burning "smell" issue and "gas pedal vibration" issue in 07 gc laredo
#1 | |
hi everyone, just picked up an 07 laredo x pkg last week...
ive noticed a couple of things that i wanted to check in on... first of all, i noticed there is a "burning" smell... i can sometimes smell it when i am in the car while driving.... but i can usually always smell it after i stop and actually get out of the car... another thing i noticed, which may or may not be related, is that my engine coolant is already down to the "add" line... i did not pay attention to where this was filled up to when i bought the car, so i dont know if it was already a little low when i bought it, and i also dont know if it is normal to go through more coolant than normal when you first run the vehicle... i also didnt know if this smell was "normal" on a new car... but as i am nearing a week in service and about 400 miles, i am startting to get concerned because the smell has not gone away... i also think i noticed a steam/smoke rise from under the hood at one point, but it was also raining so i didn't really take note at the time.,, the second issue is that i can sometimes feel intermittent vibrations on my accelarator pedal... they seem to have no relation to anything (ie, not dependent on whether i am accellerating, coasting, on different road surfaces, etc) this vibration just seems to come and go without provocation... the vibration is very small.. and some people driving may not even njotice it unless they were really paying attention and "looking" to feel it... all that said, i am not noticing any performance issues or otherwise..,, wondering if anyone has any thoughts on this, and what should be my next step, if any... thanks!!!!
#2 |
Sounds as if your baking the the paint on your motor, all new engines kind of smell like they are burning for the first 2-3k miles. The smell is gone on mine after 5k. Whats your temp gauge reading ? Add some coolant and don't worry about it unless it goes down again.
Can't help you with the vibration issue, sorry, could be a million things.
93 GC Laredo 4.0 I&E, 30/35C, AW4, 249, 30X9.50 MT DD with occasional trail/camping duty 06 Commander Limited 5.7 Hemi ! |
#3 |
temp reading is normal, so maybe that's it!
thanks for the reply! |
#4 |
No clue about the smell however you seem to be describing a vibration that sounds very similar to what im experiencing. About 1,500 miles ago I brought my 05 Hemi in for front end whine. They fixed the whine however now I notice a weird pulsating vibration mainly felt in the pedals and is intermittent with throttle position. It seems most noticeable after coasting and then accelerating again. Best way to explain is what I think to be the torque converter engaging or as the RPM's drop down. I swear it started after they did the front ring and pinion work. Someone mentioned they may have not mark matched the driveshaft. I am having a very hard time getting a dealership to fix it. The tech finally felt it however he said he has no clue what it is and thats as far as I got.
JT |
#5 |
hmm. i wouldnt really describe it as "pulsating"... i know it's really hard to explain things like this over a message board... but i would describe what i am feeling similar to maybe what it would feel like if you took a... well, for lack of a better description... what it would feel like if you took a vibrator, and touched it against the gas pedal... and the "second hand" vibration you would then feel through the vibrator through the pedal is what i feel...
it's a very tiny vibration that is very quick, and as i said, probably would be unnoticable unless you were really concentrating and trying to feel it...
'11 gc ltd. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
