Cd player making weird noise - JeepForum.com
post #1 of 2 Old 01-17-2013, 09:52 AM Thread Starter
biippy
2005 WK
Hey guys i recently just bought a 2005 jeep grand Cherokee limited with the 6 disc cd changer. Every time I unlock or lock the doors the cd player sounds like a gear is slipping in the changer, i do not believe there is a disc in there. when i press the eject button nothing will happen, it will also no load a cd.
any ideas how i can fix this?
thanks!!
biippy is offline
post #2 of 2 Old 02-15-2014, 01:10 PM
Ghost241887
2005 WK
Same thing happened with my 05 WK
This same thing happened to my 05 WK. However, I had been using the CD player for awhile and then all of a sudden the CD's got stuck and it began making the noise your are describing when I unlocked/opened my doors. I would guess that while you may have not put any CD's in the player, the prior owner had and they got stuck and they just left them there.
As a temporary fix you can actually removed the CD changer unit from your radio and the other features (radio, sat radio) will still function correctly. It's a pretty simple process. If you want to use CD's, you'll probably have to get a new CD changer mechanism for your radio. Hope this helps!
Ghost241887 is offline
