BFGoodrich All-Terrain T/A pic request - Page 2 - JeepForum.com
post #16 of 20 Old 09-11-2012, 08:24 AM
trax95008
2006 XK Commander
Originally Posted by TimBanham
are they standard fit i.e. don't affect speedo readings etc?
In the original post, he said 245/70-17. That is NOT the stock size. So yes the speedo would be effected unless re calibrated
trax95008 is offline
post #17 of 20 Old 09-11-2012, 08:39 AM
TimBanham
2006 WK
Thanks
Looking at the stock tyres and these the speedo would only be out by < 1mph at 30 so wouldn't be worth doing it - good to know as want a set of BFGs on mine when I get it best tyres I ever had on my last 4x4
2006 Black CRD 255/60/18s General Grabber ATs on Overland alloys
Black Wk Club MEMBER #146
TimBanham is offline
post #18 of 20 Old 09-11-2012, 09:48 AM
diesel88
2008 WK
Originally Posted by Mainsail
265/65-17 at stock height, however the Pintlers move the wheels outboard about an inch.
Hi I just bought a set of steel cragar soft 8s. They are 17x8 with 4 1/2 backspacing. They fit great in back but the fronts don't . The guy I bought from had them mounted on an 08 JK and I just found out the grand has beefier front calipers. I really don't want to use spacers. I'm thinking maybe trimming the brake caliper bracket or maybe a different caliper altogether. Any ideas or know of a place I could find info for my dilemma? I noticed on AZ website the JK has a single piston caliper where as my Wk has a double piston caliper. Thanks.
diesel88 is offline
post #19 of 20 Old 09-11-2012, 10:10 AM
Mainsail
2005 WK
I agonized over that decision- what fits? I emailed a guy at some custom wheel company for over a week trying to get something that would fit, but I'm no exert on offset and back spacing. In the end I went with the Pintlers because they were designed specifically for the WKs, and even though they were expen$ive, they were well worth it. That credit card bill is long forgotten but the wheels are still great.
I have heard of people shaving the calipers to make 16" wheels fit, but I don't know much about it. For me the problem (with the stockers) was the upper control arm bolt. You may run into that even if the wheel will fit over the shaved calipers.
As for the speedo, my hand is usually in the way when I'm driving and I can't see it. I use the speed read-out on the GPS since it's more accurate anyway.
When I got the M1009 it needed tires badly, and I was just about to spring for the Wrangler Authority from Wal-Mart when some BFGs came up on craigslist for less. They're not the E load range like the ones on the WK, but they're still a great and tough tire.
Poor grammar is something up with which I shall not put.
Mainsail is offline
post #20 of 20 Old 09-22-2012, 10:14 AM Thread Starter
ligcmp
2005 WK
The garage guy put 60psi with the max at 80psi anyones thoughts on what psi to run?
Black WK Club Member #23
ligcmp is offline
Nitto Mud Grappler vs. BFGoodrich KM2 94ZJ-318 ZJ Grand Cherokee Forum 7 11-09-2010 01:38 PM
Which tires? Eagle LS or BFgoodrich trac TA? TAWS600 ZJ Grand Cherokee Forum 4 10-30-2008 01:04 PM
BFG Mud Terrain vs. KM2 jopolly3 ZJ Grand Cherokee Forum 12 10-25-2008 04:55 PM
255/75/R17 BFGoodrich Mud Terrains PGCI WK Grand Cherokee & XK Commander Forum 5 03-16-2008 02:02 PM
Michelins, bfgoodrich and uniroyal afss ZJ Grand Cherokee Forum 15 12-13-2004 02:37 PM
