bulletproof wk build thread - Page 3 - JeepForum.com
post #31 of 74 Old 12-26-2012, 07:38 PM
bhawks28
2014 JK Wrangler
wow man, nice lookin' WK!
bhawks28 is offline
post #32 of 74 Old 12-26-2012, 10:25 PM Thread Starter
christiang26
2009 WK
Thanks.
After the lift was installed took the wk to a carwash to get sprayed in the frame with wd-40
christiang26 is offline
post #33 of 74 Old 12-26-2012, 10:41 PM
thedude411
2008 WK
not what i was expecting at all in this thread
pretty neat tho
thedude411 is offline
post #34 of 74 Old 12-26-2012, 10:45 PM
Quantum
2007 WK
When money is no object...
Uhm, what does your dad do?
Quantum is offline
post #35 of 74 Old 12-26-2012, 10:47 PM Thread Starter
christiang26
2009 WK
Finally got bigger tires they are 305/70r17 nitto terra grappler
post #36 of 74 Old 12-26-2012, 10:49 PM Thread Starter
christiang26
2009 WK
He make special security suits for car manufacturers. I can't say that money is not a problem, the only vehicles that they decide to bulletproof are my brother and mine to keep us safe, all the mods on my vehicle came from my wallet.
post #37 of 74 Old 12-27-2012, 02:39 PM
AJeepZJ
2006 WK
Looks really nice, dude - I like it!
All Gear, No Skill.
AJeepZJ is offline
post #38 of 74 Old 12-27-2012, 02:47 PM
smcginnis87
4X4WK
smcginnis87's Avatar
2007 WK
That is crazy!
2015 WK2
--4x4WK--
smcginnis87 is offline
post #39 of 74 Old 12-27-2012, 03:02 PM Thread Starter
christiang26
2009 WK
Thanks I appreciated.
I want to copy the hidden winch mod from omelet but I don't know if it will work with the 2008+ bumper, I am also saving some money to buy a mj and use it as a trail vehicle.
post #40 of 74 Old 12-27-2012, 03:10 PM
Quantum
2007 WK
Things are obviously going far better in VZ than in the US...
Quantum is offline
post #41 of 74 Old 12-27-2012, 03:16 PM Thread Starter
christiang26
2009 WK
I don't think the same way in Venezuela you can't go out in the night, the only way is if you have a bulletproof vehicle because in the first traffic light some guy in a motorcycle will try to kill you or rob what you have bought with hard work
post #42 of 74 Old 12-27-2012, 04:46 PM
suzieque
2008 WK
I assumed this thread was about making the vehicle so it was very capable and never break down on the trail, was I wrong!
Interesting thread though!
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #43 of 74 Old 12-27-2012, 06:26 PM Thread Starter
christiang26
2009 WK
That's what I want but remember that has a lot of added weight plus all the armor so the suspension could brake if I abuse in some trails
post #44 of 74 Old 12-27-2012, 06:55 PM
toycam
I'm guessing that the glass is also bulletproof then, huh? If so, that stuff is generally a bit heavier than regular tempered glass. Does the window motor have to be adjusted accordingly?
toycam is offline
post #45 of 74 Old 12-27-2012, 07:10 PM Thread Starter
christiang26
2009 WK
Yes is much more heavier, the motor was not adjusted but there is a shock inside the door panel that helps the window to go up but it also limits the window to open half way
My '05 WK build thread. ogie WK Grand Cherokee & XK Commander Forum 36 02-12-2015 08:42 AM
Another build thread punisher65 ZJ Grand Cherokee Forum 11 10-13-2011 02:29 AM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
BizarroZJ Build thread Bizarro_ZJ ZJ Grand Cherokee Forum 5 04-07-2009 02:34 PM
