boston acoustic system question - JeepForum.com
post #1 of 7 Old 02-18-2009, 07:02 PM Thread Starter
konarider94
2005 WK
Does anyone know if the input to the amplifier is at a pre-amp level or speaker level input. the reason im asking is because i want to add an aftermarket subwoofer and it would be very convenient to tie into a pre-amp signal right in the rear part of the jeep. alternatively my amp has a speaker level input. or i could use a line level converter.
konarider94 is offline
post #2 of 7 Old 03-10-2009, 09:47 PM
98JEEPTJ
2005 WK
I do not have the answer you are looking for but you might have an answer for me. Do you have a wiring diagram for the stereo and amp? I am also getting everything in order to add a Double din DVD/navigation system and sub and amp.
OUT WITH THE OLD R.I.P. 98 TJ Sport 4" Procomp lift/adjustable lower control arms and track bar **** Cepek FCII 33x12.50x15/**** Cepek DC-1 wheels
IN WITH THE NEW 05 WK LIMITED EDITION 5.7L
98JEEPTJ is offline
post #3 of 7 Old 03-15-2009, 08:59 PM
warrenhaynes
2006 WK
I used an inline converter. Everything works fine except the sub has a seperate volume control and still bumps pretty hard when the stereo volume is low between 1-15
warrenhaynes is offline
post #4 of 7 Old 06-24-2009, 12:43 AM
davidkaron
where did you connect the inline converter to?
davidkaron is offline
post #5 of 7 Old 06-24-2009, 01:36 AM
Remmy
2005 WK
I just got done putting subs in mine yesterday using hi-lo converters from radio shack.
I was wondering if the head unit was a preamp as well so I used the outputs of the amp instead to prevent any clipping.
I used pin outs 3,4,9, &12 on the Amplifier Connector C1. For the remote wire I used the left side cig lighter on the dash.
Check Here <--- that will be your friend.
Someone on another forum mentioned pinout 13 (Red/Yellow) on the C2 connector was a remote wire but I cant confirm that.
Remmy is offline
post #6 of 7 Old 06-24-2009, 01:45 AM
davidkaron
I used pins 1,2,7,8 on the Amp C1 connector. Didn't use a high low converter or a remote wire because my JL Audio amp takes high level inputs and has signal sensing for turn on. But somethings definitely worng cause the sub sounds like crap. Maybe something is out of phase?
post #7 of 7 Old 06-24-2009, 04:58 AM
Remmy
2005 WK
^ Try using the pins I used. The head unit might not be putting out enough power for the amp.
Remmy is offline
Adding amp and sub with boston system arc11 WK Grand Cherokee & XK Commander Forum 4 09-14-2009 09:11 PM
direct ipod connect to 2005 GC w/ Boston Acoustic Stereo jschaden ZJ Grand Cherokee Forum 8 09-12-2009 11:32 AM
Boston Acoustic Speakers distortion sanitarium16 WK Grand Cherokee & XK Commander Forum 5 07-10-2009 06:58 PM
Boston Sound System? DarrylFlynn WK Grand Cherokee & XK Commander Forum 11 01-27-2009 05:10 PM
Boston Sound system upgrade? oberth1 WK Grand Cherokee & XK Commander Forum 22 02-13-2008 12:39 PM
