BoraBora build thread - Page 2 - JeepForum.com
post #16 of 394 Old 06-09-2013, 04:10 PM
AJeepZJ
2006 WK
Nice build nice to see these continue to pop up, unless Omelet is updating these I really don't have the time to update the WK THREADS LIST, but I will get them all in there eventually!
Good luck with the rest if the build!
All Gear, No Skill.
AJeepZJ is offline
post #17 of 394 Old 06-10-2013, 06:51 AM
robswk
2008 WK
Hey nice setup going, I have same plan for the lights behind grill idea only problem is Idk which lights would be best, i think i want more of distance rather than width of beam. Have you hooked them up yet? If so csn you post pics of the beam pattern please!
robswk is offline
post #18 of 394 Old 06-11-2013, 07:25 PM Thread Starter
BoraBora
2015 JK Wrangler
Yeah, I'll snap some pictures and upload them soon. My real camera is broken hence the lack of pictures in this thread.
BoraBora is offline
post #19 of 394 Old 06-11-2013, 09:02 PM
ca07wk
2007 WK
The back is easy, and I've read even easier with a spring compressor.
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #20 of 394 Old 06-15-2013, 10:09 AM Thread Starter
BoraBora
2015 JK Wrangler
Here are some pictures I've been slacking on taking. I used L shaped brackets to lower the lights an inch.
Ignore the dirt on my step pad....theres still dried up mud and rocks embedded in it. I need to wash it soon.
Got my ORT badge!
BoraBora is offline
post #21 of 394 Old 07-07-2013, 01:13 PM Thread Starter
BoraBora
2015 JK Wrangler
Almost pulled the trigger on some new struts, shocks and 265 tires....decided to contact Kolak and will be ordering the OME HD and 285 tires instead.
'15 JK 2.5" lift on 35's
'06 WK 3.5" lift on 33's (Sold)
BoraBora is offline
post #22 of 394 Old 08-28-2013, 08:38 PM Thread Starter
BoraBora
2015 JK Wrangler
Almost all the parts are in! Just waiting on the order from Rusty's to arrive with my trac bar, rear poly spacer and extended rear sway bar links.
So far I have the OME HD springs, Bilstein 5100 struts and shocks, 1.5'' Rough Country wheel spacers all around, tires and JK moabs. Scored a set of 285/70/R17 Duratracs for $250 with about 60% tread left on them.
Also installed my 7w Cree reverse LED's. Man what a difference!
BoraBora is offline
post #23 of 394 Old 08-28-2013, 08:48 PM
816jared
2005 WK
nice find on the tires. that should look pretty sexy.
816jared is offline
post #24 of 394 Old 09-07-2013, 08:13 AM
ScottHarr_TJ
2010 WK
Get the lift installed yet?! Sounds like is gonna look awesome! Got any more pics of that ORT badge? trying to get one myself for my black WK.
00' TJ-sold
'10 WK
Blue Jeep Club Memeber #132?
ScottHarr_TJ is offline
post #25 of 394 Old 09-07-2013, 08:59 AM Thread Starter
BoraBora
2015 JK Wrangler
I'm scheduled for Wednesday the 11th to get all my parts installed. I'll snap some pics in a bit, but badge really makes the back look sharp.
BoraBora is offline
post #26 of 394 Old 09-07-2013, 01:04 PM Thread Starter
BoraBora
2015 JK Wrangler
Here you go:
Also rocking the Jeep Forum and Aspen Creek decals Installing my Firestik as I type this.
BoraBora is offline
post #27 of 394 Old 09-08-2013, 10:44 AM
ScottHarr_TJ
2010 WK
That looks real good. Hopefully I can snag one of those ort badges. Good lookin jeep man.
00' TJ-sold
'10 WK
post #28 of 394 Old 09-08-2013, 12:57 PM
816jared
2005 WK
just curious, why did you go 5100's vs OME shocks/struts?
816jared is offline
post #29 of 394 Old 09-08-2013, 01:02 PM Thread Starter
BoraBora
2015 JK Wrangler
Thanks man. Means alot.
It was slightly cheaper and the 5100 struts add a .75'' boost even on the lowest setting, which, since I was planning on modding my OME anyways, turned out to be the easier path instead of stacking strut spacers.
BoraBora is offline
post #30 of 394 Old 09-20-2013, 08:02 AM Thread Starter
BoraBora
2015 JK Wrangler
Getting completed by the end of today. Decided against using the 5100 struts up front. It will cause too much stress on the front end parts. So whats going in:
Front: OME HD springs
Rear: OME HD springs, 1.5'' poly spacer, Bilstein 5100 shocks, adjustable sway links, adjustable trac-bar
Should sit with a .5'' rake like BlackedOutWk's Wk. Will post pictures probably tomorrow in the day light.
Also looking to sell the Bilstein 5100 front struts. Brand new in box. PM me if you want them.
BoraBora is offline
