Bilstein 5100 series strut - Page 8 - JeepForum.com
 1Likes
post #106 of 350 Old 10-19-2013, 05:35 PM Thread Starter
ca07wk
2007 WK
I wouldnt use that kind of strut compressors, better to find a shop with a wall mounted compressor to use
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #107 of 350 Old 10-21-2013, 09:16 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Depends on the compressor. I have used a cheap set ($20) with snapped on me and I have used a more expensive set ($50) which have held up great over the years even multiple times on my OME HD coils.
Omelet is offline
post #108 of 350 Old 10-21-2013, 10:12 AM
overland-wk
2006 WK
I use the same spring compressors
06 ROR lifted wk (mine)
07 RC lifted xk (wife's)
Youtube channel
Bumsmodified98xj
overland-wk is offline
post #109 of 350 Old 10-21-2013, 02:47 PM
Kolak
Vendor
Kolak's Avatar
Just out of morbid curiousity, what happened when the cheap set snapped? Is the coil spring still orbiting the Earth?
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #110 of 350 Old 10-22-2013, 06:51 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Haha, not quite! The hook snapped off the end, didn't exactly fly into the sky but it did slide across the room.
Omelet is offline
post #111 of 350 Old 10-24-2013, 08:46 PM
marcram
2008 WK
Another mechanic quoted me two hours, then raised it to 3 after he realized the fuse box and coolant tank had to be removed. Was tired of mechanic hopping, so got them installed. Haven't seen anyone else go from stock to 1.5 inch lift. I really like the new feel of the jeep. Bilsteins in the back have enough lift loo make practically level. A modest, but noticeable change from stock for me.
http://www.jeepforum.com/forum/f67/1...8-crd-1723162/
marcram is offline
post #112 of 350 Old 10-29-2013, 12:59 PM
Chadwi
2007 WK
I got the 5100's yesterday, thanks Kolak. I am going to try them at the .75 setting with a 2" Rough Country lift. Hopefully I can get it done this weekend!
Chadwi is offline
post #113 of 350 Old 11-02-2013, 12:59 PM
0321Nick
2006 WK
Hmmm. Maybe if RRO bust out a new hidden winch mount or bumper for the WK I will have to get these to offset the weight of the winch.
Right now I'm running OME HD with a Rusty's 1/4" spacer up front, but with something like this, I could drop the 1/4" spacer and just use the Bilsteins to get back where I was + any increase in weight from a winch, etc.
This is especially tempting since I'm about 2000 miles away from 100,000 and I had my OME installed around the 50,000 mark . . . it might be time for some new shocks anyways.
KHAKI CLUB #65
2006 WK 4.7L V8 - Modified OME HD with Bilstein 5125s (28" length); JBA UCA; JKS Rear Discos; K&N CAI; PowerStop Discs; HyperTech; TOYO Open Country AT IIs 285/70/17; + some other goodies
0321Nick is offline
post #114 of 350 Old 11-19-2013, 09:41 AM
fredkiller
2008 WK
So I had my Jeep dealer put these struts together for me (bought new upper mounts, isolators, and jounce bumper so I could have it preassmebled), but I'm not sure its done quite right... based on the instructions I found for installing the the OME lift on a commander, the top mount is definitely not aligned correctly (looked at this after getting them back from the shop), but I'm also wondering about the lower perch? being as its not welded on, how should it be aligned? I see what looks like a "pilot" hole on the lower perch, that I'm assuming should align with the strut tab? The FSM indicated that there is an alignment hole on the upper mount that should be 180* from the tab, but that is definitely wrong based on the install writeup. I need to get it back to them to correct, and want to make sure I'm explicit with my instructions.
Thanks for any insight!
2008 Jeep Grand Cherokee Overland Modern Blue, 3.0L CRD
Current mods: ARB Winch Bumper, TABOR 9K Winch, OME HD, Bilstein 5100 front and back, AEV JK Pintlers w/P265/70/17 GY Wrangler Silent Armor
Pending upgrades: pinch weld?
fredkiller is offline
post #115 of 350 Old 11-19-2013, 05:43 PM
candyman85
2007 WK
Great thread.
Looking for some advice for my 2007 Jeep Grand Cherokee Limited, 5.7 L Hemi with QDII.
Current setup: Stock coils, RRO 2.25" BB spacer rear/front, OME HD Front Struts, RRO rear shocks (not much info on these rear shocks at the moment).
I'm not happy with the handling of my shock/strut setup, and the front OME HD struts seem very noisy compared to when my vehicle was stock (not sure if it's that, or the coil/spacer mix, etc). Sounds clunky and very "squishy" sounding from the front.
Idea 1. Keep RRO spacers all around, put in Bilstein HD shocks/struts, stock coils (possibly XK hemi coils up front down road for winch weight - will this raise height of front?)
Idea 2. Remove RRO spacers all around, put in Bilstein HD shocks/struts with OME HD coils all around. (assuming OME HD coil can handle weight of winch)
Any advice on which option? I feel I am turned off the OME shocks/struts...but perhaps my setup is just incorrect.
Also, keeping in mind the below, would you recommend the Bilstein HD shocks/struts or the Bilstein 5100 shocks/struts? (what would be better for what I'm doing?)
-I tow a small camp trailer (likely a bigger one in the future)
-Mainly city/hwy driving with mild-medium off-roading - this is my daily driver....hopefully 100% trail rig in the future...
Also, does anyone know the coil spring weight rating of the front 2007 Jeep Grand Cherokee Limited with Hemi/QDII? I am trying to compare this to the XK Hemi front coil rating of around 600lb's - need to know for when I install my hidden front winch mount + winch...if I actually need to change my stock front coils.
Sorry this was long, I did my lift the 1st time not being 100% happy, don't want to make that mistake the 2nd time. Looking for recommendations from some fellow lifted WK's out there.
Thanks!
candyman85 is offline
post #116 of 350 Old 11-19-2013, 07:32 PM
zc911
I think i know what you are saying. The tab sticking out of the bottom of the shock slots into the lower fork, and you are worried the top hat is not aligned properly for the studs to line up with the holes in the body and that tab to line up with the lower fork.
If so, don't sweat it. When you go to install the new strut assembly, put the top hat studs into the body holes and you can twist the strut body to align the tab for the lower fork
zc911 is offline
post #117 of 350 Old 11-24-2013, 09:46 PM
BlackNMWK
2008 WK
Has anyone tried these with the Superlift strut spacer? I was wanting to do this should get about 5 to 5.5 inches of left??
BlackNMWK is offline
post #118 of 350 Old 11-24-2013, 09:59 PM Thread Starter
ca07wk
2007 WK
We use that for the modified Superlift. OME HD coil and 5100 strut set at 1.5" spot.
ca07wk is offline
post #119 of 350 Old 11-25-2013, 05:33 AM
sk1er18
2007 XK Commander
And not using the superlift spacer? Sounds like that would greatly limit the suspension droop of the superlift setup. Remember the OME, 5100, spacer, etc type lifts gain height at almost a 2:1 factor since the control arm is being pivoted for the lift. The superlift drops everything down 4" and maintains a flat control arm angle. To get full range of suspension travel with the superlift you want a strut setup that is overall ~4 inches longer than the stock strut at full extension.
Thats why im making a spring that has the OME HD spring rate but will only provide 1-1.5" lift with the 5100s on their lowest setting and using that with the SL spacer for my modified superlift setup.
-Matt
sk1er18 is offline
post #120 of 350 Old 11-26-2013, 11:23 PM
BlackNMWK
2008 WK
Cool thank you. I have the OME HD 2inch lift with the superlift strut space right now rides real rough for me.. I was going to try the Bilstein 5100's at the 2inch setting with my stock springs. Long as I can clear the 35's I should be ok. as it sits now I have room to fit 37's. Does anyone see any issues I might run in to?? Thank you.
