-   WK Grand Cherokee & XK Commander Forum (http://www.jeepforum.com/forum/f67/)
-   -   Brake lines for modified OME? (http://www.jeepforum.com/forum/f67/brake-lines-modified-ome-1832282/)
WieSeL 11-26-2013 07:23 PM
I got rustys spacers for the front and rear and was wondering if brake line length would be an issue. Do you have to get extended brake lines or any kind of drop bracket to compensate for a total of 4 inch lift front and rear? Stacking spacers up front with extended studs for the strut plates and going another 1.5 out back with removing the stock coil insulator and adding in a 2 inch spacer to get a full 4 inch lift.
WieSeL 11-27-2013 09:22 PM
Bump
JeepN4KC 11-27-2013 09:57 PM
Put it together and then take a look at how much slack you have in the brake lines. Flex it out somewhere you have control of your suspension travel - ideally an RTI ramp but you get what I'm saying.
The front you ought to be able to tell pretty quick since you're basically pushing the "default" down travel by stacking spacers. The rear probably has a little more room to play with.
FWIW when I modified mine with 1 Rusty's spacer up front and combined a .5" poly spacer with extra coil isolaters out back I did not do anything in regards to brake lines. Granted, it's about a half inch under what you'll be, but I don't have any issues - and it's been tested..........I've never disco'd the sway bars, but I've wheeled it hard a few times since the modification.
WieSeL 11-27-2013 10:10 PM
Ok I will check it out and if need be get some custom lines built. Thanks
ca07wk 11-28-2013 09:35 AM
I'm am working on finding someone to mass produce extended brake line for the WK
WieSeL 11-28-2013 09:57 AM
There is a performance shop where im at that builds lines for around $10 to $20 a line. My buddy had to get some built for his 4runner and his 4 inch lift
ca07wk 11-28-2013 10:15 AM
Damn that's cheap! What's this place called?
WieSeL 11-28-2013 11:00 AM
Tognotti's. It's a local speed shop up here in Sacramento.
WieSeL 11-28-2013 11:01 AM
Tognotti's. It's a local speed shop up here in Sacramento. I think they are mostly $20 depending on length and all.
The time now is 02:56 PM.
