Buying a WK/XK?? (Read This) - Page 8 - JeepForum.com
 4Likes
post #106 of 246 Old 03-31-2014, 11:17 AM
Palak
2008 WK
Originally Posted by james_2k View Post
or get the crd and get performance AND mileage!
This man knows where it's at! ... I went the same route.. have the power and then some.. PLUS the mileage!.. and this Mercedes engine is quite the sweet little piece of machinery. (Needs a few CHEAP little tweaks to make it run issue free for a LONG time)
Palak is offline
post #107 of 246 Old 07-04-2014, 12:20 PM
PDragon
2007 WK
WK CRD is the way to go!
2007 WK CRD / QDII /+250,000 kms
GDE Eco tune / OME HD / JBA UCAs
275-75-17 Cooper Discoverer AT3
PDragon is offline
post #108 of 246 Old 07-06-2014, 01:34 PM
roysHEMI
2006 WK
ok I m just getting back in the game with my 06 GC Hemi. So don't hammer me and please excuse my lack of knowledge but what is this CRD everyone speaks of.
2006 Jeep Grand Cherokee Limited - 5.7 Liter Hemi WK, QDII, Stock
roysHEMI is offline
post #109 of 246 Old 07-06-2014, 03:58 PM
ZWilson07
2008 WK
Just the diesel motor that you can get as an option.
CRD: common rail diesel
2008 WK Overland 5.7 Hemi 4x4 QD2
Everything I need, plus a lot more I don't.
Black WK Club Member #154 || Hemi Club Member #89
ZWilson07 is offline
post #110 of 246 Old 07-08-2014, 07:47 AM
Billbo1970
2009 WK
I *THINK* it stands for Clean Running Diesel.
Regards,
Bill
Billbo1970 is offline
post #111 of 246 Old 07-08-2014, 12:42 PM
scarerey
2010 WK
Hey folks...
I'm about to look at a 2010 WK Limited with 75K Miles on it. The dealer is asking $21,450. Based on the build sheet, it looks like it has just about every possible option except for the HID headlights. (One of the options I wanted most...)
If I swap the halogen headlights for the OEM HID headlights, will that also give me the auto-leveling feature? (Not sure if that depends on something outside the lamp itself...)
Also, does this sound like a decent deal? The mileage is a bit higher than I'd prefer, but since the only comparable WK's for sale in this area have 85K and 91K miles, I don't know that I should worry about 75K. Thanks!
Build Sheet
Dealer Ad
2010 Grand Cherokee (WK) Limited - 5.7L HEMI V8
scarerey is offline
post #112 of 246 Old 07-08-2014, 08:54 PM
scarerey
2010 WK
Well, I'm looking over that 2010 WK Limited now and it seems to have the dreaded "Service 4WD System" message when I try to shift into 4LO. (QuadraDrive II) I put a scan tool on it and it isn't pulling any codes though. Most of the threads I've seen about that message are due to an issue with an N23 recall, but obviously if it's a problem with the transfer case that could be more severe. Anyone have any thoughts on the severity of that message?
scarerey is offline
post #113 of 246 Old 07-08-2014, 09:17 PM
ZWilson07
2008 WK
You are going to get mixed opinions here. It is pretty common and I wouldn't worry about the message per se.
I was in the same boat as you when I just bought mine and the flash had already been performed.
So I had 2 options.
1. try and find an older pcm that hasn't had the flash and deal with the possible popping into neutral issue.
2. take it to the dealer and make sure the newest procedure for the flash is done and hope it works.
Since I was already dropping it off to have diagnostics ran on my O2 sensors, I went with option 2 and figured it couldn't hurt. My local dealer that i work with stated that they haven't had a single person come back with the 4wd low problem once they did the newest procedure released back in march which seems to be the key here. Mine has been working fine ever since I had the flash redone with the newest procedure and I am seeing more and more of that now.
Now I'm not saying that it is the perfect solution for everyone but I wouldn't let that deter me from buying the jeep because you are going to have that issue to deal with no matter which wk you buy more than likely.
Just my 2 cents.
post #114 of 246 Old 07-09-2014, 05:54 PM
scarerey
2010 WK
Thanks!
Just my 2 cents.
Sounds like very sound advice. I took it, and will be picking the WK up tomorrow as soon as they give it a full detail.
Thanks!
scarerey is offline
post #115 of 246 Old 07-09-2014, 08:27 PM
ZWilson07
2008 WK
Thanks!
You're welcome. Hope it works out.
If it makes you feel any better the day I got mine home I had the 4low problem, a O2 sensor, and cat going out. Talk about an expensive ride home lol. But I will get it all figured out eventually here.
post #116 of 246 Old 07-12-2014, 08:20 PM
davidtownsend
2006 WK
Looking to pick up a 05 wk hemi. What do you guys think? I well be going through the check list. Here is a link to the add.
http://mobile.dealercarsearch.com/Ve...c-3800d7e205d2
1994 Jeep Grand Cherokee 5.2L Limited
2006 Jeep Grand Cherokee Overland 5.7L Hemi
davidtownsend is offline
post #117 of 246 Old 07-12-2014, 08:27 PM
ZWilson07
2008 WK
Whats the carfax show?
Seems clean from the pictures but curious as to what the carfax might show.
post #118 of 246 Old 07-12-2014, 08:35 PM
davidtownsend
2006 WK
It kinda scares me that the price is a little low but I'm going to check right now.
post #119 of 246 Old 07-12-2014, 11:48 PM
ZWilson07
2008 WK
Sounds good.
Keep us updated
post #120 of 246 Old 07-14-2014, 09:04 AM
Billbo1970
2009 WK
I just checked Kelly Blue Book for a dealer purchase based price on that vehicle, and it's around $9k... so be careful & check it out thoroughly!
Direct Link to KBB for that vehicle
Bill
Regards,
Bill
