Can you install Rusty's strut spacer by compressing the coil? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Can you install Rusty's strut spacer by compressing the coil?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineParacord grab handles, door limiting, etc at JeepHut.comRough Country Deals at JeepHut.com
Unread 05-02-2015, 01:05 PM   #1
Sneaky2Toes
2005 WK
Looking at possibly picking up Rusty's front strut spacer to offset a little sag from my OME lift.
I searched but didn't find my answer. With the solid axle, adding spacers was simple. Just jack up the wheel and put a coil compressor on it, then let it down and slide in the spacer. I don't really want to have to take the strut out and am not sure if this technique will work on the struts.
Can I just jack up one wheel (the one I want to add the spacer too) then put a strut compressor on the coil, then let the suspension droop? With the strut remained compressed and allow enough room to slide in the spacer?
Have others seen about 1/2 sag in their OME HD lifts? I don't have any extra weight in the front (stock bumper, no Matrix). I know sag is to be expected, just curious what is normal for OME HD coils.
The only reason I am looking into this is that I have 285/70/17 tires which fit fine when the lift was new. Once the coil sagged a bit, if you are on the highway and the tires get good and warm, they will slightly rub at full lock (pulling a U-turn).
Thanks for info guys!
Derek
Sneaky2Toes is offline   Reply With Quote Quick reply to this message
Unread 05-03-2015, 09:20 AM   #2
BoraBora
2015 JK Wrangler
Yup. Loosen the lug nuts, jack it up under the LCA, put some jack stands under the Jeep, take off the wheel, compress the coil, loosen the 4 nuts above the strut through the engine compartment, and drop the jack under the LCA. Should give you enough room to slide the spacer right in.
'15 JK Sport
'06 WK 3.5" lift on 33's (Sold)
BoraBora is offline   Reply With Quote Quick reply to this message
Unread 05-03-2015, 09:32 AM   #3
Sneaky2Toes
2005 WK
Thanks for the info. I was not sure if it would work with a strut. That strut is under pressure and was not sure if the coil would be compressed but the strut top would still be extended.
