Budget Boost Long-Term Update - JeepForum.com
post #1 of 9 Old 05-13-2013, 12:54 AM Thread Starter
Texas WJ
Texas WJ's Avatar
2005 WK
It's been a LONG while since being active on here, but I thought I would add this to the JeepForum collective.
The '05 has been chugging along much neglected when this past week a metal on metal clunking has developed in the rear. I finally crawled underneath and the rear coil spacer has just been completely obliterated. It's completely gone and what could not fall out through the springs is just hanging around the bottom of the coil doing nothing useful.
100K on that lift, and nearly 6 years I think. 130K on the Jeep total. Just a heads up, I guess these things can wear out.
I think I have a Skyjacker lift [EDIT - it was a TerraFlex Lift], but won't be sure till I talk to the guys at the shop where it was installed tomorrow to see what my options are.
On a side note, I have a transmission shudder when going from reverse to drive. I topped off the fluid which seemed to help for a day or two but the shudder came back. Time for a filter and fluid swap? Or am I missing something? I haven't had a ton of spare time to search and I'm not sure it's worth a second thread of its own. Other than that, the transmission seems to be operating normally.
And just because I'm a photo whore:
265/70-17 BFGoodrich All-Terrain T/A KO, 2" lift, JK Wrangler Moab wheels, Spidertrax Spacers, Rola Roof Rack.
Texas WJ is offline
post #2 of 9 Old 05-13-2013, 02:05 PM Thread Starter
Texas WJ
Texas WJ's Avatar
2005 WK
Updated, it's a TerraFlex spacer in the rear and my buddy's shop manager has only heard of one failing before... on a Grand. So, there we are.
Shockingly, and whether this is do to my buddy and who he is or just overall awesome customer service, they're going to warranty the parts and labor. So, two new spacers are heading my way.
Awesome.
Texas WJ is offline
post #3 of 9 Old 05-13-2013, 02:48 PM
kVon
Awesome.
Are the spacers poly or steel?
2005 WK 3.7 Laredo Rocky Mountain - 255/70R17 Grabber AT2 - RC 2" BB - Spidertrax 1.5" spacers - Bilstein HD & MLL - Rola roof basket - Midland CB w/2' Firestik - Solid Rear diff cover
Red WK Club Member #30
kVon is offline
post #4 of 9 Old 05-13-2013, 03:05 PM Thread Starter
Texas WJ
Texas WJ's Avatar
2005 WK
Poly in the rear.
The front are steel.
Texas WJ is offline
post #5 of 9 Old 05-13-2013, 07:08 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Awesome.
Awesome indeed!
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #6 of 9 Old 05-15-2013, 03:38 PM
Ben824
1997 XJ Cherokee
The transmission filters have a life of 100,000 miles. So you are definitely due for a change! You can do a complete system flush but there is conflicting opinion as to whether this is necessary or even good for the transmission on these Jeeps. But the basic drain the pan and change the filter service is always recommended. Remember unlike on an engine, only about 20-25% of the total amount of fluid in the transmission is in the pan. Most of the fluid stays in the transmission so when they drain the pan and refill it with about 5 quarts of fluid, they are only replacing a portion of the total amount of fluid and there will still be old fluid in the transmission that the new 5 quarts will mix with.
Ben824 is offline
post #7 of 9 Old 05-15-2013, 04:29 PM
lekmedm
2007 XK Commander
Someone once explained the tranny drain/flush controversy this way. There are transmissions that do not have serviceable filters. They have built-in screens that pull out contaminants from the fluid. These trannys can be flushed because the machine pushes the fresh fluid backwards through the system, which helps clean out the screen. Somehow this doesn't damage any internals. While out trannys use replaceable filters, if you were to push fresh fluid backwards through the system, you would still have a somewhat dirty filter(s). Perhaps pushing the dirty nasty stuff can also clog up the internals in ours?
Anyway, since our documentation specifies a drain and fill with new filters, that's what I always do.
2007 Commander Overland / 4" SuperLift / 285/70R17 Cooper Discoverer ST Maxx / + other great stuff
lekmedm is offline
post #8 of 9 Old 05-16-2013, 08:04 AM
paroxysym
2007 WK
glad to read this, as i have been wondering the long term deterioration of the poly style spacers on my WK. no granted my daystar BB only has roughly 45k on it, ill be looking at the rear spacers this weekend when i swap out my swaybar links.
did you take a look at the front spacers?
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #9 of 9 Old 05-19-2013, 11:34 PM Thread Starter
Texas WJ
Texas WJ's Avatar
2005 WK
The front spaces are looking fine, but they're metal.
The rear had developed a sag, the extent of which I had not realized till I got the Jeep back on Friday. Man, I knew something looked "off" at the rear. This Jeep spends a good deal of time on rutted, wash-boarded, dirt roads so you're mileage may vary.
And I agree with y'all on the filter and fluid swap. I'll have that done when I get the Jeep in for that recall later this month. Can't hurt and doesn't really cost that much.
Texas WJ is offline
