Center brake light is out. How do you replace the bulb? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Center brake light is out. How do you replace the bulb?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deliJeep XJ Cherokee Ulitmate Sliders now available!
Unread 06-27-2008, 08:09 AM   #1
05WKinPA
2005 WK
My brake light over the back window went out last week, so I tried changing it. I got the cover off, but the manual says "twist the bulb socket to remove the bulb"....when I look at the back of the brake cover, I don't see anything that looks like it twists off. Has anyone changed their center brake lamp yet? Does the entire black backing come off? Just trying to figure out how to get at the bulb.
Any help would be appreciated.
Thanks.
-Mike
05WKinPA is offline   Reply With Quote
Unread 06-27-2008, 08:11 AM   #2
I thought these were all LED assemblies? -Someone please correct me if necessary but I don't think the unit is user-serviceable. You may have to replace the entire LED unit.
---- is offline   Reply With Quote
Unread 06-27-2008, 08:15 AM   #3
05WKinPA
2005 WK
That's what it looked like to me as well...a bunch of led lights, but I went to Pep Boys and they had a replacement bulb for the 05 WK center brake light. The owners manual also explains how to change the 'bulb'.
This is my second brake light out in as many months....I should probably just replace the left side one now since I'm sure that will be out by next month too.
Unread 06-27-2008, 08:25 AM   #4
I think the Laredo models have a single filament bulb. Higher trim levels should have the LED. -Again, I'm not 100%, but I think that's the case.
Unread 06-27-2008, 12:06 PM   #5
stgry1
2006 WK
nope..laredo here. LEDs
db
Brandon, FL
USMC
06 Silver Laredo
mopar bug shield, rear mopar air deflector, K&N drop in w/ modified OEM air intake, 08 Gladiator wheels w/ 255/60/18s.
stgry1 is offline   Reply With Quote
Unread 06-27-2008, 01:00 PM   #6
vtbert3
2006 WK
Yep, LED's and when I replaced mine it ran about $45 from the stealer, wasn't able to find any aftermarket ones at the time. My issue was a loose connection inside and since you cannot take it apart without destroying it, I could not solder the connection. I guess you could always check salvage yards for much cheaper used one.
vtbert3 is offline   Reply With Quote
