A/C only blowing cold on the driver side - JeepForum.com
post #1 of 8 Old 05-29-2016, 11:45 AM Thread Starter
samger2
2005 WK Laredo, the A/C blows nice and cold on the driver side, but just blows room temp air from the passenger...thoughts?
samger2 is offline
post #2 of 8 Old 05-29-2016, 12:29 PM
TurboDiesel
2008 WK
blend door actuator behind the glove box???
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline
post #3 of 8 Old 05-29-2016, 12:43 PM
bobbylx
2008 WK
Try charging the system. Mine does that at the beginning of every summer. I add a can of refrigerant and all vents blow nice and cold. I have no idea why low refrigerant does this, but search the forum and you'll find quite a few people with the same results.
2008 Overland 5.7 Hemi
Modified Rusty's lift
JK Moabs/Nittos
Black WK Club #136
bobbylx is offline
post #4 of 8 Old 05-29-2016, 01:12 PM
T1m
2006 WK
Same with me. I was certain I had a blend door issue with all of the threads regarding blend doors. but a simple charge fixed it.
I could be wrong, but I don't think the blend doors are an issue with the '05 and up.
T1m is offline
post #5 of 8 Old 05-30-2016, 10:06 AM Thread Starter
samger2
Thanks for the replies, I guess it would make sense to try the simplest possible fix first
samger2 is offline
post #6 of 8 Old 06-12-2016, 08:20 AM Thread Starter
samger2
So my wife reminded me that we had this happen once before. Sure enough I looked up the service records and found we went to the dealer a year ago and they diagnosed it as the evap core....$1,500.00.
blah
samger2 is offline
post #7 of 8 Old 06-12-2016, 12:22 PM
Montreal300
Montreal300's Avatar
Manual or automatic temperature control?
If it was the core that was the problem, you wouldn't have cold air on either side.
Air comes in the cowl, through the fan and then through the evaporator. The temperature is tempered by having part of the air flow, after the evaporator, go over the heater coil. This air splitting function is done by the blend door.
With automatic dual zone AC systems there are two blend doors.
A description of the system fundamentals is attached.
Montreal300 is offline
post #8 of 8 Old 06-12-2016, 01:21 PM
ggt1_02
2009 WK
Just a thought, if the air is warmer in the passenger side check the recirc gear may be broke and allowing warm outside air in.
Sent from my SM-G930V using Tapatalk
09 WK Limited 5.7L QDII | SRT Intake Tube | BT Catch Can | Hankook Dynapro ATM 255/60/18
ggt1_02 is offline
