Broken door handles - JeepForum.com
post #1 of 16 Old 08-14-2013, 11:13 AM Thread Starter
lafacej
Broken door handles
I know it's probably been posted here before but I have one of the classic broken door handles on my 05 limited. I saw the replacements online for 30-40 each I think. Does anyone know how easy these are to do or if I'm better off doing fiberglass behind the door panel to strengthen the broken are?
Thanks!
lafacej is offline
post #2 of 16 Old 08-15-2013, 05:19 PM
justinmiller930
2011 WK
I'm having the same problem with my 05. It seems like the inside door handle is rather hard to open. I have to pull mine almost clear out for them to open the door.
justinmiller930 is offline
post #3 of 16 Old 08-15-2013, 05:37 PM Thread Starter
lafacej
Mine still seem to open fine it just feels loose and disconnected from the panel
lafacej is offline
post #4 of 16 Old 08-19-2013, 02:10 AM
scootter82
2009 WK
I'd love to get a stronger door handle. They just feel kind of cheap. Like I could break it off if I pulled too hard.
OME HD, JBA UCA, Rear Adj TB, Catch Can, K&N CAI, Gibson CB, MM TB, Flaspaq, Full LED swap
scootter82 is offline
post #5 of 16 Old 08-19-2013, 09:15 AM Thread Starter
lafacej
I saw online that they make replacement ones but I'm not sure how exactly they go in
lafacej is offline
post #6 of 16 Old 08-19-2013, 12:27 PM
Jeepforthewin
2010 JK Wrangler
According to Jeep you are supposed to replace the entire door panel due to the way the handles are attached. Search the forums about it and there are a couple people who came up with ways to replace just the handle area itself and nothing else.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #7 of 16 Old 08-19-2013, 12:43 PM Thread Starter
lafacej
That's what I found, you just need to drill out the plastic rivet/slugs then use a self tapping (short) screw and washer to put the new handle area in. $30 a piece on eBay, I ordered one to give it a try as I only have one bad door handle
lafacej is offline
post #8 of 16 Old 08-22-2013, 12:39 PM
10Xk
2014 WK
File a complaint with the NHSTA and maybe It will be a recall.
https://www-odi.nhtsa.dot.gov/ivoq/
Is the OEM fix about $800 per door for the panel?
10Xk is offline
post #9 of 16 Old 08-22-2013, 01:51 PM Thread Starter
lafacej
I did file, likely nothing will come of it. But yeah I got an estimate of 769 per door I think. Only 1 of mine is broken but I will be fixing it Friday or Saturday when my new handle comes in. I'll put up some pics to show how it looks
lafacej is offline
post #10 of 16 Old 08-25-2013, 10:01 AM Thread Starter
lafacej
I fixed my door handle today with the replacement handle from parts pros and it only took me about 20 minutes total including removing and replacing the door. Looks perfect and the directions are very simple. Def going to do my other doors if I start to notice a problem.
lafacej is offline
post #11 of 16 Old 08-25-2013, 10:10 AM
Jeepforthewin
2010 JK Wrangler
You just screw the new one in it looks like? I know some people have filed the plastic took the old one off then remelted the plastic to lock the new one in place. How much for the replacement and how is the quality?
post #12 of 16 Old 08-25-2013, 02:40 PM Thread Starter
lafacej
Yeah they're really short self tapping screws. It was only 30 bucks with free shipping and the quality seems great so far it feels much sturdier and less brittle than the OEM and the color match is about perfect.
lafacej is offline
post #13 of 16 Old 08-25-2013, 03:01 PM
Jeepforthewin
2010 JK Wrangler
Nice! I will have to check the website out I've been using a broken handle for about a year now
post #14 of 16 Old 08-26-2013, 08:01 AM
blue3
2005 WK
The new one has to slip on the old posts, which have mushroomed tops to them. So the new one doesn't slip right on, you have to modify the mushroom tops somehow.
We ended up using a dremel to trim them, and the self taping screws worked well to attach it all. Hopefully the screws don't come loose with usage. They are very short and are going into plastic, so that concerns me.
blue3 is offline
post #15 of 16 Old 08-26-2013, 08:11 AM
Jeepforthewin
2010 JK Wrangler
That is true. I may end up putting some Gorilla Glue around the edges and then the screws just incase they do come loose.
