bilstein 5100 vs MLL - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > bilstein 5100 vs MLL
**Flash Weekend Sale** Rockridge4wd.com Only!RIGID LED Light Blowout Sale - All Sizes, All Series, all Jeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06
Unread 08-23-2015, 02:40 PM   #1
Rebnx
Looking at ordering the modified ome off crawl. Just curious will the bilstein 5100 in rear give me more lift then my f150 MLL? If not I'll just order HD rear coils with the fronts and bilstein strut. Already have the rc spacers.
Rebnx is online now   Reply With Quote Quick reply to this message
Unread 08-23-2015, 08:13 PM   #2
Kolak
Vendor
Kolak's Avatar
What precisely is "modified" about this setup? Which front Bilsteins are you getting, 4600 series or 5100 series?
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
kolak@aol.com or kolak@kolakperformance.com
Kolak is online now   Reply With Quote Quick reply to this message
Unread 08-24-2015, 04:10 AM   #3
caulk04
2008 WK
The only rear shock that will give you any lift is the MLL because it has a spring on it. They're also a cheap shock so...
IMO, get a good shock (Bilstein) and use stiffer springs or spacers to get your lift.
08 5.7 Limited WK - Basic stuff...
caulk04 is offline   Reply With Quote Quick reply to this message
Unread 08-24-2015, 04:13 AM   #4
paroxysym
2007 WK
agreed... youll end up pulling the MML out within months of install to fix the rubber sleeve on the shock, which most have to glue and duct tape to fix it... which the fix will eventually fail and youll have to fix it again.
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline   Reply With Quote Quick reply to this message
Unread 08-24-2015, 07:21 PM   #5
Rebnx
Originally Posted by kolak View Post
what precisely is "modified" about this setup? Which front bilsteins are you getting, 4600 series or 5100 series?
5100.
Unread 08-25-2015, 12:06 AM   #6
Kolak
Vendor
Kolak's Avatar
Your putting 5100 series front struts together with OME springs up front? With which version of OME spring - MD or HD?
What year/engine size is your WK? What engine do you have?
Originally Posted by Rebnx View Post
5100.
Unread 08-25-2015, 05:29 AM   #7
Rebnx
HD 06 Hemi
Unread 08-25-2015, 12:30 PM   #8
Kolak
Vendor
Kolak's Avatar
I know some of done this, but given the 3" lift of the OME HD coils and the minimum .75" setting of the Bilstein 5100 series struts, since sounds like a geometry nightmare waiting to unfold. What size tires are you going to install?
HD 06 Hemi
