Bilstein 5100 series strut - Page 2 - JeepForum.com
 1Likes
post #16 of 342 Old 06-01-2013, 09:21 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Originally Posted by sk1er18 View Post
When I measured it side-by-side the stock strut, the OME was 5/16 (~.3") longer fully extended.
I'm not sure exactly what reference point they use to measure the fully extended/compressed lengths, but if they use the top of the fork bracket on the strut to the seat of the strut mount, I measured right around 19-19.25" on the OME (it was hard to get an exact figure)
Ok thanks!
Can someone post the specs for the Bilstein HD struts for comparison?
Omelet is offline
post #17 of 342 Old 06-01-2013, 10:32 AM
Jvenrick
2007 WK
So these can work along with an rc spacer lift right? Just need to be mindfull of the cv axels.
2007 Grand Cherokee Rocky Mountain Edition: 4.7L V8- QTII- Green
The build:
Jvenrick is offline
post #18 of 342 Old 06-01-2013, 10:47 AM Thread Starter
ca07wk
2007 WK
Originally Posted by Omelet View Post
Ok thanks!
I post the HD struts in the first post
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #19 of 342 Old 06-01-2013, 10:51 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Haha, that's right you did! Thanks!
Omelet is offline
post #20 of 342 Old 06-02-2013, 02:10 PM
zeds_dead
2005 WK
So in other words, these can be used in a modified OME setup and would be the equivalent of using Rusty's strut spacer if they are turned down all the way?
Everyday, something new you want to do. Disease of Jeeps.
zeds_dead is offline
post #21 of 342 Old 06-02-2013, 06:41 PM
BlackNMWK
2008 WK
I have the modified OME set up would this be better then what i have now and would i need new springs? Thanks.
BlackNMWK is offline
post #22 of 342 Old 06-02-2013, 06:42 PM
paroxysym
2007 WK
Or say I run a XK hemi coil in the front with a rusty strut spacer, I'd set these to the 1" position to accommodate the added height or would setting them to the 1" setting add to the 3/4"-1" I'm gaining from the XK hemi coil and strut spacer?
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #23 of 342 Old 06-02-2013, 06:48 PM
BlackNMWK
2008 WK
Would you get more travel with this strut vs the OME strut and coil??
post #24 of 342 Old 06-03-2013, 01:10 AM
BlackNMWK
2008 WK
Would it be better to use the stock spring vs the OME spring its not modified, would it over extened the strut? Thanks
post #25 of 342 Old 08-10-2013, 08:19 PM
Williker
2006 XK Commander
OK, so you throw a set of these on the front and set them to 2", what would be the best way to go for the rear? An OME Med set of 2" springs? I do tow a trailer so would the HD's workout better or end up a little too stiff with the stock front coils?
Williker is offline
post #26 of 342 Old 08-11-2013, 02:09 AM
Kolak
Vendor
Kolak's Avatar
I spec a longer 5100/5125 set for the rear and then you can either get springs or a set of rear spacers depending on budget.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #27 of 342 Old 08-11-2013, 07:35 AM
sk1er18
2007 XK Commander
Since you're towing i would definitely go with the OME HD's.
There's a lot of shock options for the rear. Are you planning on doing any offroading? If so, there's a few minor modifications and you can run rear shocks up to 28" long to maximize travel.
-Matt
sk1er18 is offline
post #28 of 342 Old 08-12-2013, 06:25 AM
BoraBora
2015 JK Wrangler
The 5100's adjusted all the way down still give 3/4" boost? I'm putting these in with my modded OME HD and I'm trying to maintain a .25" inch rake...so I guess I'll have to add some extra coil isolators along with the rear 1.5" puck?
'15 JK 2.5" lift on 35's
'06 WK 3.5" lift on 33's (Sold)
BoraBora is offline
post #29 of 342 Old 08-12-2013, 07:38 AM
sk1er18
2007 XK Commander
You'd be better off getting JBA 4" springs instead of OME HDs for the rear. Or see if someone has some used superlift springs for sale.
-Matt
sk1er18 is offline
post #30 of 342 Old 08-12-2013, 08:17 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
I have a set of SL coils sitting in my garage if anyone is interested. They had me at a 23.5" hub - fender measurement when they were in.
Omelet is offline
