Black Betty Build Thread - Page 4 - JeepForum.com
 6Likes
post #46 of 159 Old 11-21-2015, 08:32 PM Thread Starter
05BlackWK
2005 WK
Old v.s. New
IMG_20151120_105515733_TOP.jpg   IMG_20151120_104333407.jpg   IMG_20151120_230007413.jpg
05BlackWK is offline
post #47 of 159 Old 11-21-2015, 08:38 PM Thread Starter
05BlackWK
2005 WK
Trying to compress these springs and get them to fit inside was probably one of the hardest things I've done. It really didn't help that the compressors lock pins wouldn't lock because the springs were too wide. So I had to jerry rig it like so each time. It was a pain in the *** to compress them and even more to try and decompress once inside.
post #48 of 159 Old 11-21-2015, 08:41 PM Thread Starter
05BlackWK
2005 WK
Before and after for the front
post #49 of 159 Old 11-21-2015, 08:47 PM Thread Starter
05BlackWK
2005 WK
Wheels and tires are on the way right now. Have an appointment to get them installed Wednesday. Also need to install the rest of the lights and do the pinch weld.
IMG_20151120_093650676.jpg   IMG_20151121_171409391_HDR.jpg   IMG_20151121_171423304_HDR.jpg
post #50 of 159 Old 11-21-2015, 08:50 PM
JakeWK
2005 WK
that's hilarious with the old tires
but really, that's a nice lift man! Looks great can't wait to see the new wheels on
05 WK HEMI
USN Jeep Club
CentralCaL 4X4
Colorado 4X4
JakeWK is offline
post #51 of 159 Old 11-22-2015, 04:09 AM
paroxysym
2007 WK
Check your hub to fender measurements for the front- if you're over 23" then pray that front end settles some.
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #52 of 159 Old 11-22-2015, 07:20 AM
youngPreacher
2006 XK Commander
I don't know, you can see his axle in the front pic, not a horrible angle. No where near as bad as my expedition was when I lifted it. I'm about to replace my RC 2" with Rusty's 2" springs and bilsteins at 3/4" in the front. Hoping to hit 23"on the head
~XKs LEAD THE WAY.~ '06 XK.Hemi.SCT 3872.Modified Rusty's lift
youngPreacher is offline
post #53 of 159 Old 11-22-2015, 07:37 AM Thread Starter
05BlackWK
2005 WK
post #54 of 159 Old 11-22-2015, 07:40 AM Thread Starter
05BlackWK
2005 WK
I measured from the center of the wheel to fender... It was right around 23 so...
post #55 of 159 Old 11-22-2015, 03:08 PM
youngPreacher
2006 XK Commander
so OME HD with 5100@2" nets you 23": seems like almost every other thread says that would be way too much . Hmmm
post #56 of 159 Old 11-22-2015, 03:31 PM
paroxysym
2007 WK
Agreed. The OME HD springs alone on a 3.7 should have put you at or a hair under 23"
OEM+
post #57 of 159 Old 11-22-2015, 04:10 PM
youngPreacher
2006 XK Commander
Apparently it worked?
post #58 of 159 Old 11-22-2015, 07:47 PM Thread Starter
05BlackWK
2005 WK
Yes the Bilsteins were set a 2. I measured from the very middle of the wheel and it was right around 23. I'll check again later. But I'm pretty sure it was at 23 give a half inch either way
post #59 of 159 Old 11-22-2015, 07:53 PM
eMc9002
2007 WK
Seem's like you would be over 23" with it set at 2", most who set the 5100's to .75" come out to 22.75" hub measurement.
07 WK 4.7L V8 Limited l Flowmaster 44 l Spidertrax 1.5" l JK Moab's l Black WK #137.
eMc9002 is offline
post #60 of 159 Old 11-23-2015, 08:32 AM
youngPreacher
2006 XK Commander
Interesting...must have something to do with geometry, or a broken tape measure.lol if it is true tho, I have to rethink my lift next month
