Bilstein 5100 series strut - Page 12 - JeepForum.com
 1Likes
post #166 of 350 Old 01-15-2014, 10:07 AM
ecollins7
2006 WK
Lol thanks for the quick response
ecollins7 is offline
post #167 of 350 Old 01-15-2014, 10:49 AM
pancake
2005 WK
No problem!! Class = boring hahahah Going through the planning phase of my lift so I've been doing a lot of research
05 Jeep WK Laredo 4.7L QTII | K&N CAI | Flowmaster 40 | ...lift and such in planning phase...|
pancake is offline
post #168 of 350 Old 01-15-2014, 11:22 AM
paroxysym
2007 WK
Originally Posted by ecollins7 View Post
Right now I have the day star lift with bilstein 4600 on all four corners. I want to get rid of the daystar so after speaking with kolak, I'm looking at going with ome hd springs all the way around with the 5100 in the rear and keeping the 4600 up front. What setting should I put the 5100 at for 3 inch lift?
check out boraboras build thread, he just did this, as did the chadwi. its the new version of the modified OME- bilstein 5100s in the front and a 2" spacer in the rear, gets you close to 23" in the front and closer to 24" in the rear.
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #169 of 350 Old 01-15-2014, 11:35 AM
pancake
2005 WK
He doesn't have 5100s in the front. He has ome spring and oem strut in the front and ome spring, 5100 shock, and coil spacer in the rear. I plan on doing as you described though when I order my lift in the spring
pancake is offline
post #170 of 350 Old 01-15-2014, 11:37 AM
ecollins7
2006 WK
I'm looking to do the opposite, 5100 in the rear with ome hd springs and 4600 in the front with ome hd springs
post #171 of 350 Old 01-15-2014, 11:39 AM
pancake
2005 WK
This is an awesome option. That's the setup Chris (from crawl offroad) is running. I just am looking for a little more height than the regular ome setup
pancake is offline
post #172 of 350 Old 01-15-2014, 12:41 PM Thread Starter
ca07wk
2007 WK
Yep, that's my setup! Love it over the RC spacers I used to have.
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #173 of 350 Old 01-15-2014, 12:54 PM
pancake
2005 WK
Do you know your hub to fender measurements (front and rear) if not that's okay, I'm just trying to do as much research as possible and take into account ALL of my options before I start buying parts. Thanks
Parker
pancake is offline
post #174 of 350 Old 01-15-2014, 01:25 PM
modernblueWK
How do the 5100's do to stiffen up the rear suspension. Mine feels like it bottoms out all the time with 3 adults in the jeep and a 40 pound dog in the back. I was looking at the strut spacer/leveling spacer but my shocks feel a little worn for my taste at 68k miles. I'm thinking about the middle setting on the front 5100's. If I want it level what do I need in the rear?
Would a set of MLL's be a good solution to stiffen up the rear suspension?
Thank you
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #175 of 350 Old 01-15-2014, 01:47 PM
pancake
2005 WK
You could go with 5100s out back too or 4600 (the stock replacement). The 1.5 setting up front would level the jeep out to actually make the jeep "level" so you can do one of those if that's the look you want. If you want your jeep to "level" out back to the stock rake after installation of the 5100s up front then yes you could go the mll route or a spacer such as the bds (at 1.5") or rough country if you want 2" (if you prefer a metal spacer). If you want a poly spacer than rustys, daystar, etc. would work too
Parker
pancake is offline
post #176 of 350 Old 01-15-2014, 05:11 PM Thread Starter
ca07wk
2007 WK
Parker
22.75 Front and Rear
ca07wk is offline
post #177 of 350 Old 01-15-2014, 05:12 PM Thread Starter
ca07wk
2007 WK
Thank you
Thats the stock coils, they are garbage. Save up and get one of the OMEs MD or HD, you'll have alot less coil sag and way better handling
ca07wk is offline
post #178 of 350 Old 01-15-2014, 06:50 PM
paroxysym
2007 WK
How do the 5100's do to stiffen up the rear suspension. Mine feels like it bottoms out all the time with 3 adults in the jeep and a 40 pound dog in the back. I was looking at the strut spacer/leveling spacer but my shocks feel a little worn for my taste at 68k miles. I'm thinking about the middle setting on the front 5100's. If I want it level what do I need in the rear? Would a set of MLL's be a good solution to stiffen up the rear suspension? Thank you
The MLLs will stiffen up the rear and give you a bit of no lift and a rake- but will ride horribly. If it were me- aside from doing OME coils, I'd hunt down some XK rear coils and throw some Bilstein 4600s in the rear.
OEM+
post #179 of 350 Old 01-15-2014, 08:28 PM
pancake
2005 WK
Thanks!! What I needed to hear. Just three quick questions for you:
1) What engine do you have?
2) Is everything settled?
3) what's the height difference (hub to fender) between the 4600 and 5100 on the lowest setting once everything is settled?
Thanks
Parker
pancake is offline
post #180 of 350 Old 01-15-2014, 09:11 PM Thread Starter
ca07wk
2007 WK
I have the 3.7L with HD coils, everything's settled, it has about 5000 miles on this set up. The 5100 adjustable strut adds .75" of lift up front.
ca07wk is offline
