Bilstein 5100 series strut - Page 5 - JeepForum.com
 1Likes
post #61 of 345 Old 09-26-2013, 02:24 PM
Flyboys
2015 JK Wrangler
Originally Posted by ca07wk View Post
I dont think itll compress the spring much more then it is now, your just raising the lower spring purch makng the spring sit higher up on the strut body. I would try the Bilstein set to 2" without the spacer first.
But wouldn't the spring be compressed at least another inch?
2015 Willys JKU
2014 Ram CC Sport
Flyboys is offline
post #62 of 345 Old 09-26-2013, 02:46 PM
zc911
no the cup the spring sits in gets moved up and the shock just extends further out
zc911 is offline
post #63 of 345 Old 09-26-2013, 03:13 PM
sk1er18
2007 XK Commander
The shock doesnt get extended.
Raising the lower perch adds preload to the spring. Its just like adding a coil spring spacer in the assembly. Fully extended length of the assembly remains constant.
-Matt
sk1er18 is offline
post #64 of 345 Old 09-26-2013, 03:25 PM
zc911
i thought the extended length would have jsut increased
zc911 is offline
post #65 of 345 Old 09-26-2013, 03:28 PM
sk1er18
2007 XK Commander
It doesnt.
Fully extended length stays the same. Move spring perch up = add preload to spring = lift.
One of the benefits that Bilstien touts is that these dont hyper extend the front end at full drop.
-Matt
sk1er18 is offline
post #66 of 345 Old 09-26-2013, 09:14 PM
sunrcr69
2005 WK
Read up
http://www.bilsteinus.com/fileadmin/...WebArticle.pdf
Preload is not added to the spring when it is adjusted to the higher settings. The shock has longer than stock travel therefore the whole assembly gets longer = lift.
2005 WK 5.7L Hemi, RC 2" BB + fabrication = 3.5" lift, JK Rubicon Tires & Wheels, 1.25" Spacers, Fabricated Skidplate, Fabricated Recovery Points, Airaid CAI, Superchips, HIDs RED WK Club #10
sunrcr69 is offline
post #67 of 345 Old 09-26-2013, 09:29 PM
sk1er18
2007 XK Commander
Originally Posted by sunrcr69 View Post
Read up
Well it looks like we're both partially wrong
First and foremost- the strut is longer than stock by 1/2-3/4" (cool stuff, glad to see ).
It also increases pre-load. The fully extended length is the same regardless of which "setting" its on. It doesn't get any longer whether its on its lowest setting vs its highest setting.
The brochure you linked even details how the rebound valving of the 5100 is specifically designed to account for the additional preload (whereas throwing a coil spacer in a stock assembly isn't ideal).
-Matt
sk1er18 is offline
post #68 of 345 Old 09-26-2013, 09:37 PM
sk1er18
2007 XK Commander
Here's a good visual that'll help show you how/why pre-load is added to achieve lift (its for the 5100s but a different application that has a few more settings).
-Matt
sk1er18 is offline
post #69 of 345 Old 09-26-2013, 09:55 PM
sunrcr69
2005 WK
From the article - "Bilstein 5100 Series Leveling Shocks are longer than the O.E. shocks by 1/2” to 3/4”, depending on application. Now when the ride height of the
vehicle is increased by 2”, the Bilstein 5100 Series Leveling Shocks offer additional droop. By maintaining the factory up-travel, this combines for an
increase in overall wheel travel. The result is the lift you’re looking for - along with a great ride."
It says it maintains the factory uptravel. How would that be possible if there is preload on the spring?
Preload on the spring = less travel due to the spring being partially compressed. The spring would bind if compressed the same distance as stock while preloaded.
sunrcr69 is offline
post #70 of 345 Old 09-26-2013, 09:58 PM
sk1er18
2007 XK Commander
No, additional preload on the spring doesnt equate to less up-travel.
There is still plenty of compression left in the spring, even when pre-loaded.
I'm not sure how else to explain it without a scratchpad (and some beers), but if you've ever assembled a strut you'd know that moving the lower perch upwards will result in spring preload. It doesn't magically add more travel... there's already enough preload on the spring that the strut extends to its max position without any load/weight on it.
-Matt
sk1er18 is offline
post #71 of 345 Old 09-26-2013, 10:26 PM
sunrcr69
2005 WK
I get it (and I've assembled 1000s of struts/coilovers). You are right, there is preload added, but not enough to get coil bind.
I would need the same scratchpad and more beers to explain my original theory
sunrcr69 is offline
post #72 of 345 Old 09-26-2013, 10:30 PM
sk1er18
2007 XK Commander
nothing like talking about jeeps/suspension/mods over a few beers! It's possibly one of the best parts of this type of hobby
-Matt
sk1er18 is offline
post #73 of 345 Old 09-27-2013, 07:10 AM
Flyboys
2015 JK Wrangler
Well think I'm gonna just take out the RC 2" spacer lift in the front and then adjust the Bilsteins too 2" and call it a day. Hope to report back later tonight on tomorrow.
2015 Willys JKU
2014 Ram CC Sport
Flyboys is offline
post #74 of 345 Old 09-27-2013, 08:20 PM
onlyone
onlyone's Avatar
2014 JK Wrangler
I am having the 5100's installed with a 1.5 inch spacer in the back along with the rear 5100's on Thursday of next week. I will post up some pics and let everyone know how they ride when done.
Thank you Jesus
2014 Wrangler Sport 1.5" spacers in front .75 rear, 1" BL 255/80/17 BFG KM2
onlyone is offline
post #75 of 345 Old 09-28-2013, 04:47 PM
Flyboys
2015 JK Wrangler
Took out the 2" RC spacer in front and adjusted the Bilsteins to max 2". Also still have the RC" spacer in rear with rear Bilstein 5100's as well. Put a 8mm spacer up front. Love it! The ride is awesome, very pleased!
2015 Willys JKU
2014 Ram CC Sport
Flyboys is offline
