Buying a WK/XK?? (Read This) - JeepForum.com
 9Likes
post #1 of 273 Old 01-03-2013, 05:30 PM Thread Starter
AJeepZJ
2006 WK
So you're looking to purchase a Jeep WK (2005-2010), here are a few things that you may want to look at during your walk around and/or test drive. Keep in mind that you should always consider having the vehicle you are interested in buying inspected by a certified mechanic, so this post is in no way a substitution of that service.
Always ask about the last time the 4x4 was serviced, ESPECIALLY when it is around and/or approaching the service interval for the 4x4.
Always test every single electronic feature that is available on the WK. I will not list them all, because not all are available on every WK. But test everything from the power mirror windows and heated seats to the Navigation and A/C
Engage the 4x4 on an appropriate trail or gravel road, and ensure that it works properly. This means that is does not bind and buckle, especially during turns.
As you look underneath the vehicle. Inspect the seal on the transfercase, and differentials, and also inspect the area just below the engine to ensure that there is no oil leaking from them.
Many southern dealers will buy Jeeps from the North and sell them down south. Make sure the doggone Jeep doesn't have extensive rust damage.
Other common sense stuff includes checking fluids, brakes, lights, and tires (though every state I've been to requires a certain amount of tread before it can be sold).
Bones_WK: Suggests shifting the transmission between P,R,N,D - And listening/feeling for any delay as this could be indicative of a failing transmission.
Bones_WK also suggests listening/feeling for any clunking while driving, especially over pot-holes or speed bumps as this could be a sign of worn bearings or bushings/Upper or lower Control Arms/Ball joints - etc.
I'm sure I'll miss stuff - so for those who have purchased and own a WK, feel free to contribute on items to look/listen for when purchasing a WK.
pawlished and Punisher07WK like this.
All Gear, No Skill.
AJeepZJ is offline
post #2 of 273 Old 01-04-2013, 03:58 AM
ssobel
2007 WK
Awesome thread. I'm going to look at an 07 Limited, Hemi tomorrow. I'll make sure to turn everything on! Thanks for the advice!
ssobel is offline
post #3 of 273 Old 01-04-2013, 09:25 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Check to see that the auto stick on the shifter is functioning properly.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #4 of 273 Old 01-04-2013, 11:05 AM
BonesWK
2006 WK
Bones_WK: Suggests shifting the transmission between P,R,N,D - And listening/feeling for any delay as this could be indicative of a failing transmission Loud clunk from shifting from PRND or P-D, P-R. R-D etc. are front differential bushings going bad.
Awesome stuff AJ - fixed a few for you.
Also note the 2005-2006 4.7 and Hemi issues about exhaust manifolds going bad. Turn the jeep on, and listen for exhaust leaks in the engine bay, open the hood and smell for exhaust fumes (both sides). Probably applies to anything over 70k to at least check
Turn the wheel while sitting still from lock to lock. Coast down the road truing the wheel some back and forth (safely) - pops or knocks could be the steering rack
Check door handles, these seem to crack and break easily!
Check hood and liftgate supports - easy fix but just be aware
Punisher07WK likes this.
Ryan
2006 Black WK Limited 4.7 4x4 QD II SOLD
Current - 2008.5 Mazdaspeed 3
If you want to achieve greatness, stop asking for permission
BonesWK is offline
post #5 of 273 Old 01-04-2013, 03:00 PM
ATown17
The WK I'm looking at has this problem. What's involved to fix it?
ATown17 is offline
post #6 of 273 Old 01-04-2013, 03:16 PM
ATown17
Just got off the phone with the dealer. Part's cheap... $35 but labor is 3-4 hours. Has anyone changed this themself that can give me an idea of what's involved? Also, if I find that I can't do it and it'll cost me $500 at a dealer, do I hurt anything by not fixing it? Or is it just that I have to hear the loud clunk when shifting into gear? Thanks in advance
ATown17 is offline
post #7 of 273 Old 01-05-2013, 09:27 AM
06JeepXKHEMI
You definitely want to fix it, mine was so bad it was smacking the oil pan. I had my buddy fix it for me so cant give insight on the job but many people on here have done themselves
05 LJRubi Currie 4" Springs, Savvy Fox shocks, MC trackbars, MC CA's single adj lower double uppers, 37x13.50 Cooper STT Pros on 17x9 ATX Ravine, MC Overlines front, Genright rear, Revolution 5.38s, Carolina Driveline driveshafts, MCAI
06JeepXKHEMI is offline
post #8 of 273 Old 01-09-2013, 07:33 AM
Eric1080
1978 J-Series Truck
is the constant ticking noise a problem on all of them? wife 05 with 120k ticks when cold and gets quieter when warm although still making noise
Eric1080 is offline
post #9 of 273 Old 01-13-2013, 10:01 AM
ATown17
Thanks for your help. We wound up not purchasing the jeep.
ATown17 is offline
post #10 of 273 Old 01-15-2013, 06:21 PM
TheDemon
2006 WK
A night time test drive if possible would be wise, some of the lights were out on the buttons for the climate and information center, and ended up costing me about $500 to fix by replacing all the controls, apparently you can't just replace the bulbs and have to replace the entire unit. There was no way to see that the controls were out since I test drove my Jeep during the day.
2006 WK Overland 5.7: SOLD!
TheDemon is offline
post #11 of 273 Old 01-16-2013, 08:37 PM
Theogriff15
2006 WK
My whole climate control unit is dark. Have been waiting to get to the dealer to get an estimate, but I guess now that it costs 500 I'll be turning on my interior lights for now.
2017 JKU - Sport, 3.21, Weathertech Floor Liners, Quadratec Diver Down Seat Covers
Theogriff15 is offline
post #12 of 273 Old 01-16-2013, 09:25 PM
jjt250
2007 WK
Hey guys I found this on another forum. Haven't watched it yet but it helped out a lot of people so far.
2007 Grand Cherokee Limited | QDII | 3.0L Diesel | S4xC Shackles Mounts | Goodyear Duratracs
Bilstein HD Front/Rear | Rusty's 1/2" Strut Spacer | Hemi XK Front/Rear Coils | HID Projectors
jjt250 is offline
post #13 of 273 Old 01-17-2013, 01:44 PM
TheDemon
2006 WK
Nice video! Too bad I didn't see that before the stealership jacked me
TheDemon is offline
post #14 of 273 Old 01-22-2013, 07:04 AM
WXman
So the steering racks, exhaust manifolds on V8s, and electrical gremlins are basically the only common problems with WKs? I'm considering a Hemi model myself, but I want a dependable vehicle that I don't have to throw money at when it gets a little age on it.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #15 of 273 Old 01-22-2013, 08:37 AM
Eric1080
1978 J-Series Truck
you will also most likely have to replace the suspension (shocks/ struts/ ball joints) when it gets some miles on it. my 05 has 120k and rear shocks did nothing and front struts barely do anything anymore. not a ton of money but still only has 120k....
Eric1080 is offline
