Calling all 2007 WK diesel CRD owners! - Page 10 - JeepForum.com
 1Likes
post #136 of 210 Old 02-23-2014, 01:43 PM
PDragon
2007 WK
I have been driving one for almost a year. Is a 2007, +210,000 Kms WK CRD - the issues of the motor and rest of the truck are well documented. I have no issues with the motor (knock on wood) but other members of this forum haven't been so lucky.
My issues have been with the truck's body work, mainly the sunroof.
The crd has power in spades and runs like a charm. Keep in mind why do you need/want a CRD. In my case the crd's city mileage is "meh" (around 15MPG, I think) paired with very high diesel prices, is not making too much sense for me right now.
That being said, the WK CRD is an awesome machine, that could give you thousands of miles trouble free.
2007 WK CRD / QDII /+250,000 kms
GDE Eco tune / OME HD / JBA UCAs
275-75-17 Cooper Discoverer AT3
PDragon is offline
post #137 of 210 Old 04-07-2014, 05:05 AM
james_2k
2003 WJ
you guys have no idea what high fuel prices are! haha
almost 200 USD to fill my tank.
james_2k is offline
post #138 of 210 Old 06-03-2014, 10:59 AM
Zlartibartfast
2007 WK
Originally Posted by coupdevill View Post
Questions:
If I avoid the 07' can I avoid many of the issues?
Are there mods I should do on the front side?
I figure I can get a low mileage 07-09 WK Diesel CRD for $18-$22K
Advice? Stay away or take the plunge?
coup
I have an 07 (RWD) now with 69K miles on it. I have NOT had the swirl motor issue (I installed the GDE tune just a few months after I bought it in 2012), but I have had 2 glow plugs fail (not a big deal except #6 is hard to get at). No need to "avoid" the 07.
Mods to the front side? Not sure what that means....the only front end mods I made were cosmetic (I did instal new Bilstein struts, by choice not necessity)
Mine is a Limited w/rear DVD - got it with 46K miles it, paid $24K 2 years ago. I know of some folks that got theirs for less than I paid, so you're probably in the ballpark there.
Yes- I would recommend this Jeep to anyone who is comfortable with diesel
Zlartibartfast is offline
post #139 of 210 Old 06-06-2014, 12:44 PM
zc911
anyone else have their oil temp sensor (pretty sure thats what it is) in the oil pan start leaking?
Found a couple drips in the driveway and the sensor in the pan was wet and around it was wet from oil as well. I gave it a couple turns with a wrench to see if that fixes it. Is there a gasket on it it that i can replace at my next oil change?
All cars all the time
zc911 is online now
post #140 of 210 Old 06-15-2014, 01:01 AM
SeekingCRD
2008 WK
Hey guys
I'm looking at an 08 3.0 CRD WK Limited. It's has only 94ooo Kms. I've read a bunch of this forum but did not find much about if the issues were fixed in 08 from the 07..
I will be looking to buy an extended aftermarket warranty for this jeep seeing as I've used the one I got for my diesel f350 and it covered the expensive injection parts, pumps etc...
This one drives nice but I'm concerned with the sensation that it always gears down (or attempts to gear down) when you let off the go pedal. What should my mechanic be looking for when he does the inspection? The codes that come up will they show with a standard code reader?
Thanks
SeekingCRD is offline
post #141 of 210 Old 06-16-2014, 03:45 AM
Tango.
2008 WK
I have an 08, and the gear down which is also a kluck-thud sometimes is normal, just takes some getting used to.
The swirl motor is still a problem on the 08. Since you are in BC you can get tank rust on the bottom of the fuel tank above the skid plate. The is a black o-ring gasket that should be on the large hose cold air intake into the turbo, if it has the orange one it ill leak oil on top of the engine.
There is a tune from GDE green diesel worth the money. Maybe yours has it already?
hope that helps.
Tango. is offline
post #142 of 210 Old 06-16-2014, 09:46 PM
PDragon
2007 WK
GDE Eco tune is a must.
Make sure 4lo is working and that is Recall N23 free
PDragon is offline
post #143 of 210 Old 10-22-2014, 10:07 PM
jarodmarks
2007 WK
I recently bought an 07, 43k miles, just put all the bypass, and delete stuff on with a gde tune. I do have a problem now and haven't left the garage yet. the alt cable that goes to the starter has fuse link that melted off while we where doing the install of the exhaust stuff. Weird i know, come to find out, where it bolts to the starter, it was loose. we attempted to take the wire direct to the battery with an inline fuse, that didn't work, cooked the fuse. would this be an alt issue? any help is appreciated. Also the lighting bolt light is flashing. no codes are being thrown though.
jarodmarks is offline
post #144 of 210 Old 10-24-2014, 01:01 PM
Superfresh
2008 WK
Good to know. will look to see if any of these problems trickle down to my wife's 08
Superfresh is offline
post #145 of 210 Old 10-24-2014, 07:25 PM
jarodmarks
2007 WK
well the alternator was bad, replace it, but still throwing a U1132 code. tried almost everything, any help would be appreciated.
post #146 of 210 Old 10-30-2014, 03:58 PM
arik_zuckerman
WK CRD 2007 q
Hi,
I have a chance to buy a 2007 CRD, but it has 170KMs. In my country those kinds of CRDs are really rare so the chance to find one with a lower mileage is pretty low. As it's the Sprinter's engine, I thought maybe this is not too bad and the Engine may work properly for many more miles. Can someone validate this? When usually those kinds of engine start to really fall apart?
Any help would be highly appreciated,
Thanks!
arik_zuckerman is offline
post #147 of 210 Old 11-02-2014, 06:50 PM
Chirpz
Chirpz's Avatar
2007 WK
You will find quite a few of us on this board and you will find all the quirks that the system has. Once you cure the quirks, I think it great. I have 103,000 on mine and still smiling. Have owned it since 11,000 so I am 2nd owner. Bought it in 08
Chirpz
2007 WK 3.0L CRD, Quadradrive II, GDE EcoTune, DPF-Delete
4xGuard Front, Rear, Belly, & Side Rails, Factory Skids
EHM MOD, Garmin Mechanic EcoHD, K&N Filter (Deleted)
Chirpz is offline
post #148 of 210 Old 11-07-2014, 07:45 AM
caddydaddy
2007 WK
Originally Posted by arik_zuckerman View Post
Hi,
Mine has 269,000 KMs on it and the engine runs great!
2007 CRD Limited w/QDII
GDE HOT Tune, Turbo Resonator Delete
2" RC lift
194,000+ miles!
caddydaddy is offline
post #149 of 210 Old 11-08-2014, 06:46 AM
Jospwr
1947 CJ2A
The happiest day of my owning a 2007 Grand Cherokee with the 3.0 CRD, after the 1st year honeymoon, was the day that it was declared a total loss after a wreck due to black ice. I was thrilled that I was clear of the problems that Chrysler refused to acknowledge & repair. The CRD engine is not the problem. Every connection to it by Chrysler is. The ETC issue is a bad seal which allows oil to flow into the turbo, for instance. That problem, which Chrysler wants to charge you over $2,500 to "fix" & is clearly their poor design issue, became a non-issue for me when it was not taken into consideration by the insurance assessor. I happily took the check for full value and have run, screaming, from Chrysler for evermore. This was my second bad experience with Chrysler, only due to my trusting Mercedes to turn the pig of a company around. Shame on me. NEVER AGAIN.
2007 WK 3.0 CRD - Wrecked early 2013
In youth, formerly owned by '47 Willy's CJ-2A.
Jospwr is offline
post #150 of 210 Old 11-09-2014, 03:59 PM
Tango.
2008 WK
Originally Posted by Jospwr View Post
The happiest day of my ..... That problem, which Chrysler wants to charge you over $2,500 to "fix" & is clearly their poor design issue, .....
That is an excelent example of how good this forum is.
That is also known as the resistor modification and cost only $20 to fix... which one would know by participating in this jeep forum.
Life is hard-John Wayne
Tango. is offline
GC CRD Catch Can dilema - calling all diesel owners ! manitoman WK Grand Cherokee & XK Commander Forum 10 10-21-2009 07:27 AM
Calling all dashhawk owners... sidewaysInto3rd WK Grand Cherokee & XK Commander Forum 0 02-03-2009 01:08 PM
Diesel WK owners rcs8104 WK Grand Cherokee & XK Commander Forum 7 02-28-2008 01:25 PM
Calling all ZJ owners with side steps / rock sliders Rockingdad ZJ Grand Cherokee Forum 12 02-08-2008 02:56 PM
Calling all 5.9 owners. BUNKER ZJ Grand Cherokee Forum 8 03-23-2005 06:37 PM
