Battery Life - JeepForum.com
post #1 of 20 Old 08-17-2013, 07:01 PM Thread Starter
JackB1
2008 WK
Battery Life
For years I used 3 years as a reasonable battery life but things seemed to have changed. Car manufacturers have gotten vehicles to start almost immediately preserving battery life and many batteries now come with a 5 year warranty. My 08 3.6 WK battery has recently been load tested and tests out fine but I am considering a replacement. Our WK with original battery is not our main vehicle so does not see a lot of starts but at almost 6 years old I am considering a new one. Has anyone gone an extended period before replacing their battery? Will I have a sign from the battery when it is ready to die or will it be instant death possibly in an inconvenient location?
JackB1 is offline
post #2 of 20 Old 08-17-2013, 08:10 PM
magneticred
2008 WK
You might want to hook your battery up to a charger every month or so. Lead acid batteries last longer when they maintain full or near-full charge.
magneticred is offline
post #3 of 20 Old 08-17-2013, 08:15 PM
AirborneCav
It all depends on the cold cranking amps! I had a battery recently that appeared fine, car started and no issues. My trusted mechanic hooked it up to one if his testers and it was 'dead'. It seemed odd, but I was there and he confirmed with a new battery that the gauge was accurate. I kept that battery for a while after that until the starts got harder.
SILVER JEEP MEMBER #15
AirborneCav is offline
post #4 of 20 Old 08-17-2013, 08:39 PM
jbarrett
My factory Mopar battery lasted 7 years, or 85k miles. There is no sign of a battery about to die. It either has enough juice to start your car or it doesn't.
jbarrett is offline
post #5 of 20 Old 08-17-2013, 09:12 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
My '07 OEM battery died last summer. No signs. No nothin.
It wasn't in an inconvenient place but it was an inconvenient time. :-(
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #6 of 20 Old 08-18-2013, 02:13 PM
jaje
2007 WK
My OEM battery died at 75k miles and it was tough to diagnose as several electronic features would work sometime and now - like the auto up windows would go up but then go back down 1/2 way. It finally had a tough time cranking the engine over one morning so I looked under the hood and noted the massive corrosion on the negative terminal and then drove straight to the parts store to swap it out.
'14 WK2 EcoDiesel Limited
'13 Subaru BRZ
#74 Exocet - NASA ST3 / E0
jaje is offline
post #7 of 20 Old 08-18-2013, 04:11 PM
modernblueWK
I need to replace mine before this winter. No symptoms yet but i do not want to get stranded in the snow.
My local shop sells interstate batteries. What do you think about those?
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #8 of 20 Old 08-18-2013, 05:22 PM
chrali
2006 XK Commander
My battery made my XH go nuts, turning its own lights and heater fans on, not responding to the controls to turn them off, not letting me in with the remote fob. New battery fixed all of that several months ago. It was still on its original battery at 7 years and 48k.
Encourage alternative fuels - use all the petrol!
GDE HOT Tune
chrali is offline
post #9 of 20 Old 08-18-2013, 05:27 PM
Walt
2008 WK
My original factory battery went after 5.5 yrs and 85K miles. Tested at 63% capacity when it went.
Odd things start to happen on the WK's when the battery is going, such as weird codes, slow starts, apparent HVAC malfunctions, etc. You won't get a lot of advance warning. In my case, I saw the charging voltage going up slowly. A failing battery also taxes the alternator so don't wait too long.
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline
post #10 of 20 Old 08-20-2013, 09:34 PM
jgump
2009 WK
Mine went this spring. 3.5 years, 40K miles.
jgump is offline
post #11 of 20 Old 08-20-2013, 10:11 PM
modernblueWK
I volt tested mine with no load tonight. 12.65 volts. Peace of mind goes a long way with me. 6 months of below freezing temps makes me want to replace it before the snow flys.
SOLD 2008 WK 4.7 V8
post #12 of 20 Old 08-21-2013, 04:43 PM
R32R1
2006 WK
I started noticing my A/C fan would die down and surge as I came to a stop and the RPMs idled. I also noticed that cold starts would require two attempts or a very long single crank. I said f-it and bought an Optima yellow top battery (way overkill)...A/C is consistent and starts almost instantly when cold
R32R1 is offline
post #13 of 20 Old 08-21-2013, 06:06 PM
Walt
2008 WK
Battery voltage when stopped is only one indicator. Running, it should be 13.8-14.3V. However, the battery capacity test will give you advance warning when it's about to give up the ghost. Anything below 65% means you should be in the mode of looking for a new one.
I caught a Sears DieHard Gold (Group 94R) on sale on line, store pickup, no delivery charge. Interesting because it was exactly the same store where I had been quoted a price of $45 higher and it came from the same stock room. Stupid marketing strategy IMHO but I did enjoy saving the $45.
Walt is offline
post #14 of 20 Old 08-22-2013, 12:32 AM
modernblueWK
I will get mine load tested. I just have a hard time replacing it but based on all the members here with sudden failures and my own paranoid thoughtsi just might. Ive had zero issues with it so far. It will have been in service for 6 years in sept 2013.
SOLD 2008 WK 4.7 V8
post #15 of 20 Old 08-22-2013, 04:14 PM
TonyVideo
TonyVideo's Avatar
2008 WK
I still have the original battery in my 08 CRD with 159,345 miles. I have thought about replacing it before winter. I may have it checked first but no issues so far.
Tony
2008 GC 3.0L CRD Limited, ProVent Installed, Clear Bra, Scangauge
1999 GC 4.0L Larado
1985 Jeep Larado 4.0L Sold
TonyVideo is offline
