-   WK Grand Cherokee & XK Commander Forum (http://www.jeepforum.com/forum/f67/)
-   -   Bilstein 5100 series strut (http://www.jeepforum.com/forum/f67/bilstein-5100-series-strut-1530603/)
ca07wk 05-31-2013 11:59 AM
Im not sure if this is new or not but I just ran across it
Part Number: 24-225793
Series: 5100 Series (Ride Height Adjustable)
Position: Front
Descriptor: Front Lifted Height: .75-2"
Collapsed Length (IN): 13.35
Extended Length (IN): 19.20
Provides 5.85" of travel
The factory replacment
Part Number: 24-186797
Series: 4600 Series
Position: Front
Collapsed Length: 14.57 in / 370 mm
Extended Length: 19.02 in / 483 mm
Provides 4.45" of travel
Kolak 05-31-2013 02:40 PM
That is correct and it's great news! These _just_ came out a few days ago. There's also a companion 5100 series shocks for the rear.
PM me if anyone wants pricing on a set - there are plenty available right now.
Omelet 05-31-2013 03:23 PM
That's cool! I wonder if they are based off the prototype set Russ was working on some years back? I do need new struts when I get home. Now do I get these or build some coilovers, decisions decisions!
sk1er18 05-31-2013 05:37 PM
AWESOME!!!
These adjustable 5100 series have been VERY popular in the fullsize truck world. I was hoping they would come out with these before I pulled the trigger on the superlift. MUCH easier than cutting coils to run some extra lift!
heathcrow 05-31-2013 08:03 PM
Can someone explain the ride height adjustable feature of these struts? Can these be used with stock springs to give up to 2" of lift. I apologize in advance if this seems like a dumb question.
sk1er18 05-31-2013 08:18 PM
Yes, they're meant to be used with stock springs.
The lower spring perch is adjustable, 3 positions to be exact. The lift is achieved by moving the spring perch "up", decreasing the coil pocket which adds pre-load to the spring.
heathcrow 05-31-2013 08:24 PM
Thank you sir.
Jvenrick 05-31-2013 11:24 PM
This is great I'm needing some new struts and a little extra lift in the front would be awesome!!
Jaashua 06-01-2013 12:04 AM
9 Attachment(s)
Where were these a couple of months ago. :(
heathcrow 06-01-2013 01:39 AM
Finally, my procrastination pays off.
Sneaky2Toes 06-01-2013 02:18 AM
These sound great!!!
Omelet 06-01-2013 03:02 AM
I found some more info here:
http://www.shockwarehouse.com/site/p...Grand-Cherokee
This unit can be setup to add lift in the front for up to 2-inches of leveling. This is done by relocating the spring perch. Bilstein 5100 series offroad Racing Shock.
5100's are specifically engineered for offroad and lifted vehicles.
14mm Hardened Chromed piston rod
One piece alloy rod guide & seal system
46mm piston with self-adjusting digressive valving
One piece seamless monotube shock body
Patented nitrogen chamber and floating dividing piston
360psi gas pressure
Depending on the vehicle chassis and race set-up, some modifications may be needed to adapt these to your suspension. See your offroad mechanic or lift kit manufacturer for specs.
I wonder how well these would work with my modified OME coils? Adjusted all the way down they still provide a 3/4" lift.
Does anyone know what the extended length is on the OME struts?
sk1er18 06-01-2013 05:39 AM
When I measured it side-by-side the stock strut, the OME was 5/16 (~.3") longer fully extended.
I'm not sure exactly what reference point they use to measure the fully extended/compressed lengths, but if they use the top of the fork bracket on the strut to the seat of the strut mount, I measured right around 19-19.25" on the OME (it was hard to get an exact figure)
paroxysym 06-01-2013 06:53 AM
Pardon my ignorance, but say you ran these stock with the perch extended to the 2" mark to provide some lift to your stock suspension - wouldnt running it like that with no coil spring or spacer supporting that 2" extension cause premature wear/possible damage?
sk1er18 06-01-2013 07:03 AM
Premature wear to what? In terms of front end suspension components, its no different than running OME springs and better than running 2" spacers (the spacers over-extend the front end at full droop).
The only downside I see is adding preload to stock springs for the lift which will cause them to wear quicker (as with any spring). The benefit however is maintaining the stock spring rate for those who prefer a closer to stock ride quality. You could also add a 1/4" strut spacer take some pre-load off the spring... or to get a little over 2" lift.
The time now is 03:57 AM.
