CEL on 2008 WK CRD, showing no codes - JeepForum.com
post #1 of 5 Old 09-28-2010, 02:34 PM Thread Starter
thebigtman
Yesterday the CEL illuminated on our 08 WK CRD 4x4. I get no DTCs when I put it in diagnostic mode. Any ideas?
I checked the oil and it looked a little low so I brought it back to spec. We have a faulty nav system that's waiting to be replaced but I doubt that has anything to do with it. The fuel cap is on properly. It's right at the oil change interval but I've not seen a CEL illuminate b/c of that before. Bad fuel maybe?
Does anyone have some ideas? I'm going to use my buddy's handheld scanner to see if that will pull any codes but so far I've got zilch.
Thanks,
Tim
2008 Hemified JK Rubicon Unlimited
2005 KJ CRD (RIP 2/5/10) replaced with...
2008 Grand Cherokee CRD
thebigtman is offline
post #2 of 5 Old 09-28-2010, 03:12 PM
suzieque
2008 WK
I had the same problem, eventually the problem occurred again and kicked a code. In your case, I would not worry until it kicked a code out. Keep your scanner with you in case it happens while driving.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #3 of 5 Old 09-29-2010, 11:39 AM Thread Starter
thebigtman
I used a scanner and I'm showing P0672 and P0673. This translates to glow plugs 3 and 4. I'll do some digging and see if anyone else had these codes.
post #4 of 5 Old 09-29-2010, 01:24 PM
suzieque
2008 WK
seems glow plug failures are getting common lately. I'm planning to research a good price myself and then ordering 6 and when 1 fails, I will just do them all.
suzieque is offline
post #5 of 5 Old 09-29-2010, 06:22 PM
Dr. Internet
Had the same problem on my 2007, with 36k miles. No code, just the CEL. Went to the dealer and he couldn't find anything wrong, turned off the light. Two days later it was back on, went back to the dealer, #2 glow plug fixed. No problems and no lights since.
Steve
2012 Black GC Overland Summit 4x4 2006 Red LJ Rubi
USN Club Hull TJ-13 TX Jeep Club #29
Dr. Internet is offline
cel , crd
4.7 showing codes 0171 and 0174 OzzyWJ ZJ Grand Cherokee Forum 15 12-18-2009 07:32 AM
2K WJ not running right with fuel inj codes & No ASD relay output voltage codes. HELP hillside250 ZJ Grand Cherokee Forum 0 04-06-2009 02:17 AM
Jeep showing off jnnym21 ZJ Grand Cherokee Forum 3 10-11-2008 08:28 PM
Grand Slam West 2008 Scheduled - May 30-June 1, 2008 FPKites ZJ Grand Cherokee Forum 54 05-15-2008 10:40 AM
Airbag light driving me nuts, no codes showing! CunningLinguist ZJ Grand Cherokee Forum 6 01-16-2007 12:48 PM
