Ball joint question - JeepForum.com
post #1 of 4 Old 08-27-2013, 10:08 AM Thread Starter
AIRBORNE
Ball joint question
I have a question about ball joints. I called yesterday to get price on an alignment to get my vehicle back into spec after installing the new TREs, Track bar, drag link, etc. Guy tells me that alignment is 84.99....BUT, on that model GC there are some "special" ball joints that are required sometimes to get it back into the correct tolerance. I have wiggled all the stuff under there and the ball joints seem okay to me. I have not taken it to the tire shop for the alignment yet. I am just curious if anyone else has heard of this. Sounds fishy to me.
They are a very reputable business that comes with a 4.7 out of 5 star rating. I used them for one other job. I am fairly new to this area, so I don't have a "go-to" mechanic like I do in my hometown.
2000 Grand Cherokee Limited/ Quadra Drive / 4.0L/ OME HD springs, Bilsteins, JKS trackbar, 255/75/17 BFG M/T with JK Moabs
2005 Silverado 2500 HD Duramax
United States Army (2004-present)
AIRBORNE is offline
post #2 of 4 Old 08-27-2013, 11:09 AM
caulk04
2008 WK
He's probably talking about alignment ball joints. They have an eccentric built in to the design that allows more adjustment if needed.
If you are still at stock height and the thing hasn't been wrecked, I see absolutely no reason to need them.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #3 of 4 Old 08-27-2013, 11:30 AM
tjkj2002
2002 KJ Liberty
There called adjustable ball joints.In most cases on older/higher mileage D30 front ends those inner C's are bent a little which throws off camber and caster and beside welding on new inner C's the next way to get everything back in is to install adjustable balljoints(uppers only are this way).
tjkj2002 is offline
post #4 of 4 Old 08-27-2013, 12:43 PM Thread Starter
AIRBORNE
Good info. I've never heard of that. Thanks.
I'm not at stock height. OME springs and Bilstein shocks.
AIRBORNE is offline
