Bilstein 5100 series strut - Page 11 - JeepForum.com
 1Likes
post #151 of 345 Old 12-26-2013, 08:34 PM
Jvenrick
2007 WK
Originally Posted by Chadwi View Post
RC lift and 5100's are a no go. I tried, that setup has way too much down travel.
To much down travel for what? Cv's, brake lines, uca's?
2007 Grand Cherokee Rocky Mountain Edition: 4.7L V8- QTII- Green
The build:
Jvenrick is offline
post #152 of 345 Old 12-27-2013, 06:47 AM
Chadwi
2007 WK
CV's boots rub on knuckle, spring seat hits knuckle and it looked like the steering tie rods bind at full droop. I drove it to and from the shop to get my tires mounted. It sat right at 23", but at full droop it looked expensive with all the contact and that's with the JBA arms. It would work with limit straps, but I would not want to rely on straps to keep from damaging all of the other parts. I think you could add some down travel by either using a few washers stacked on the stem of the strut or using the 1/4" spacer on top of the strut cup. I want to get it back on the road, I have had it apart three times now. I figured the OME guys have been running the stock length setup with success and the 5100's already add about 3/8" to the strut.
Chadwi is offline
post #153 of 345 Old 12-27-2013, 10:29 AM
Jvenrick
2007 WK
Thanks a lot for the info!! I guess my new question is, would keeping the rc lift and getting the bilstein hd struts or removing the rc lift and getting the 5100's and the rusty spacer be a better way to smoth out the ride and get the front to 22.5?
The build:
Jvenrick is offline
post #154 of 345 Old 12-30-2013, 06:44 AM
Chadwi
2007 WK
It's done! I installed the OME MD springs front and rear. The 5100's are set at .75" in front and I used the RC spacer in the rear. I am setting at 22" in front and 23" in the rear. I also welded a 2" steel coupling to the rear spacer to extend the bump stop. I did not like the way the stock isolator fit, it was loose around the coupling. I made a 1/4" spacer with a sleeve to fit between the coupling and the spring from a poly JK spacer I had. The ride is firm but not harsh. My wife even commented that it rides better, she got car sick with the mushy stock ride. It is freaking cold out, -9. I will work on getting some pics as soon as I can. Thanks guy's for sharing your knowledge and experiences, it helped a lot.
Chadwi is offline
post #155 of 345 Old 12-30-2013, 07:30 AM
paroxysym
2007 WK
so with the 5100s on 3/4" and MD OME coils you only netted 22" i figured youd be closer to 23". looking forward to pics
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #156 of 345 Old 12-30-2013, 11:13 AM
Chadwi
2007 WK
I thought I would end up closer to 23" too. It looks good with the 285's and I figure it is more within the safe range for less trouble in the future. If it sags some I may install a 1/4" strut spacer. Also, I have a CRD, so your results may vary.
Chadwi is offline
post #157 of 345 Old 12-30-2013, 01:10 PM
Chadwi
2007 WK
Pics!
IMG_20131230_112930_932-1[1].jpg   IMG_20131230_112946_789-1-1[1].jpg   IMG_20131230_113012_880-1[1].jpg   IMG_20131230_113032_478-1[1].jpg   IMG_20131230_113052_873-1[1].jpg
Chadwi is offline
post #158 of 345 Old 12-30-2013, 01:14 PM
paroxysym
2007 WK
DAMN! those are 285s?
looks good dude
OEM+
post #159 of 345 Old 12-30-2013, 01:20 PM
Chadwi
2007 WK
Sure are, so far they are great!
2007 WK CRD, Bilstein 5100's set at .75" RC rear spacer, OME MD springs F/R. At 22" front 23" rear hub to fender. JBA control arms, 1.25" Spidertrax spacers, Fierce Attitude MT's, 4XGuard front skid, Full LED interior swap, 9012 low, 9011 high/driving light bulb swap. Swirl motor resistor mod, Front pinch weld mod...
Chadwi is offline
post #160 of 345 Old 12-30-2013, 01:23 PM
paroxysym
2007 WK
pinch welds modded front and rear?
OEM+
post #161 of 345 Old 12-30-2013, 01:36 PM
Chadwi
2007 WK
Front pinch weld mod. I flattened that sucker as flat as I could, sealed it and used a sheet metal screw with a fender washer to hold the liner back. In the rear I extended the bump stop 2".
Chadwi is offline
post #162 of 345 Old 01-02-2014, 06:08 PM
kdawgFL
2005 WK
Wouldn't the swaybar limit down travel?
2005 5.7L limited, 2'' BDS Lift, 255-70-17 Revo II
kdawgFL is offline
post #163 of 345 Old 01-02-2014, 07:11 PM
Chadwi
2007 WK
Correct, the sway bar does limit rear down travel. I mostly drive in the snow, not rocks. I would need to extend brake line brackets, locker wires and the rear vent hose. I will see about extending the links in the spring, when it is not 4 degrees like it is now.
Chadwi is offline
post #164 of 345 Old 01-15-2014, 10:51 AM
ecollins7
2006 WK
Right now I have the day star lift with bilstein 4600 on all four corners. I want to get rid of the daystar so after speaking with kolak, I'm looking at going with ome hd springs all the way around with the 5100 in the rear and keeping the 4600 up front. What setting should I put the 5100 at for 3 inch lift?
ecollins7 is offline
post #165 of 345 Old 01-15-2014, 10:55 AM
pancake
2005 WK
The rears aren't adjustable. They'll just give you mor travel than the 4600s which you'll need with the longer springs. However the front 5100s ARE adjustable if you want more lift than just the ome springs. If you want more lift out back than keep and/or trim your daystar spacer or purchase another one that is shorter
05 Jeep WK Laredo 4.7L QTII | K&N CAI | Flowmaster 40 | ...lift and such in planning phase...|
pancake is offline
