Broken door handle from ice storm - JeepForum.com
post #1 of 16 Old 02-12-2014, 05:01 PM Thread Starter
quicksilverado
2007 WK
Tried to open drivers door when the jeep had about 1/2 inch of ice on it. Heard a pop and the handle pulled out normally, but the door did not open. Now the door will not open from the inside or the outside. Anyone have any suggestions to get the door open. I hate to take it to the stealership.
07 Grand Cherokee Limited CRD 4X4 GDE tune
00 Silverado 10 sec work truck
quicksilverado is offline
post #2 of 16 Old 02-12-2014, 05:11 PM
Jeepforthewin
2010 JK Wrangler
I would say take the door panel off but you need the door open for that. Is it frozen shut maybe?
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #3 of 16 Old 02-12-2014, 05:38 PM
Shafer57
2006 WK
X2.
Pull the door panel, and confirm all of the linkage is properly connected to the handle/lock cylinder still. Dealer is going to charge you ~$90/hr, so try this yourself first. Might be something simple.
Dodge Dakota R/T 360ci Small-block _sold_
Jeep GC 5.7L Hemi- Magnaflow Cat-Back, BT Catch Can, 20" Gloss black SRT Reps
275/45R20 Nexen Roadian, Blacked out, 180 Stat _SOLD_
2008 335i Twin-Turbo
Shafer57 is offline
post #4 of 16 Old 02-12-2014, 06:37 PM Thread Starter
quicksilverado
2007 WK
Originally Posted by Shafer57 View Post
X2.
I would do this, if I could get the door open so I could take the door panel off. Anyone else with any suggestions.
post #5 of 16 Old 02-12-2014, 06:41 PM
tom19511
2014 WK
There is probably ice freezing the weatherstripping to the door??? Try to get in from another door. and warm it up.. If you still cant open it the linkage may have disconnected (plastic link) or broke. Good luck..
Tom
tom19511 is offline
post #6 of 16 Old 02-12-2014, 06:52 PM
Shafer57
2006 WK
Even pulling the handle from the inside, and pushing, does nothing?
Shafer57 is offline
post #7 of 16 Old 02-12-2014, 07:03 PM Thread Starter
quicksilverado
2007 WK
The linkage is broken. When I pull either handle there is no resistance. Definitely not frozen shut. I drove it around for about 3 hours. Had to get in and out from the passenger door. What a pain in the a$$.
post #8 of 16 Old 02-12-2014, 07:07 PM
Shafer57
2006 WK
Any tension when you turn the key in the lock?
Shafer57 is offline
post #9 of 16 Old 02-12-2014, 07:11 PM Thread Starter
quicksilverado
2007 WK
Did not try that, but I did hit the lock unlock buttons on the door panel and fob several times, with no luck. It locks and unlocks fine. Just no tension when you pull either handle to open the door.
post #10 of 16 Old 02-12-2014, 07:47 PM
Shafer57
2006 WK
Sounds like you've disconnected the linkage that runs to the pull handle. I'm rattling my head to think of any other way to open it without damaging other parts.
Do you have a decent locksmith in your area? Or maybe a mechanic who has dealt with this before?
Shafer57 is offline
post #11 of 16 Old 02-12-2014, 07:51 PM Thread Starter
quicksilverado
2007 WK
Talked to a friend that does body work. He said he can sometimes remove a door panel with the door closed. We are gonna give that a shot in the A.M. If that fails. I will have to support the local stealership.
post #12 of 16 Old 02-12-2014, 08:16 PM
Anon155
2005 WK
Is there no way to get to the door linkage by removing the window switch bezel? I would think by removing that bezel it would give you enough room to at least slide a hand back there to reconnect it, or at least see what rod/linkage is causing the issue.
05 Jeep Grand Cherokee: ORT 4X4; Khaki #55
Too many mod's to list...
Anon155 is offline
post #13 of 16 Old 02-12-2014, 08:29 PM
Shafer57
2006 WK
It's worth a shot to remove AS MUCH as OP can, and trying to see inside of the door to see what's broken.
Good idea Anon
Shafer57 is offline
post #14 of 16 Old 02-13-2014, 09:26 AM
BonesWK
2006 WK
Check out this video I found (just posted in DIY area too) - its for switching out the broken interior door handles, however it does show how to get to the linkage and take the door panel off and see if its broken
Ryan
2006 Black WK Limited 4.7 4x4 QD II SOLD
Current - 2008.5 Mazdaspeed 3
If you want to achieve greatness, stop asking for permission
BonesWK is offline
post #15 of 16 Old 02-13-2014, 10:19 AM
Shafer57
2006 WK
Nice video Bones.
OP, you might have to unbolt the driver's seat and try to push it towards the back of the vehicle to give yourself more room to work. That's what i've done on other cars/trucks.
Shafer57 is offline
