Bilstein 5100 series strut - JeepForum.com
 1Likes
post #1 of 350 Old 05-31-2013, 12:59 PM Thread Starter
ca07wk
2007 WK
Im not sure if this is new or not but I just ran across it
Part Number: 24-225793
Series: 5100 Series (Ride Height Adjustable)
Position: Front
Descriptor: Front Lifted Height: .75-2"
Collapsed Length (IN): 13.35
Extended Length (IN): 19.20
Provides 5.85" of travel
The factory replacment
Part Number: 24-186797
Series: 4600 Series
Position: Front
Collapsed Length: 14.57 in / 370 mm
Extended Length: 19.02 in / 483 mm
Provides 4.45" of travel
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #2 of 350 Old 05-31-2013, 03:40 PM
Kolak
Vendor
Kolak's Avatar
That is correct and it's great news! These _just_ came out a few days ago. There's also a companion 5100 series shocks for the rear.
PM me if anyone wants pricing on a set - there are plenty available right now.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #3 of 350 Old 05-31-2013, 04:23 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
That's cool! I wonder if they are based off the prototype set Russ was working on some years back? I do need new struts when I get home. Now do I get these or build some coilovers, decisions decisions!
Omelet is offline
post #4 of 350 Old 05-31-2013, 06:37 PM
sk1er18
2007 XK Commander
AWESOME!!!
These adjustable 5100 series have been VERY popular in the fullsize truck world. I was hoping they would come out with these before I pulled the trigger on the superlift. MUCH easier than cutting coils to run some extra lift!
-Matt
sk1er18 is offline
post #5 of 350 Old 05-31-2013, 09:03 PM
heathcrow
Can someone explain the ride height adjustable feature of these struts? Can these be used with stock springs to give up to 2" of lift. I apologize in advance if this seems like a dumb question.
Mine: '06 Limited 4.7 QDII | 265/70-17's on Moabs| 1.5" Spidertrax
My daughter's: '06 Laredo 3.7 stock
heathcrow is offline
post #6 of 350 Old 05-31-2013, 09:18 PM
sk1er18
2007 XK Commander
Yes, they're meant to be used with stock springs.
The lower spring perch is adjustable, 3 positions to be exact. The lift is achieved by moving the spring perch "up", decreasing the coil pocket which adds pre-load to the spring.
-Matt
sk1er18 is offline
post #7 of 350 Old 05-31-2013, 09:24 PM
heathcrow
Thank you sir.
post #8 of 350 Old 06-01-2013, 12:24 AM
Jvenrick
2007 WK
This is great I'm needing some new struts and a little extra lift in the front would be awesome!!
2007 Grand Cherokee Rocky Mountain Edition: 4.7L V8- QTII- Green
The build:
Jvenrick is offline
post #9 of 350 Old 06-01-2013, 01:04 AM
Jaashua
2005 WK
Where were these a couple of months ago.
Jaashua is offline
post #10 of 350 Old 06-01-2013, 02:39 AM
heathcrow
Finally, my procrastination pays off.
post #11 of 350 Old 06-01-2013, 03:18 AM
Sneaky2Toes
2005 WK
These sound great!!!
Sneaky2Toes is offline
post #12 of 350 Old 06-01-2013, 04:02 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
I found some more info here:
http://www.shockwarehouse.com/site/p...Grand-Cherokee
This unit can be setup to add lift in the front for up to 2-inches of leveling. This is done by relocating the spring perch. Bilstein 5100 series offroad Racing Shock.
5100's are specifically engineered for offroad and lifted vehicles.
14mm Hardened Chromed piston rod
One piece alloy rod guide & seal system
46mm piston with self-adjusting digressive valving
One piece seamless monotube shock body
Patented nitrogen chamber and floating dividing piston
360psi gas pressure
Depending on the vehicle chassis and race set-up, some modifications may be needed to adapt these to your suspension. See your offroad mechanic or lift kit manufacturer for specs.
I wonder how well these would work with my modified OME coils? Adjusted all the way down they still provide a 3/4" lift.
Does anyone know what the extended length is on the OME struts?
Omelet is offline
post #13 of 350 Old 06-01-2013, 06:39 AM
sk1er18
2007 XK Commander
When I measured it side-by-side the stock strut, the OME was 5/16 (~.3") longer fully extended.
I'm not sure exactly what reference point they use to measure the fully extended/compressed lengths, but if they use the top of the fork bracket on the strut to the seat of the strut mount, I measured right around 19-19.25" on the OME (it was hard to get an exact figure)
-Matt
sk1er18 is offline
post #14 of 350 Old 06-01-2013, 07:53 AM
paroxysym
2007 WK
Pardon my ignorance, but say you ran these stock with the perch extended to the 2" mark to provide some lift to your stock suspension - wouldnt running it like that with no coil spring or spacer supporting that 2" extension cause premature wear/possible damage?
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #15 of 350 Old 06-01-2013, 08:03 AM
sk1er18
2007 XK Commander
Premature wear to what? In terms of front end suspension components, its no different than running OME springs and better than running 2" spacers (the spacers over-extend the front end at full droop).
The only downside I see is adding preload to stock springs for the lift which will cause them to wear quicker (as with any spring). The benefit however is maintaining the stock spring rate for those who prefer a closer to stock ride quality. You could also add a 1/4" strut spacer take some pre-load off the spring... or to get a little over 2" lift.
-Matt
sk1er18 is offline
