Battery Life - Page 2 - JeepForum.com
post #16 of 20 Old 08-22-2013, 06:26 PM
lafacej
Originally Posted by TonyVideo
I still have the original battery in my 08 CRD with 159,345 miles. I have thought about replacing it before winter. I may have it checked first but no issues so far.
Wow 160k on an 08! I thought I had a lot at 101k on my 05
lafacej is offline
post #17 of 20 Old 08-24-2013, 09:52 PM
GregK340
2017 WK
My '07 battery (original) died this past spring (6 years). Everything was fine then suddenly wouldn't start, wouldn't even turn over. Jumped it, all was good for 2 weeks, then suddenly wouldn't turn over again. Jumped it and went to sears for a new battery, no problems since.
GregK340 is offline
post #18 of 20 Old 08-25-2013, 08:23 AM
Xmind
2007 WK
Originally Posted by modernblueWK View Post
I volt tested mine with no load tonight. 12.65 volts. Peace of mind goes a long way with me. 6 months of below freezing temps makes me want to replace it before the snow flys.
Yeah testing with no load is not a very good indicator of your battery life. Batteries will build up a surface charge that will artificially increase the measured voltage. A better method is to turn on a high load like the high beam headlights (with the engine off) for about 30 seconds and then take a voltage reading.
'07 GC CRD QDII, EHM, GDE ECO, DPF & intake rez delete, Paramount Perf Valve Body, Roof drain mod
Xmind is offline
post #19 of 20 Old 08-25-2013, 08:43 AM
modernblueWK
I will try that.
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #20 of 20 Old 08-26-2013, 08:36 AM
NDSU_Bison
2014 WK
I just had to replace the OEM battery on my WK after 5 1/2 years and 128,000 miles. I noticed over the last couple of weeks that the starter motor wasn't turning as fast, especially after not being driven for a couple of days. Then one day it would hardly turn over so and the shop said the cold cranking amps were at about 1/2 what they should be.
NDSU_Bison is offline
