Better then nothing - JeepForum.com
post #1 of 24 Old 10-24-2013, 05:21 PM Thread Starter
Burnerman
Burnerman's Avatar
Better then nothing
Wife took her Jeep to the dealer today because I found the front diff bushing is shot. They said they're gonna replace the rack under warranty ( reg $1400 repair) cause that's where they say the clunk is from. The diff bushing isn't covered under the warranty. They wanted $600 to do the front diff bushing. Lol. I just ordered all three mounts online for $175. I'll have this done in 4hrs tops. All. Oem Mopar parts. They wanna put a brand new rack in for my $100 deductible, go for it! Take advantage of any warranty you guys have!!
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #2 of 24 Old 10-24-2013, 05:28 PM
Jeepforthewin
2010 JK Wrangler
Better than $1400!
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #3 of 24 Old 10-24-2013, 06:07 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
There is a great write-up in here on swapping the front diff bushings. I'm on android otherwise I'd post a link but it is also in the diy stickies IIRC.
Brand new rack plus labor for 100 bones = Bonus!
Good for you!
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #4 of 24 Old 10-24-2013, 06:36 PM
Jeepforthewin
2010 JK Wrangler
Originally Posted by JeepN4KC
There is a great write-up in here on swapping the front diff bushings. I'm on android otherwise I'd post a link but it is also in the diy stickies IIRC. Brand new rack plus labor for 100 bones = Bonus! Good for you!
I'll help ya out! http://www.jeepforum.com/forum/f67/h...ement-1299567/
post #5 of 24 Old 10-25-2013, 02:12 PM Thread Starter
Burnerman
Burnerman's Avatar
Thanks for the link. I have read that thread before. I'll be doing it on my back in the driveway and I'm hoping to have it go well. I've got all the tools, just wish I had a lift.
96 ZJ.
post #6 of 24 Old 10-25-2013, 02:30 PM
JeepN4KC
JeepN4KC's Avatar
^^^ x2
~Mike~
WK
XJ
JeepN4KC is offline
post #7 of 24 Old 10-31-2013, 08:34 AM Thread Starter
Burnerman
Burnerman's Avatar
Update: They installed a new rack and outer tie rod ends. Aligned it all for $100. Warranty is good to have. I'm gonna see how much stuff I can get them to replace before it runs out.
This weekend I attack the diff bushings and fluid change for the frt diff and tcase. Next week I'll do the rear diff fluid.
96 ZJ.
post #8 of 24 Old 10-31-2013, 09:15 AM
JeepN4KC
JeepN4KC's Avatar
^^^ good to hear.........good luck w/ the rest of the to do list!
~Mike~
WK
XJ
JeepN4KC is offline
post #9 of 24 Old 10-31-2013, 09:59 AM
90grandoneer
90grandoneer's Avatar
2006 WK
Changing the front diff. bushings is not a picnic. Hope you have an air chisel and a good assortment to tools.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, K&N Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline
post #10 of 24 Old 10-31-2013, 01:56 PM Thread Starter
Burnerman
Burnerman's Avatar
Oh yeah. Air tools, air chisel, sawzall, ball joint press and a roll around full of tools. Just wish I had a lift or a pit to work under the jeep.
96 ZJ.
post #11 of 24 Old 10-31-2013, 02:02 PM
Jeepforthewin
2010 JK Wrangler
Sounds like you got all you need for it! The lift would help but it can be done without, good luck!
post #12 of 24 Old 10-31-2013, 04:33 PM Thread Starter
Burnerman
Burnerman's Avatar
Thanks! )
96 ZJ.
post #13 of 24 Old 11-02-2013, 12:09 PM Thread Starter
Burnerman
Burnerman's Avatar
Ok. The bushings ARE a PIA. The bolt on the pinion bushing is stupid to get to. It took me about 3hrs to do it by myself but can do it faster now I know the way. Also with the OME lift the diff won't drop down enough to clear the passenger side mount. I had to jack up the a arm to get the axle angled right. It took about 5 seconds with the air chisel to remove the bushing. That was the easiest part of the job! I replaced the pinion bushing and front mount/ bushing. The passenger sir mount was perfect yet.
The second hard part was getting the stupid fill plug outta the front diff cover. I had to make a 9/16" Allen socket and use a breaker bar to get it out! Friggin kids at the dealer and their impact guns set for strip/ melt the bolts in!!!! 1 1/2hrs to change diff and transfer case fluid!!! Unreal!!!
Anyway, it's done and the clunks and creaks are gone! It's beer o'clock!!!!
96 ZJ.
post #14 of 24 Old 11-02-2013, 12:16 PM Thread Starter
Burnerman
Burnerman's Avatar
Here's the bad bushings.
96 ZJ.
post #15 of 24 Old 11-11-2013, 11:44 AM
emasta
2005 WK
Can this be done without air tools?
I also need to replace these bushings but I don't have access to air tools is it possiable to get the top bushing out without a air chisel?
emasta is offline
