Bank 2 Sensor 1 Location - JeepForum.com
post #1 of 21 Old 01-14-2012, 11:46 AM Thread Starter
BleedingBlue
2005 WK
Where is the bank 2 oxygen sensor 1 located? I know it is a downstream sensor and I located both directly after the cat, but I dont know which one it is? Thanks!
BleedingBlue is offline
post #2 of 21 Old 01-14-2012, 02:10 PM
84foxgt
2007 WK
pass. side is bank 2. if you are looking for sensor 1 that would be the upstream sensor, 2 is the downstream sensor.
2007 v6: Rough Country kit, Aries taillight gaurds, 2457517 Wrangler Silent Armors, LED interior lights, painted oe wheels Gunmetal, Topline 1.5" wheel spacers,SOLID rear diff cover,CREE backup lights,Hypertech Programmer
84foxgt is offline
post #3 of 21 Old 01-14-2012, 02:44 PM Thread Starter
BleedingBlue
2005 WK
The guy at auto zone said downstream so that is what I bought...dang. The code is P0152.
I had some transmission work done and they replaced one of my up-streams bc they said it was bad, I bet they used a cheap one and that is why it is throwing a code.
post #4 of 21 Old 01-14-2012, 03:02 PM Thread Starter
BleedingBlue
2005 WK
I crawled under there and to no surprise the one they changed is throwing the code. They said it was bad and a light never came on for it which I thought was interesting....
post #5 of 21 Old 01-14-2012, 04:14 PM
Walt
2008 WK
MOPAR's like OEM or NGK O2 sensors. Others (like Bosch) may throw a DTC (diagnostic trouble code). Recommend you find out what brand was installed and then return to one of the preferred manufacturers.
Codes can be read here: http://www.wkjeeps.com/trouble_codes.htm
P0152 is Bank 2, Sensor 1 (passenger's side, front sensor).
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline
post #6 of 21 Old 01-14-2012, 04:23 PM Thread Starter
BleedingBlue
2005 WK
Do they sell NGK sensors anywhere or only online?
post #7 of 21 Old 01-14-2012, 07:49 PM
84foxgt
2007 WK
you can get them from Napa.
84foxgt is offline
post #8 of 21 Old 01-14-2012, 08:14 PM Thread Starter
BleedingBlue
2005 WK
Awesome, thanks!
post #9 of 21 Old 01-15-2012, 07:51 AM Thread Starter
BleedingBlue
2005 WK
Well Napa is closed on sundays, but Advance has NTK oxygen sensors...are those any good?
post #10 of 21 Old 01-15-2012, 09:29 AM
84foxgt
2007 WK
same thing. thats who is making the ngk ones. you're welcome
84foxgt is offline
post #11 of 21 Old 01-15-2012, 10:09 AM Thread Starter
BleedingBlue
2005 WK
Thanks, went and picked one up and there is no way I can change this thing. I cant even touch the connector with the trans and exhaust pipes in the way...what a pain
post #12 of 21 Old 01-15-2012, 03:32 PM
just501
2008 WK
Anyone have a suggestion on how to get to that connector?
'08 WK Overland 5.7 HEMI QDII
'99 WJ Limited 4.7 QTII
'68 Firebird 400 4-Speed
just501 is offline
post #13 of 21 Old 01-15-2012, 03:57 PM
GrilledJeep
2005 WK
Here are some fun pictures
GrilledJeep is offline
post #14 of 21 Old 01-16-2012, 12:17 PM
zonk6719
Bank 2 Sensor 2
I can not get this either.
zonk6719 is offline
post #15 of 21 Old 01-16-2012, 09:01 PM
just501
2008 WK
Evidently when the drivetrain was assembled, they installed the transmission fill tube after the wiring. The wiring is between tube and transmission and it seems not possible to remove without either 1) removing tube or 2) cutting wires (sensor end).
just501 is offline
downstream oxygen sensor , o2 sensors
code p0138 4.0L bank 1 sensor2 is after the converter sensor? sdowney717 ZJ Grand Cherokee Forum 0 01-09-2012 02:09 PM
code p0138 bank one sensor 2 leechris ZJ Grand Cherokee Forum 3 01-13-2010 11:08 PM
Labor cost of replacing Bank 1 Sensor 1 OS jeepingtom ZJ Grand Cherokee Forum 15 01-11-2010 02:06 PM
o2 sensor Bank 1 Sensor 2, which one is it? 360limited ZJ Grand Cherokee Forum 10 01-11-2010 09:01 AM
Bank 1 Sensor 2 '01 Grd Cher o2 sensor location mgrean ZJ Grand Cherokee Forum 15 02-06-2009 01:41 PM
