Best Air Compressor for Filling tires.... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Best Air Compressor for Filling tires....
XT (ExtremeTerrain.com) has Barricade Off-Road Armor!ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail Nitro Gear Packages Now Available at Rockridge 4wd
Unread 03-28-2015, 02:50 PM   #1
KillaJeep4569
2006 WK
Hey guys whats up. Im looking for an air compressor I can stick under the hood of my WK. As I do alot of Beach driving for Surf fishing. I am wanting to get a Good Air compressor. This way I dont have to wait online at the fil up station at the beach... Some dont have these so It would be beneficial to get one..
With that said.
I want one that will take max 3 mins to fill each tire.
One that can be placed under the Hood.
Does minimum 2 CFM constant
Dont wanna spend a crazy amount of money. Max $150
I searched online found a few, But not sure which one to get. Even seraching the site, there are many different views and takes on this.. PLease let me know what you guys think.
KillaJeep4569 is offline   Reply With Quote Quick reply to this message
Unread 03-28-2015, 03:11 PM   #2
JRLT
2010 WK
Search Omelet's build thread.
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline   Reply With Quote Quick reply to this message
Unread 03-28-2015, 03:19 PM   #3
KillaJeep4569
2006 WK
seen it. but not sure I want to spend that amount on a compressor
Unread 03-28-2015, 03:27 PM   #4
TurboDiesel
2008 WK
i got a viair 88p off amazon for like $60
havent used it yet but has amazing reviews
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is online now   Reply With Quote Quick reply to this message
Unread 03-28-2015, 07:22 PM   #5
ca07wk
2007 WK
Get an onboard compressor either heavy duty ARB or Viair
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline   Reply With Quote Quick reply to this message
Unread 03-28-2015, 08:21 PM   #6
KillaJeep4569
2006 WK
For ARB I like the CKSA12 or CKMA12 ---But what is the differences between the two? And I was hearing that the CKSA is just for people who have lockers?
For Vlair I like the 275C Compressor Kit or VIAIR 100C Compressor Kit -- Just dont know much about these
Also some recommended the Superflow MV90 or MV50
Unread 03-28-2015, 08:40 PM   #7
Anticanman
The Thunder Chunky
Anticanman's Avatar
The smittybilt 2781 is about $150 and pretty potent for the price. Plus if you get it locally at a four wheel parts store, they can warranty it if it ever breaks. I hard mounted mine in my Yj and now everyone lines up at my jeep after the trail ride to get their tires filled back up rather than wait for their crappy compressors.
Luck Favours The Prepared
"Whiskey is for drinking, Water is for fighting over" - Mark Twain
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 03-29-2015, 02:17 PM   #8
ca07wk
2007 WK
MA12, CK12 is designed just for lockers. Look into the Viair 370
Unread 03-29-2015, 03:23 PM   #9
BlackPrintz
2005 WK
This is not a compressor, but does an awesome job at inflating my 32" tires from 12 lbs up to 32 lbs at about a minute per tire. I get about 6 or 7 trail runs per charge. Yes it costs money to fill the tank, but there are no mechanical parts to wear out or deal with. It's a simple and convenient system, but it will run you about $250.
Black WK #139
05 WK, 5.7 Hemi, 2" R.C. lift, 32s, K&N, MagnaFlow, 4xGuard Skids, Custom Rock Rails
BlackPrintz is offline   Reply With Quote Quick reply to this message
Unread 03-29-2015, 03:34 PM   #10
Greever
2008 WK
How do you charge it? Can it be refilled with any compressor?
2008 4.7 V8 Limited
Greever is offline   Reply With Quote Quick reply to this message
Unread 03-29-2015, 03:44 PM   #11
Bojeepus
welding shop liquid c02
I have 3 jeeps in the stable
(95 yj wrangler 2.5L 33in tires owned since 2002)
(93 xj 4.0L 2wd stock owned since 2009)
(97 zj 5.2L Orvis ed. 32in tires newest in collection)
http://www.tnjeeps.com
Bojeepus is offline   Reply With Quote Quick reply to this message
Unread 03-29-2015, 04:05 PM   #12
KillaJeep4569
2006 WK
I'm looking for a inboard compressor. nothing more nothing less. just something to go under the hood and fill up 4 tires after surf fishing. thanks.
Unread 03-29-2015, 04:22 PM   #13
ca07wk
2007 WK
Get the ARB MA12
Unread 03-29-2015, 04:23 PM   #14
KillaJeep4569
2006 WK
Originally Posted by ca07wk View Post
Get the ARB MA12
didn't u say those r for lockers only?
Unread 03-29-2015, 04:28 PM   #15
ca07wk
2007 WK
Thats the CK12, which is medium duty, the MA12 is heavy duty designed to run lockers and air up tires
