a/c problems 2006 wh grand cherokee - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > a/c problems 2006 wh grand cherokee
50" LED CREE Light Bar Pair With Wiring KitFLASH SALE! Open thread to reveil the Newest Sale @ ROCKRIFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 03-27-2015, 10:32 PM   #1
troy123
one day i was driving with the a/c on and it just stopped then the next day it started working again on all settings i turned the car off but I left it on no 3 blower setting when I started the car and it turned on for a moment then stopped and would not come on again. i decided i would buy a ac/heater control module as it was only $200 i waited 3 weeks for that to come with no a/c i installed it and i still had no aircon then the next day i started the car as the blower setting was on 2 and it worked, it worked fine for 3 weeks and now it has stopped again. I checked the blower motor and it works fine (hooked it up to 12v) i do not have AC on hi setting, my next move is to replace the blower motor resistor just to eliminate it. has anyone else had this problem and if so how do you fix it.
troy123 is offline   Reply With Quote Quick reply to this message
Unread 03-28-2015, 05:45 AM   #2
JKM
2005 WK
My first guess would have been the resistor
JKM is offline   Reply With Quote Quick reply to this message
Unread 04-01-2015, 02:49 AM   #3
troy123
Just changed the blower resister still does now work. So now I have eliminated front control panel, HVAC blower, all fuses and relays, blower resister I'm now thinking it could be a bad ground does anyone know if there is a computer that the a/c runs off? Or has any idea what I could try next?
Unread 04-24-2015, 06:49 PM   #4
troy123
Just changed the ignition switch still nothing. I have ran out of ideas will have to take it to the stealer please help
