Quantcast CB radio and Antenna for my WK - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > CB radio and Antenna for my WK
Old 06-03-2009, 01:24 AM   #1
bull_blaster
2005 WK
Hello guys.
I need some help picking up the right CB radio. Been looking online for a while and found several good ones. Any brand name you guys recommend ? I've never owned or thought I needed one untill today, after getting lost away from the group in the middle of no where really sucked ! But anyways, besides that, what would be a good place to mount the Antenna on the WK...assuming i dont wanna drill or put holes in my bummper ?
Thanks inadvance.
bull_blaster is offline   Reply With Quote
Old 06-03-2009, 01:39 AM   #2
ROMEO69
2007 XK Commander
I got my a cobra night-watch, alone with a 5k wilson antenna with a magnetic mount, that way I didn't have to drill the body of my XK.
ROMEO69 is offline   Reply With Quote
Old 06-03-2009, 08:09 AM   #3
justa4banger
2007 WK
Get a wilson mag mount ant ...if you don;t want holes. Otherwise put the antenna on the roof...if you don't care.
Don;t mount the antenna where the base of the antenna is below the roofline. this reduces the range drastically.
As for Radio's......Cobras, uniden and Galaxy are nice. the nicer ones aren't small. a Older Cobra 19 will work well, and you can even have it tweaked a bit to get more ooomph from your radio. If you don;t mind being illegal, you can also invest in a linear amp.
2007 GC LTD CRD 2x4.........For towing...
1985 Mustang SVO 2.7t......In progress
justa4banger is offline   Reply With Quote
Old 06-03-2009, 01:51 PM   #4
dieth
2008 WK
Another point about antenna mounting. The cross bars can screw up antenna performance so if you also have a Sat antenna already on the roof, you might have to remove the cross bars for best performance since you want to separate the antennas. They will interact if too close to each other and too close to the crossbars in the roofrack..
dieth is offline   Reply With Quote
Old 06-03-2009, 02:53 PM   #5
justa4banger
2007 WK
Remember also.... that if you mount the antenna at the rear of the roof, your strongest signal will be everything infront of the vehicle. At the center of the rof will give the best OMni direction signal, and to the front of the roof will make the signal strongest to the rear of the vehicle. This applies for both Recieving and transmittig.
If you run Dual whips... like semis. their "ears" (the antennas) listen best forward and aft..... the will HArdly pick up any signal from the side...... Dual antennas make a vehicle VERY directional.
Good grounds Help. and if you want advise on what to "turn up" inside the radio... tell them to adjust the modulation...... Screw the wattage.... Need more watts, get an Amp.
Old 06-03-2009, 10:05 PM   #6
nostaw22
I was looking at installing a 3' Firestik Firefly antenna on a hood channel mount so I could use the bolts holding on the fender - no drilling required.
Make sure you include a spring if you mount it (e.g. not a mag mount) so you don't mangle something if it snags.
JW
1998 XJ - built for offroading
2007 WK CRD - DashHawk, for towing the XJ
nostaw22 is offline   Reply With Quote
Old 06-05-2009, 11:51 PM   #7
dustb0wl
2005 WK
I installed mine on the root rail and then grounded the antenna to the roof. Works really well, although the jeep is really tall when I have the antenna up. lol
2005 3.7L V6
K&N CAI
2.25" RR Lift Kit
255/70/R17 Firestone Destination A/T's
Bosch Iridium Fusion Spark Plugs
Akebono ProACT Brake Pads
dustb0wl is offline   Reply With Quote
Glock Forum
