Which bushings usually need replacement on the Front Lower Control Arms? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Which bushings usually need replacement on the Front Lower Control Arms?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineForever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!
Unread 12-03-2015, 06:29 PM   #1
Sneaky2Toes
2005 WK
Hello all,
I am currently working overseas and only get home to the States once a year. I had someone back home take the Jeep in for inspection so I could register it again. The Jeep failed the inspection due to bad lower ball joints.
I have been reading through threads and the job doesn't look that tough. My WK is an '05 with 115K miles. I have an OME HD kit with JBA UCA's. I only want to tear that front end apart once and get it aligned once.
So far I have bought the following MOOG replacement parts:
-Front LCA ball joints
-Inner and outer tie rod ends
I need the help of the community to tell me if all the bushings on the LCA go bad or just a couple (maybe the clevis bushing and the lower rear bushing?)
There are three bushings in the LCA and I think these are the Mopar part numbers (please correct me if I am wrong)
52089989AA (MOOG-K200182) - Front Lower Rearward
52089991AB (MOOG-K200183) - Front Lower Arm to Strut (clevis)
52089988AC (MOOG-K200181) - Front Lower Forward
I have a ball joint press and am hoping these can be pressed in using that. My main question is do all 3 go bad usually?
Thanks for the help!
Sneaky2Toes is offline   Reply With Quote Quick reply to this message
Unread 12-05-2015, 11:45 AM   #2
Sneaky2Toes
2005 WK
Well, I decided to order all 3 and am just going to rebuild both lower control arms while I have things apart.
Unread 12-05-2015, 08:19 PM   #3
jgump
2009 WK
Please let us know how this goes. I need to do mine. I get the clunk over bumps. Thanks.
jgump is offline   Reply With Quote Quick reply to this message
Unread 12-06-2015, 08:06 AM   #4
Sneaky2Toes
2005 WK
I won't be doing this until July of next year when I get back to the States. Can you wait that long?? LOL
Unread 12-06-2015, 08:20 AM   #5
jgump
2009 WK
Maybe. It is the wife's Jepp. LOL
Unread 12-06-2015, 08:31 AM   #6
Sneaky2Toes
2005 WK
I am hoping everything comes apart easily. I have a ball joint press that I will see if I can use to press in the new bushings. If that doesn't work, my plan is just run the control arms to a shop with a press and have them do it. Figure it should be pretty cheap since its only 4 bushings and the part is already out and ready to work on.
Unread 12-06-2015, 08:50 AM   #7
jgump
2009 WK
I have a Dake press at work, so hopefully it helps.
