Bumping up the Rough Country lift to 3+ inches?? - JeepForum.com
post #1 of 9 Old 10-04-2013, 05:55 PM Thread Starter
camber
Hey guys,
So I have the Rough Country 2" spacer lift. I am thinking of getting the Bilstein 5100 adjustables in the front and setting them to .85" ... then getting Monroe load levelers for the rear. From everything I understand that should put me at about 3-3.5" of lift but still within spec to not have to deal with alignment and steering rack issues.
Does anyone know if I will be looking at other problems or issues in running this setup? Anyone running a similar setup? Pics are DEFINTELY welcome!
camber is offline
post #2 of 9 Old 10-04-2013, 07:29 PM
BoraBora
2015 JK Wrangler
All about measurements bro. Just don't exceed 22.5" up front and you're solid. In fact I even have a brand new set of Bilstein 5100 front struts I'm selling. If you decide to go this route I'll let them go for cheap.
'15 JK 2.5" lift on 35's
'06 WK 3.5" lift on 33's (Sold)
BoraBora is offline
post #3 of 9 Old 10-05-2013, 07:49 AM
Eastwk
2007 WK
This is exactly the setup I want to run I hope we see some pics
Eastwk is offline
post #4 of 9 Old 10-05-2013, 10:27 AM
Eastwk
2007 WK
How much do you want for your struts
Eastwk is offline
post #5 of 9 Old 10-05-2013, 01:11 PM
BoraBora
2015 JK Wrangler
$175 shipped. Sounds fair to me since shipping them is $50 just by itself.
BoraBora is offline
post #6 of 9 Old 10-07-2013, 02:49 AM
R4TCHET
2005 WK
i have the RC lift as well. i already have OME shocks installed. i just picked up some Rustys rear shocks which extend to like 29", a Rustys adjustable rear track bar, and a set of Rustys .25" spacers for the front. i plan on getting some OME MD springs in the near future, keeping my front OME shocks, putting a .25" spacer in front and leaving the rear RC spacer on, installing the rear track bar, and getting some brake line extensions. if it has too much rake (which im afraid of) im going to either get some 1" rear spacers fabbed up. an eventual RRO UCA up front is going to be coming as well.
| (dark)KHAKI WK CLUB MEMBER 17 | 2005 4.7L QTII | JBA UCAs | Modified OME MD 3.5" lift | Rusty's Adj. track bar | 4XG Matrix | 285/70r17 Duratracs | 17" KMC Enduro Wheels | Rola Roof Rack | 21" Bean LED Light bar on Roof Rack | 2 12" Punch P3 Subs | Expanded Sheet Grille | SA Sliders |
R4TCHET is offline
post #7 of 9 Old 10-18-2013, 10:49 AM
Chadwi
2007 WK
Originally Posted by camber View Post
Hey guys,
I am planning to use the 5100's with the RC lift. Stock I was at 18.5" front, 20" rear. I welded a 2" conduit coupling to the rear RC spacer to extend the bump stop 2". I made a poly spacer from a JK rear one I had to put the rear at 3.5" lift. I expect to have to cut the spacer down, it's 2" thick right now. My main concern is down travel in front with the longer 5100's and RC spacer. I ordered the JBA control arms to take care of the ball joint issues. I may look into limiting straps if it appears to be an issue. I am shooting for a ride height of about 22" in front with just a little rake.
Chadwi is offline
post #8 of 9 Old 10-18-2013, 12:06 PM
bobbylx
2008 WK
Stupid question, but where is this measurement taken? Fender lip to center of hub? or elsewhere?
Struggling with the same decisions now for mine.
bobbylx is offline
post #9 of 9 Old 10-18-2013, 12:09 PM
Chadwi
2007 WK
You are correct! Center of hub straight up to fender lip. By using this measurement it eliminates a lot of variables such as tires.
Chadwi is offline
