Bilstein 5100 series strut - Page 14 - JeepForum.com
 1Likes
post #196 of 350 Old 02-19-2014, 03:10 PM
Jeepforthewin
2010 JK Wrangler
Originally Posted by ChiliPepperXJ View Post
X2, think this is the way to go, with the assumption that the hub-fender stays under 23". Just don't know whether to go HD or MD on the coils. Hoping someone out there has some feedback on that.
With the Hemi you will most likely want the HD coils.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #197 of 350 Old 02-19-2014, 03:18 PM
ChiliPepperXJ
2006 WK
Thanks for the feedback, was definitely leaning that direction. Just wanted to get opinions before pulling the trigger
ChiliPepperXJ is offline
post #198 of 350 Old 02-19-2014, 03:55 PM
Chadwi
2007 WK
Go with MD. See my SIG. I have been happy with my set up. Only difference would be the Rusty's spacer, which is a good option.
2007 WK CRD, Bilstein 5100's set at .75" RC rear spacer, OME MD springs F/R. At 22" front 23" rear hub to fender. JBA control arms, 1.25" Spidertrax spacers, Fierce Attitude MT's, 4XGuard front skid, Full LED interior swap, 9012 low, 9011 high/driving light bulb swap. Swirl motor resistor mod, Front pinch weld mod...
Chadwi is offline
post #199 of 350 Old 02-19-2014, 05:02 PM
ChiliPepperXJ
2006 WK
Perfect! You have any pictures of this beast?!
The only thing I would be concerned about is the extra weight of your CRD versus my Hemi.
post #200 of 350 Old 02-19-2014, 07:21 PM
fafafofi
2006 WK
Hemi
Md coils up front in .75" setting bilstein 5100s and Rustys strut spacer - 22.5"
HD coils in rear bilstein 5100s no spacer but in future plans - 21.5"
285 Duratracs
fafafofi is offline
post #201 of 350 Old 02-19-2014, 07:21 PM
Chadwi
2007 WK
Go to page 11 of this thread for pics. I have read that the hemi and crd are really close in weight. I am at 22" if the hemi is a little lighter I doubt you would be above 23". Should be perfect.
Chadwi is offline
post #202 of 350 Old 02-19-2014, 08:01 PM
WH-HEMI
The HEMI is heavier than the CRD, these are the stock figures:
CRD - 4652 lbs
HEMI - 4740 lbs
2005 WH Jeep Grand Cherokee 5.7 HEMI
WH-HEMI is offline
post #203 of 350 Old 02-19-2014, 08:11 PM
ChiliPepperXJ
2006 WK
Originally Posted by fafafofi View Post
Attachment 1102137
Hemi
285 Duratracs
It looks great man, thanks for the pic! You should definitely look at getting the rear spacer in to top it off..
CRD - 4652 lbs
HEMI - 4740 lbs
Did not know this. Actually thought it was the other way around. Thanks for the info.
Will all this being said, and seeing this image, think I will follow what fafafofi did, rather ditch the front spacer, and do HD coils instaed of MD
post #204 of 350 Old 02-20-2014, 06:03 AM
fafafofi
2006 WK
Thanks man. Spacer will be added when it warms up. Possibly switch out the springs or adjust them when I get my hidden winch mount installed.
fafafofi is offline
post #205 of 350 Old 02-20-2014, 11:37 AM
Chadwi
2007 WK
Here is a pic of mine.
Chadwi is offline
post #206 of 350 Old 02-20-2014, 11:38 AM
Chadwi
2007 WK
..and another angle..
Chadwi is offline
post #207 of 350 Old 02-21-2014, 07:23 AM
08GC21
2008 WK
As I've been looking through these posts it seems like most of you use the 5100 series with some sort of spacer or lift. I do have a question, and if it has been answered through here I apologize and please point me in the right direction..
I'm looking at just leveling out the front of the Jeep, not necessarily looking for a lift here. First of all, will the 5100's accomplish this, and if so, what setting would bring the front level with the rear. Currently no suspension modifications.
08GC21 is offline
post #208 of 350 Old 02-21-2014, 07:24 AM
BoraBora
2015 JK Wrangler
Yeah they will level it. At the lowest setting you get .75" and that's all you need to level it.
'15 JK 2.5" lift on 35's
'06 WK 3.5" lift on 33's (Sold)
BoraBora is offline
post #209 of 350 Old 02-21-2014, 07:47 AM
paroxysym
2007 WK
like bora said you could go with the .75" or from what ive seen you could also go 1.5" in the front and add a 4600 bilstein to the rear for a boost as well to level out with the 1.5" setting
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #210 of 350 Old 02-21-2014, 08:01 AM
DVB
2006 WK
So he'll have a leveled 1.5" lift?
2006 4.7 Limited QD II, Stock
DVB is offline
