BoraBora build thread - JeepForum.com
post #1 of 394 Old 05-08-2013, 02:56 PM Thread Starter
BoraBora
2015 JK Wrangler
From this:
To this:
Heres what I have so far:
Suspension:
-OME HD
-Bilstein 4600 struts
-Bilstein 5100 shocks
-JBA .5'' strut spacer
-Rear 1.5" poly coil spacer
-Adjustable Trac Bar
-RRO UCA's
-New LCA's
-2" extended rear sway bar links
-Pinch weld mod
Wheels and Tires:
-RC 1.5" Wheel Spacers
-Plasti-dipped JK Moabs
-285/70/R17 Goodyear Duratracs Load Range D
Lighting:
-OEM fogs
-Cree 7W Reverse LED's
-2 Hella 500ff lights behind grill
-20" LED light bar
CB set up:
-Uniden Pro505XL
-3' Firestik Antenna
-Aspen Creek Mount
Armor:
-4xGuard front skid
-OEM front suspension skid
-Tail light guards (LOL)
-SOLID rear differential cover
Exterior:
-ORT and Trail Rated badges
-18% tint all around
-Stingray roof rack
-Trimmed Bumper
-Expanded sheet metal grill
-Black housing headlights
Interior:
-Aux. input.
Recovery:
-OEM front and rear tow hooks
-Tow straps
What's to come:
Snorkel
Winch
Tire carrier
Hidden winch
Hypertech
4:10 gears
Here we go. I bought the Jeep used with 74,000 miles on it for $11,500. It is a 3.7L (boo) and was a 1 owner. Happily snatched it and took it to get a little dirty the first day. 2 weeks later I finally got the humming noise coming from the rear differential checked out by a mechanic. Took it back to the dealership since I still had the 3,000 mile warranty and took them 4 days to replace whatever needed fixing (bearings? pinions?) I went to the local Autozone and found Hella 500ff lights, which I mounted behind the grill. Have yet to wire them up. Removed the front airdam and am now putting all my money into some beefy mud tires.
BoraBora is offline
post #2 of 394 Old 05-08-2013, 04:18 PM
Theogriff15
2006 WK
Nice man! I know that low budget feeling! The trail grapplers should be sweet!
2006 - 3.7L, Superlift, 265 Guard Dogs, 30" LED Bar, Bilsteins, Spidertraxx, Solid, Hypertech, Rola, Rear Led, Led Tails, S4xC Skids
Theogriff15 is offline
post #3 of 394 Old 05-09-2013, 12:14 PM
jeremyc653
2005 WK
Looks good. I know the feeling on the low money to spend on the jeep. Also know how it feels to have lights but not have then wired up.
Build Thread: http://www.jeepforum.com/forum/f67/jeremyc653-build-thread-1423295/#post14245927
jeremyc653 is offline
post #4 of 394 Old 05-13-2013, 01:25 PM Thread Starter
BoraBora
2015 JK Wrangler
Would 275/70/R17 Goodyear Kevlar MTR tires fit my WK with 1.5'' wheel spacers?
255/75/R17
Height: 32.06
Width: 10.04
265/70/R17
Height: 31.61
Width: 10.43
275/70/R17
Height: 32.16
Width: 10.83
Any input?
BoraBora is offline
post #5 of 394 Old 05-14-2013, 05:51 AM
jeep98b
2005 WK
It would probably work as long as you did the pinch weld.
If it aint dirty you aint doin it right
05' WK, OME HD lift w/bilsteins, hypertech
jeep98b is offline
post #6 of 394 Old 05-14-2013, 03:39 PM Thread Starter
BoraBora
2015 JK Wrangler
Alright I've decided I might as well go big or go home. I'm going to go with a 275/70/R17 Goodyear Wrangler MTR with Kevlar (unless I change my mind again) Will keep this thread updated.
BoraBora is offline
post #7 of 394 Old 05-14-2013, 04:32 PM
Whit
1950 CJ3A
Oh yea, I like that attitude! post plenty of pics.
1950 Willys CJ3A, all stock except 33" BFG M/T
2011 black WK2, 5.7L Hemi
Whit is offline
post #8 of 394 Old 06-05-2013, 08:06 PM Thread Starter
BoraBora
2015 JK Wrangler
Just recieved my expanded sheet metal (too lazy to go to home depot) and this stuff seems pretty thick! It's not supposed to bend and form to flush with the grill is it? Because I cannot see this stuff bending. Here is what I ordered: http://www.ebay.com/itm/200828806568...84.m1497.l2649
BoraBora is offline
post #9 of 394 Old 06-05-2013, 10:00 PM
Whit
1950 CJ3A
Mine was the same size but not sure about the thickness. I cut my pieces to size then formed to the proper bend by using my leg to shape the metal. Made the bolt install easier.
Whit is offline
post #10 of 394 Old 06-07-2013, 03:29 PM
Jeepforthewin
2010 JK Wrangler
Have you installed the load levelers yet? Just curious cause I have the RC lift aswell and my back end sits lower. I'm stuck between the wk or the longer f150 ones. I have atleast 70 pounds in my rear cargo hold at all times so wasn't sure if that would put much effect into which one
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #11 of 394 Old 06-07-2013, 10:11 PM Thread Starter
BoraBora
2015 JK Wrangler
So I picked up some aweful scratches yesterday while offroading. It's been raining all day so these are all I've really discovered so far. Does anyone know how I can get rid of these?
BoraBora is offline
post #12 of 394 Old 06-08-2013, 01:35 PM
OhFiveHemi
2005 WK
I made a rookie mistake when i did my expanded grille and im just making sure no one else does the same thing.
Paint the sheet(s) after you cut it to size.
Blue WK Club Member #41
... | `05 WK - HEMI - QDII - Mods | ... | `07 XK - 3.7L - Stock | ...
OhFiveHemi is offline
post #13 of 394 Old 06-08-2013, 02:28 PM
rubiconkid4x4
2007 WK
You could try wet sanding. There are plenty of possibilities to get that out rather than having a body shop repaint, get a dual action buffer, and some compound. Check out larry's videos (ammonyc.com)
2007 WK - 5.7L - QDII
rubiconkid4x4 is offline
post #14 of 394 Old 06-08-2013, 03:03 PM Thread Starter
BoraBora
2015 JK Wrangler
I re-bedlined the rear step pad and wired up my hellas. I also ordered my ORT badge! Will be doing the grill mod sometime this week.
BoraBora is offline
post #15 of 394 Old 06-08-2013, 06:09 PM
BurmaJack
2008 WK
Does the expanded metal come in stainless? IMO that would be the way to go. painted or not, no rust!
'08.5 WK Laredo CRD North Edition; QTII;
Modern Blue Pearl; GDE HOT Tune
Blue WK Club Member #2
BurmaJack is offline
