Barking Diesel - JeepForum.com
post #1 of 52 Old 01-25-2014, 10:17 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
Barking Diesel
Today we were out geocaching, which involves a lot of driving around with a lot of stops.
After one of the stops, when we started off, I could swear that a small dog was barking and nipping at our tires. We drove about a block and looked around... nothing in site. Started off again and there was the dog barking again. I thought for a moment that maybe a Yorkie had jumped up into the engine compartment. With no dogs in site, we did a U turn and headed off the other way. When we drove past the original spot where there were some thick bushes... the dogs we at us again.
Then I realized the the "barking" was coming from the engine and happened when the engine backed down from about 2100 RPM. We stopped, raised the hood and experimented gunning the engine. Sure enough.... it was the engine making the noise. Sounds like a small dog or a pissed off chipmunk....you decide. I made a video so you can hear the sound...but it is much louder than the video reveals.
The sound was with us all day, along with limp mode. Finally after eating out at Green Tomatoes, we headed home and suddenly, as we were driving, it was gone. Limp mode was gone too and we zoomed home with no dogs in pursuit.
At home I checked the codes recored on my Garmin Mechanic and found the P0299 that I expected but a new on P0473 was a surprise.
Click the link below to hear the barking sound.
http://www.youtube.com/watch?v=xuGKN...ature=youtu.be
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #2 of 52 Old 01-25-2014, 10:26 PM
sickchilly
2010 WK
I'm gonna bet it's something fuel pressure related. Sounds similar, but not the same as in this thread:
http://www.jeepforum.com/forum/f67/3...noise-1525872/
2010 Brilliant Black Crystal Pearl Coat Grand Cherokee S-Limited with various bits 'n pieces... broken in but not even finished!
sickchilly is offline
post #3 of 52 Old 01-26-2014, 12:09 AM
MBDiesel
2015 WK
Sounds like the turbo compressor to me. Stuck VNT vanes that freed themselves eventually maybe?
2015 WK2 Billet Silver Diesel 4x4, ORA2, ATG
1990 Mercedes-Benz 300D 2.5 Turbo - 155k
MBDiesel is offline
post #4 of 52 Old 01-26-2014, 05:04 AM
james_2k
2003 WJ
that sounds awesome,
compressor surge by the sounds of it. check this out:
i would say its definitely turbo related.
james_2k is offline
post #5 of 52 Old 01-26-2014, 08:28 AM
Drudgery1971
2007 WK
+1 on turbo related. Check the turbo intake pipe connection - I had a similar sound but only for a few seconds after I did the resistor mod and the intake seal was't seated quite right. Reseated and went away. my sound wasn't nearly that loud or distinctive though. Good luck. Exhaust pressure high code is odd. Did you clear it and is it still gone?
2007 WK Limited 3.0 CRD - Stock (Mine)
2010 XK Sport 5.7 Hemi - Stock (Wife)
Drudgery1971 is offline
post #6 of 52 Old 01-26-2014, 11:08 AM
jediknight
2008 WK
Very interesting. Never thought that diesels could do that sound. I always thought this sound could only be done with overboosted petrol engine. This is caused by a reversed wave pressure front from the compressor wheal spining to fast. Pressurised air has nowhere to go and tries to escape backward i.e. in direction to the atmosperic intake pipe. On petrol car we often see the addition of blowoff valve to relief the extra pressure when throttle is closed. Sounds cool but not cool. Probably stuck vanes in full load position (closed) and since they are closed here comes your hight exhaust back pressure...
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline
post #7 of 52 Old 01-26-2014, 02:09 PM
jaje
2007 WK
Hmm - Mine last week went into limp mode on the way home and threw a P0234 code which means urbo/Super Charger Overboost Condition - Manifold pressure reading above turbocharger over-boost limit detected during engine operation. So I brought it into the dealer to have them check it out and they said they traced it to the PCM (ECM) and said it was the likely culprit and if not the it's the turbo. I've got the highest level extended warranty which I'm thankful for and they've been a great company to work with. But I'm now a week out and waiting on results. I've not done any modifications to the CRD except doing the EHM vent to atmosphere and swirl motor resistor (as that threw a code last year and tnadanzig sent me some leftovers to fix it). The WK2 Ecodiesel is sounding really good now that mine will be out of warranty and I tow quite a bit for racing (and will do some even longer tows this year due to a new sponsorship on board).
'14 WK2 EcoDiesel Limited
'13 Subaru BRZ
#74 Exocet - NASA ST3 / E0
jaje is offline
post #8 of 52 Old 01-26-2014, 08:41 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
Drove the Jeep to church and elsewhere today and there was NO barking although on the way home I went into limp mode with under boost.
I ordered a new actuator tonight from XsBoost. http://www.xsboostturbochargers.com/
The price is now $400 with a $100 refund upon core return.
When I was at the dealer the other day, they would not sell the actuator separate and they want $4000++ for the Turbo.
Chirpz
Chirpz is offline
post #9 of 52 Old 01-27-2014, 09:53 AM
suzieque
2008 WK
I can't recall now how the VNT handles releasing the intake pressure, it does not use a BOV.
Anyway, I've been testing a method to reduce actuator temperature. That little black box gets pretty hot and I believe it's the heat that is causing the failures. I will post up a picture of my setup in case anyone else wants to try it.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #10 of 52 Old 01-27-2014, 10:41 AM
oldsmoke
2009 WK
Might pay to go to dealer
Wow that is an expensive turbocharger and probably not the problem. I have run many turbocharged diesels over the years and never blown a turbo yet. Wait a while and see if someone here comes up with an answer but I would go to the dealer with this.
Have you removed the intake hose to make sure the compressor wheel is turning good and not damaged? Not sure if these turbos have a wastegate but that can also be a source of trouble.
Diesel Ecotune-DPF, 32" tires, 2" lift. 4xGuard bib, tow hooks
oldsmoke is offline
post #11 of 52 Old 01-27-2014, 11:01 AM
Radcrd
2007 WK
Not sure if related by check your Elephant hose mod. Has the weather been below freezing? I have seen it happen numerous times here in Montreal with guys running these mods on VW TDI's, the hoses freeze up due to condensation and eventually blow out the turbo seals.
I keep saying it... IF you live in cold climate remove this mod at least for the winter months.
2007 WK CRD QDII, GDE HOT tune. 275/55/18'' on Sahara's, SRT8 suspension.
2000 Jetta TDI (hers)
2006 Liberty CRD (sold)
3 VW TDI's (sold)
Radcrd is offline
post #12 of 52 Old 01-27-2014, 11:10 AM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
Originally Posted by Radcrd View Post
Not sure if related by check your Elephant hose mod. Has the weather been below freezing? The hoses freeze up due to condensation and eventually blow out the turbo seals.
I use a 1" diameter hose for my EHM so it is not likely to freeze and we have not had any long hard freezes.... just a few overnights in the mid 20's. It would take a lot of condensation to fill and block my 1" hose.
Chirpz
Chirpz is offline
post #13 of 52 Old 01-27-2014, 11:16 AM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
I am 90% sure that the problem is the turbo actuator. You can watch it acting spasmodically when the symptoms are present. Anyway, at a cost of $300 for the actuator I am going to risk replacing it.
Going to our local dealer costs $130 for them just to scan it and give a quote. Their answer to most turbo problems is to replace the turbo and actuator for which they would charge over $7000 parts and labor. They will not replace just the actuator. PLUS, they pull the engine to do the job which is an unnecessary procedure.
Chirpz
Chirpz is offline
post #14 of 52 Old 01-27-2014, 11:18 AM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
I ordered my turbo actuator from XsBoost. Their phone number is listed incorrectly elsewhere on this forum. The correct number is: 330-830-4075
I got this note from them.
"P.S I did notice that our phone number was wrong on the forum its 330-830-4075 not 4077"
Chirpz
Chirpz is offline
post #15 of 52 Old 01-27-2014, 02:37 PM
jediknight
2008 WK
Originally Posted by suzieque
I can't recall now how the VNT handles releasing the intake pressure, it does not use a BOV. Anyway, I've been testing a method to reduce actuator temperature. That little black box gets pretty hot and I believe it's the heat that is causing the failures. I will post up a picture of my setup in case anyone else wants to try it.
Shoot
