Bilstein 5100 series strut - Page 7 - JeepForum.com
 1Likes
post #91 of 350 Old 10-10-2013, 12:15 PM Thread Starter
ca07wk
2007 WK
Originally Posted by jjarvis0007 View Post
Thanks.
Will the Bilsteins work with the air bags in the rear?
the Bilsteins install in the factory location, I dont see why they wouldnt.
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #92 of 350 Old 10-10-2013, 01:25 PM
jjarvis0007
2005 WK
I guess I'll set the front struts at 2" for a level ride?
jjarvis0007 is offline
post #93 of 350 Old 10-10-2013, 02:05 PM Thread Starter
ca07wk
2007 WK
Yes, I think you will achieve a more level stance then if you installed a spacer lift like RC, RRO, or Daystar. I had to use 4 rear coil isolators on each side to make my WK look level with the RC lift.
ca07wk is offline
post #94 of 350 Old 10-10-2013, 02:32 PM
marcram
2008 WK
I ordered a pair of 5100 adjustable front struts. Anyone know how much I should expect to have them installed? Someone else recommended Pep Boys as this should be hard to mess up.
marcram is offline
post #95 of 350 Old 10-10-2013, 03:05 PM Thread Starter
ca07wk
2007 WK
According to Alldata, the labor is 2 hours for both front struts. Price will depend on how much the shop charges for labor/hour
ca07wk is offline
post #96 of 350 Old 10-10-2013, 04:37 PM
marcram
2008 WK
Good to know. Thanks!
marcram is offline
post #97 of 350 Old 10-18-2013, 10:27 AM
JTL13
Bilsteins
Hey everybody, new member, first post. Has anyone got any new info on these ride height adjustable 5100's. I was wondering how they are working out and the actual lift you ended up with? None of the spring shops and 4X4 shops in my area ( Windsor Ontario , Detroit Mi.) have even heard about these, and want to sell me a BB, probably because that is what they are used to. Will fill out sig when I have more time, but I have a 05 GC Limited, Hemi. If these are working out I will probably just order from Q-Tec and do it myself. Thanks in advance for any help. JT.
JTL13 is offline
post #98 of 350 Old 10-18-2013, 11:07 AM
Chadwi
2007 WK
I am planning an install of the 5100 adjustable and a Rough Country lift. We'll se what happens. I wanted to try them with the stock springs to see how it rides. I had OME on my JK and thought they were a little firm. To purchase parts, contact Kolak, he has good prices and a wealth of knowledge.
Chadwi is offline
post #99 of 350 Old 10-18-2013, 11:11 AM Thread Starter
ca07wk
2007 WK
If your set on a BB get the 5100 struts and a 2" Rustys rear spacer. If your not set then consider saving a little longer and going OME. As for the firmness of OME coils they offer a medium duty set that is a little softer. You can save quite a bit by getting the OME coils and Bilstein shock/struts.
ca07wk is offline
post #100 of 350 Old 10-18-2013, 03:34 PM
Flyboys
2015 JK Wrangler
These adjustable 5100's have been around awhile. I had them on another truckk 2 years ago. Lot of Ram's Tundra's using them. I have had them on my WK now for about 2000 miles and LOVE them. The ride is super nice in city and highway. Also off road twice (beach) with them and all good thee too. Would but them again no question. I have also added new fron sway bar bushing and front and rear BWoddy sway bar links which has helped the ride on cornering and on and off ramps.
2015 Willys JKU
2014 Ram CC Sport
Flyboys is offline
post #101 of 350 Old 10-19-2013, 11:26 AM
marcram
2008 WK
Just received my front struts. Called a few places to get quotes for installation. Pep boys said $305, another shop gave a $200 quote, and another 2 hour quote. After they looked at jeep service manual, said it looked like a 4 hour job and wanted to charge $400 for install. Is the install on the wk really that much work? Was expecting to pay for 2 hours. Any advice?
marcram is offline
post #102 of 350 Old 10-19-2013, 11:33 AM
Flyboys
2015 JK Wrangler
$150 -200 at my local shop here in NJ
2015 Willys JKU
2014 Ram CC Sport
Flyboys is offline
post #103 of 350 Old 10-19-2013, 11:34 AM Thread Starter
ca07wk
2007 WK
Should only be 2hr of labor.
ca07wk is offline
post #104 of 350 Old 10-19-2013, 11:45 AM
zane870
2008 WK
I hope to by putting mine in next weekend!
2008 WK Cherokee Laredo 4x4 (Mine)
2011 KK Liberty Jet Edition (Wife's)
zane870 is offline
post #105 of 350 Old 10-19-2013, 04:45 PM
longboy
2006 WK
How bad is the install to just do it yourself? I mean, get some strut compressors on loan from Autozone and spend a couple of hours in the garage? Get it aligned after, but I can't imagine the install is that bad to DIY.
2006 5.7l WK
longboy is offline
