Barking Diesel - Page 3 - JeepForum.com
post #31 of 52 Old 01-29-2014, 07:49 PM
jediknight
2008 WK
Originally Posted by caddydaddy
Mine makes that high pitched squeal after it's shut off as well. The turbo actuator was replaced by the previous owner about 2 months ago, so I wouldn't think that means it's bad, right?
Normal.
That noise is from the egr throttle body reseting itself.
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline
post #32 of 52 Old 01-29-2014, 08:19 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
To be clear about the squealy sound. It is newly discovered. I have been having turbo actuator trouble for a little over a month getting the P0229 code. The other day, I got the barking sound and a new code PO473 which I did not fully understand. Later I discovered the squealy sound when my wife alerted me to it. She hears everything and has not mentioned it before.
My current theory is that the actuator is now stuck in a position that causes an over boost. I can see the pressure on my guage. It easily goes up past 20psi. When I get the P0299 and limp mode, the pressure never goes above 3psi.
I would really like to see a video of a GOOD actuator on a Jeep CRD that is functioning properly at idle and also gunned to about 2100rpm. It would be great if someone would post one to satisfy this curiosity. After I get mine replace I'll post one myself but it would still be nice to have a comparison.
Chirpz
2007 WK 3.0L CRD, Quadradrive II, GDE EcoTune, DPF-Delete
4xGuard Front, Rear, Belly, & Side Rails, Factory Skids
EHM MOD, Garmin Mechanic EcoHD, K&N Filter (Deleted)
Chirpz is offline
post #33 of 52 Old 01-29-2014, 09:05 PM
willyok
2008 WK
If I get mine back from the shop tomorrow (struts) I will take a video and send it to you.
will
willyok is offline
post #34 of 52 Old 01-29-2014, 09:10 PM
caddydaddy
2007 WK
Originally Posted by jediknight View Post
Normal.
That makes sense. My motorcycle makes a weird fax machine sound after it's turned off, and it's the idle stepper motor adjusting.
2007 CRD Limited w/QDII
GDE HOT Tune, Turbo Resonator Delete
2" RC lift
194,000+ miles!
caddydaddy is offline
post #35 of 52 Old 01-29-2014, 09:29 PM
jjt250
2007 WK
Yep, mine makes that noise too. I can probably get that video for you tomorrow or friday.
2007 Grand Cherokee Limited | QDII | 3.0L Diesel | S4xC Shackles Mounts | Goodyear Duratracs
Bilstein HD Front/Rear | Rusty's 1/2" Strut Spacer | Hemi XK Front/Rear Coils | HID Projectors
jjt250 is offline
post #36 of 52 Old 01-30-2014, 12:35 AM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
That would be GREAT!!
Chirpz
Chirpz is offline
post #37 of 52 Old 01-30-2014, 12:37 AM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
will
Chirpz
Chirpz is offline
post #38 of 52 Old 01-30-2014, 12:47 AM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
I did observe some things about my actuator before it went totally bad...
1. When operating "normally" (at least I think it was normal) it would move up and down smoothly as you jogged the fuel pedal.
2. When operating in limp mode due to under boost, it would jerk up and down erratically but never make a full stroke in either direction.... it was sort of spastic movement.
3. Now that it is dead.... it does not move at all, just wiggles a tiny bit and stops and is in the down position.
What I would like to see in a video of a good one is:
1. What happens when you turn on the ignition but before you engage the starter.
2. What position is it in when idling.
3. What position is it in when at 2100 rpm sitting in park.
4. What happen when you gun it a little from idle to say 3000 and then back off immediately.
Of course this is not scientific, but it may be helpful to others who are having actuator problems.
Chirpz
Chirpz is offline
post #39 of 52 Old 01-30-2014, 08:36 AM
jaje
2007 WK
I get mine back today or tomorrow (been at the dealer for over a week now) - I got the P0234 code (overboost) and brought it in after the 3rd time it went into limp mode over a couple days. It is almost race season so needed to get tranny flush done, fuel filter and oil change. The dealer did the normal diagnostic path by first testing the wiring harness to see if there's an issue, next they found the PCM had bad power likely from a short, which they then later traced to the turbo actuator and recommended replacing the turbo (which caused the voltage overload frying the PCM). I'm amazed that was possible. Anyway, I had them go forward with the repairs as I had it covered by an extended warranty. They also discovered a small leak from the rear main seal and did that was well.
Hope you find what you need. I've found out that Toyota Corollas (rental) you can only turn of the VSA button at speed below 30 mph then it can't be shut off. What a pity
'14 WK2 EcoDiesel Limited
'13 Subaru BRZ
#74 Exocet - NASA ST3 / E0
jaje is offline
post #40 of 52 Old 01-30-2014, 04:53 PM
jjt250
2007 WK
Chirpz, here's your video, hope it helps. If there's anything else you need to see/hear, let me know and I'd be happy to help.
This is the description I put in the YouTube video: Video showing the turbo actuator moving on the Mercedes OM642 3.0 Diesel engine (application: 2007 Jeep Grand Cherokee Limited WK). Goes in this order: key in ON position, start/idle, slow rev to ~2100 rpms, idle, another slow rev to ~2100 rpms, quick rev to ~3500 rpms, another quick rev to ~3500 rpms, idle, and key in OFF position.
Video: http://www.youtube.com/watch?v=AoyDs...ature=youtu.be
Edit: You might want to turn your volume down, it's a little loud.
jjt250 is offline
post #41 of 52 Old 01-30-2014, 05:13 PM
suzieque
2008 WK
thats a great position for the camera jjt250, I was wondering how I could record a video for chirpz!
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #42 of 52 Old 01-30-2014, 05:23 PM
jjt250
2007 WK
Thanks, I used my GoPro camera with the suction cup mount on the windshield and a bunch of extensions. I couldn't find a spot to put my phone without it falling.
jjt250 is offline
post #43 of 52 Old 01-30-2014, 10:49 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
Thank you SO much. You video covered all of my questions and showed me exactly what I needed to see. Now I know what to expect when my repair is complete.
I may want to use your video in my step by step repair guide if that's OK with you.
GoPro does an awesome job!! I'm impressed.
Chirpz
Chirpz is offline
post #44 of 52 Old 01-30-2014, 11:04 PM
jjt250
2007 WK
Yes of course, that's fine with me. GoPros are awesome and a lot of fun to play with. Definitely satisfied with my purchase!
jjt250 is offline
post #45 of 52 Old 02-12-2014, 06:05 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
This issue is solved. I replaced the Turbo Actuator. See my thread on Turbo Actuator Replacement Step by Step. Or look in the sticky "Technical Write ups" Thread.
Chirpz
Chirpz is offline
