Commander Forum 1 08-30-2008 06:31 AM
Grand Cherokee stereo Batch ZJ Grand Cherokee Forum 3 07-11-2008 12:36 PM
2007 Grand Cherokee with CRD erickpl ZJ Grand Cherokee Forum 1 06-02-2006 11:15 AM
99 Grand Cherokee stereo.... jpgrl do n mud ZJ Grand Cherokee Forum 2 07-09-2004 10:13 PM
