A/C Compressor turns on with Fan - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > A/C Compressor turns on with Fan
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 07-29-2014, 09:05 PM   #1
Kapoosta
2006 WK
Does anyone else have the problem where if you turn on the fan, the A/C compressor turns on even without the A/C button turned on? I'm tempted to just pull the A/C Compressor clutch relay to prevent it from coming on because I don't like the increased fuel consumption with it on.
I've tried hitting the A/C button before/after turning on the fan to see if it would turn off but it didn't do anything.
Kapoosta is offline   Reply With Quote
Unread 07-29-2014, 09:50 PM   #2
tjkj2002
2002 KJ Liberty
Normal operation.The AC will turn on automatically in most mode selections nowdays to dehumidify the cabin air even with the temp control on full hot.
tjkj2002 is offline   Reply With Quote
Unread 07-30-2014, 09:19 AM   #3
caulk04
2008 WK
Do you have it on defrost or any blend position with defrost?
I don't think mine runs anywhere but defrost with the AC button DEselected.
I've installed switches to kill the AC compressor on vehicles before. Most notable was a 97 Ranger with the 2.3 powerhouse...I needed air out the defrost vents often, but I also wanted to be able to get moving before I turned gray.
Tint, Superchips, SRT intake tube, Gibson catback, catch can. One hardcore DD/kid hauler...yeah.
caulk04 is offline   Reply With Quote
Unread 07-31-2014, 02:08 PM   #4
Kapoosta
2006 WK
The switch sounds like a good idea. I never use my A/C since our weather doesn't really get that hot or humid.
Thanks for the help.
Unread 08-01-2014, 07:15 PM   #5
pablorg
1981 CJ7
Have you tried this:
- turn the fan on
- turn AC on then off
- turn fan off
- turn fan on
It seems to have worked for me although I am not 100% sure....
- Pablo
2013 JK Sport 6-Speed Manual, stock 3.21 gears (arghhh), 2.5" EMU Lift
1981 CJ-7 Laredo 360 V8 - Edelbrock MPI, Heads and Headers
2005 Grand Cherokee WK Limited 5.7 Hemi (wife's)
pablorg is offline   Reply With Quote
