CB Eng - Pro-lite Build - Page 3 - JeepForum.com
 1Likes
post #31 of 192 Old 04-24-2014, 02:53 PM
ryann04
2008 WK
Originally Posted by paroxysym View Post
those UCAs look incredible man.. great work.
BTW whats the overall goal of this build again? either way the amount of custom parts and time put into making them is def making this a one of a kind.
He wants to corner the market in aftermarket support for the Jeep WK.
2008 - Jeep Grand Cherokee - 3.0L CRD - Quadra Drive II - GDE Hot-Tune - OME HD Lift Kit - OEM Full Steel Skids
Blue WK Club Member #42 // DIESEL FTW !!!! -Ryan
ryann04 is offline
post #32 of 192 Old 04-24-2014, 04:11 PM Thread Starter
tnadanzig
tnadanzig's Avatar
2007 WK
Thanks, I still have lots to learn. I have always wanted a go fast low slung 4 door vehicle to haul the family in. I am a huge fan of off road racing especially short track racing. So this is kind of my idea of a short track Pro-lite truck would be if it was a Jeep CRD and still be street legal. I would still like to drive it everyday and can be just as capable on the road as off road. So it still has to have modern conveniences and be comfortable to drive/ride in. This is only stage 1 it get better with each stage, but I have to start somewhere and not go to crazy all at once or it will sit in my garage forever. Still its a pretty big build.
Thanks, that would be nice, maybe someday.
CB Engineering
CB-engineer.com
2014 WK2 EcoDiesel - CBE Parts
2008 3.0L CRD WK LTD - GDE Tune 3.07 gears
2007 3.0L CRD WK LTD - Go Fast Parts
2005 KJ CRD - GDE Tune
tnadanzig is offline
post #33 of 192 Old 04-25-2014, 10:30 AM
IIMacGyverII
2007 WK
With those new downpipe jigs you've made, are you planing on remove the cat or just making a more efficiently flowing pipe and keep the cat?
2007 WK CRD Limited Fully Loaded. GDE Hot Tune, SWK Member 115
1996 ZJ Limited -RIP
N23 Recall Victim
IIMacGyverII is offline
post #34 of 192 Old 04-25-2014, 11:26 AM
enkeivette
Originally Posted by tnadanzig View Post
I am planning on moving the knuckle forward about 1". That is how I have it drawn at the moment. I would also like more room for the tire. Currently it's closer than I would like to the pinch weld, but baby steps.
Yes, that is the idea. I have always wanted some of these parts and figure others probably would too. I currently stock DPF delete and turbo resonator delete pipes. The others I am working on.
I see two bulges up front on the pipe, one is a DPF and the other is a catalytic converter I'm assuming? No way to get rid of both without throwing a DTC?
The resonator I'm guessing is the muffler in the back? I already got rid of that thing. It's wasted metal IMO.
How much?
enkeivette is offline
post #35 of 192 Old 04-25-2014, 11:43 AM
ryann04
2008 WK
How much?
I removed both my Cat and my DPF on my 3.0l crd. No codes thrown, BUT I do have the GDE tune with DPF removal tune.
ryann04 is offline
post #36 of 192 Old 04-25-2014, 11:48 AM Thread Starter
tnadanzig
tnadanzig's Avatar
2007 WK
Originally Posted by IIMacGyverII View Post
With those new downpipe jigs you've made, are you planning on remove the cat or just making a more efficiently flowing pipe and keep the cat?
Remove the cats, get rid of them, just loss of efficiency and added weight that I don't need.
How much?
Not sure what picture you are referring to, but the pics are of the downpipe and only the cats are shown. The downpipe is two pieces and each one has a cat, one small and one big. The DPF is after these. Cats will be removed. With the tuning you will not get a DTC.
The turbo resonator is on the front of the engine between the turbo and intercooler. Its a kidney bean looking piece that supposed to quite the turbo, but doesn't do much but collect oil and disrupt the air flow. You get reduced turbo spool up and improved efficiency/+ mpg. I will PM you info on cost. My performance thread has more info on what upgrades I have done.
http://www.jeepforum.com/forum/f67/j...-mods-1411857/
CB Engineering
CB-engineer.com
post #37 of 192 Old 04-25-2014, 12:11 PM
jonjon302
2006 WK
What a great thread! I'll be watching this one closely.
I wonder if those super cleanly built UCAs would clear the springs better on my modified Superlift. My RROs cause my knuckle and UCA to knick the coil spring.
I'd be very interested in parts when you start to sell them. Or if you need testing on my setup, I'm willing to help you out. 😁
Rock Krawler 3.5" lift, 1.25" Spidertrax spacers, 265/70/17 GY Duratrac's on Moab wheels, 36" firestik, Bwoody sway bar links,
30% tint on front windows, 6000K Xenondepot HID's
jonjon302 is offline
post #38 of 192 Old 04-25-2014, 01:03 PM
IIMacGyverII
2007 WK
Are you going to work with GDE for any new tweeks for the turbo/cat removal?
N23 Recall Victim
post #39 of 192 Old 05-01-2014, 02:53 PM Thread Starter
tnadanzig
tnadanzig's Avatar
2007 WK
I'd be very interested in parts when you start to sell them. Or if you need testing on my setup, I'm willing to help you out. ��
Thanks. Currently they are setup for roughly stock height suspension so they probably wouldn't help a ton with spring to knuckle clearance. But that's also why I am going with a new coilover so I can have more clearance as I am pushing the limits of the suspension travel. I can always make a pair to give you more clearance. With my jig it's pretty easy to make adjustments. I will post when they are ready to sell. I could probably use some Superlift testing as I won't be going that direction for my build. Trying to keep this one low and mean.
I have talked with Keith about this, but this Jeep has Custom Spooling tunes so I won't be buying new tunes at this time, but I am sure we will talk about what changes can be made. My stage 2 tune was written to take advantage of the bigger turbo/intercooler upgrades.
CB Engineering
CB-engineer.com
post #40 of 192 Old 05-01-2014, 03:07 PM Thread Starter
tnadanzig
tnadanzig's Avatar
2007 WK
Updates:
Sorry I haven't posted in a while.
So lets see where I left off. I have finished the downpipe jigs and pretty much finished the 1st new downpipe. All 3" 304 mandrel bent stainless steel tubing with SS v band clamp includes O2 sensor bung welded in. Plug and Play. Stock is a mixture of 2.5" and 2.75".
Cleaned up jig
New vs Old
Got my big brake kit installed from the test spindle and bleed the brakes. Pics of stock vs SRT8 rotor. Man this should help put me through the windshield at 100 MPH. Not a huge fan of decreasing brake performance with bigger tires and some of the things I want to do with this Jeep this was a necessary upgrade. Pumped up to try it out. HA.
CB Engineering
CB-engineer.com
post #41 of 192 Old 05-01-2014, 03:46 PM Thread Starter
tnadanzig
tnadanzig's Avatar
2007 WK
Track bar built and installed. Only weights 8 ounces more than stock and its made from 3/16" steel tube vs the crappy stock one barely 1/8 and not fully welded at the ends. Johnny joint and urethane bushing. Looks so much better and its adjustable.
Working on suspension. Well with the stock fender out of the way I could finally figure out how much this is going to hurt. The stock fender prevented about 3" of bump travel. At approximate ride height.
Full bump, clear if you don't turn.
When cycling it acutally hits in the front and the back, but mostly in the back. This might push me to get some extended control arms that push the tire forward 1" a bit sooner than I thought. I didn't think it was going to be this bad. Did the pinch weld mod for quite a long way and still it wasn't enough. Had to break out the BFH and really go to town. Not sure how I am going to run wheel well liners.
Cycled suspension pics. Yellow line on inner fender has to be cut to clear tire. Not using all of the shock travel.
Full bump
Full Extension
Got it with enough room to go lock to lock, but its close in the back. Glad I didn't go with 35's. Plus the wheel spacers don't help much, they kill my scrub radius. Can't wait to get some extended control arms. Bit more work, but its close to being done in the front. Removed front sway bar, it just gets in the way, will see how it handles in the corners without it. Going to keep the SRT8 rear one has it needs some control.
CB Engineering
CB-engineer.com
post #42 of 192 Old 05-01-2014, 05:11 PM
Rob_S
2006 WK
This build just gets better and better! I love that coilover up front with the control arms. Did you by chance measure the travel at the spindle? And how are you going to manage bump control if your shock still has travel to spare?
Also, what is the purpose of the rear bump stop spacer? Aren't you using the SRT rear springs which I assume sit lower than stock?
Robbie
Rob_S is offline
post #43 of 192 Old 05-01-2014, 05:30 PM
pancake
2005 WK
Are you going to lift at all? Or just stock height and just try to get as much travel possible?
05 Jeep WK Laredo 4.7L QTII | K&N CAI | Flowmaster 40 | ...lift and such in planning phase...|
pancake is offline
post #44 of 192 Old 05-01-2014, 08:24 PM Thread Starter
tnadanzig
tnadanzig's Avatar
2007 WK
Also, what is the purpose of the rear bump stop spacer? Aren't you using the SRT rear springs which I assume sit lower than stock? Robbie
Travel at the spindle is pretty much right at 11.5" I was hoping for 12 or so, might try to figure out how to get that last .5" to 1" of travel. I will put in a urethane bump stop to prevent it from going to far. I might tweak the mounts to help lower the coilover so I have the ability to get more droop than bump. I really can't get any more bump with the wheel in its current location. Need to move it forward and cut out more inner fender.
The rear bump stop is actually thinner than the stock one and gives ~ 0.5" of additional travel. You can get it with an Eibach lowering kit.
No lift really, maybe up to an 1" to keep a good ratio of bump to droop travel, but otherwise close to stock ride height as possible. Keep it low like a short coarse race truck. That's the inspiration on the build so this thing is supposed to handle well and lifting reduces that ability. The suspension geometry limits how much droop travel can be had and guys that lift up to 3" don't have much droop.
CB Engineering
CB-engineer.com
post #45 of 192 Old 05-01-2014, 09:28 PM
Rob_S
2006 WK
That rear bump stop is awesome! I'm gonna look for an ES rear bump to try and accomplish the same thing. Also an idea for the front might be to build a new lower mount like these ones...
http://m.ebay.com/itm/280984586471?nav=SEARCH
They may give you a little more droop for tire clearance from the body and allow the shock to use that last bit of travel. I know droop is limited but that may help if it isn't drastic.
Rob_S is offline
