Barking Diesel - Page 2 - JeepForum.com
post #16 of 52 Old 01-27-2014, 02:50 PM
jediknight
2008 WK
Originally Posted by Chirpz
I ordered my turbo actuator from XsBoost. Their phone number is listed incorrectly elsewhere on this forum. The correct number is: 330-830-4075 I got this note from them. "P.S I did notice that our phone number was wrong on the forum its 330-830-4075 not 4077"
I just hope that your vane are not stuck mate
Before installing the new actuator I thing vanes leaver should be moving freely ... If any one can second that it would be good info ?
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is online now
post #17 of 52 Old 01-27-2014, 06:27 PM
johnniebravo
2008 WK
I have been digging a little and the Hella actuators are common and people have been repairing their own boxes. From what I have seen on several forums mainly for European cars, the boxes fail at the solder joints by breaking or a dry joint. I am curious if any of you with a bad actuator will open it up and see if its a similar problem.
http://www.jaguarforum.co.uk/f26/tur...air-44572.html
This link is one if MANY!
2008 CRD GC
johnniebravo is offline
post #18 of 52 Old 01-28-2014, 12:06 AM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
I'm hoping for that too.... I'll check them out carefully.
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #19 of 52 Old 01-28-2014, 12:08 AM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
I can't take it apart. Have to send it back for a core credit.
Chirpz
Chirpz is offline
post #20 of 52 Old 01-28-2014, 01:42 PM
Chucknav
2007 WK
Good luck Chirpz. I hope this takes care of your problem. And, I hope you provide a detailed instruction guide like you did for the DPF delete pipe. So, if/when my actuator fails, I will be ready. BTW, I couldn't quite see from your video, do you have the turbo resonator delete pipe on there?
2007 WK Limited CRD QDII
2" RR Lift
255/75-17 Duratracs
GDE Eco-Tune
Chucknav is offline
post #21 of 52 Old 01-28-2014, 05:02 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
Thanks. I think my actuator completely failed today. See my next post.
No I do not have the resonator delete pipe.
Chirpz
Chirpz is offline
post #22 of 52 Old 01-28-2014, 05:20 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
I got the turbo under boost indicator again today. When I got home I made a video of my turbo actuator. Notice that it does not move hardly at all. After the motor shuts off, turn up your volume and listen to the high pitched squeal that continues for about 6 to 8 seconds.
I cleared that code before making this video. When you clear the code, you get a short period improved operation before it returns. The P0299 code is accompanied by the flashing lightening bolt on the dash and limp mode.
What are your comments on that?
https://www.youtube.com/edit?o=U&video_id=_5XoF5GSKJM
Chirpz
Chirpz is offline
post #23 of 52 Old 01-28-2014, 07:50 PM
Red_liner740
That is compressor stacking, and after oil starvation it is THE fastest way to blow up a turbocharger.
DO NOT DRIVE IT like that.
As a young kid i disconnected my Compressor Bypass Valve on my turbocharged Volvo and for a week drove around with the "pigeon" sound, mind you mine was faster and much louder as i was running 19psi.
A week of driving was all it took to shatter the compressor shaft. Mind you i had a T3/T4 ready to go and was one of the reasons i was abusing the poor little T3.
Yes Diesels can do that if the turbocharger can, and VNT turbochargers CAN, build up boost faster than a low RPM engine can ingest.
Red_liner740 is offline
post #24 of 52 Old 01-28-2014, 08:14 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
OK.... that make sense. Thanks
Chirpz
Chirpz is offline
post #25 of 52 Old 01-28-2014, 08:16 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
I would appreciate it if someone would post a close up video of a GOOD turbo actuator in use. I know what a bad one acts like, but I never paid any attention to it before.
To make this video I just placed my phone over the actuator between the engine lifting bar and the edge of the compartment....easy.
Chirpz
Chirpz is offline
post #26 of 52 Old 01-29-2014, 03:14 AM
james_2k
2003 WJ
thats lower than the jeeps which is at least 22
james_2k is offline
post #27 of 52 Old 01-29-2014, 06:53 AM
tnadanzig
tnadanzig's Avatar
2007 WK
That is compressor surge from the VGT vanes not being in the correct position. I would agree that your actuator is bad and needs to be replaced. My F250 has made that sound before I blew up my first turbo.
I can't believe what the shops charge to change out a $1500 turbo. I can go online and buy them all day long for $1500-$1600. A couple of gaskets and about 5-6 hours for your first time and you can get it swapped out.
The EHM has nothing to do with this issue. Both my Jeeps and my F250 have had the EHM for a couple years (F250 over 6 years) and no freezing problems. It has been below zero for the last couple of days and my Jeep has been sitting outside almost all winter and I don't have any problems with the EHM freezing or anything like that. I keep hearing people say it freezes, but I have yet to see any proof. Show me a setup that freezes and it will be pretty obvious why it froze, poor design. With the 1" hose you are not going to generate enough water vapor to freeze that line.
CB Engineering
CB-engineer.com
2014 WK2 EcoDiesel - CBE Parts
2008 3.0L CRD WK LTD - GDE Tune 3.07 gears
2007 3.0L CRD WK LTD - Go Fast Parts
2005 KJ CRD - GDE Tune
tnadanzig is offline
post #28 of 52 Old 01-29-2014, 10:37 AM
Radcrd
2007 WK
Good point tnadanzig!
The set-ups I witnessed that froze were all on VW TDI's and all in severe cold of -30*C (20 below F.) In one case the hose had dragged through deep snow which may likely have blocked it. My point was to beware if running them in cold climates as it may cause issues. Especially if the hose is low to ground or you blast through snowbanks.
2007 WK CRD QDII, GDE HOT tune. 275/55/18'' on Sahara's, SRT8 suspension.
2000 Jetta TDI (hers)
2006 Liberty CRD (sold)
3 VW TDI's (sold)
Radcrd is offline
post #29 of 52 Old 01-29-2014, 05:20 PM
Red_liner740
True but without a throttle body that fully cuts off the air path, the 22psi is not as severe as 19psi. On the diesel with the engine still ingesting air the flutter is nowhere near as violent as some of the pressure is dissipated through the engine
In any case, no bueno.
post #30 of 52 Old 01-29-2014, 05:32 PM
caddydaddy
2007 WK
Mine makes that high pitched squeal after it's shut off as well. The turbo actuator was replaced by the previous owner about 2 months ago, so I wouldn't think that means it's bad, right?
2007 CRD Limited w/QDII
GDE HOT Tune, Turbo Resonator Delete
2" RC lift
197,000+ miles!
caddydaddy is offline
