Bad Vibrations - JeepForum.com
post #1 of 10 Old 09-28-2012, 08:47 PM Thread Starter
Mlove
Bad Vibrations
I have 2005 Jeep Grand Cherokee 3.7 Laredo it is the full time AWD. there is a intermittent vibration when I'm going down the road it does it at different speeds. I have checked all the wheel bearings, tire balance the rear and front drive shafts. there does not seem to be any extra play anywhere. I have read and talked to a couple people that think it is a drive shaft issue. Thanks to some bad advice I removed the front drive shaft to try and test drive without it, but being AWD it wont move. I have kicked it into neutral while it is happening and it seems to stop. I have heard that might be the torque converter but I think it could also be because of the AWD. Anyone have any suggestions? Thanks
Mlove is offline
post #2 of 10 Old 09-28-2012, 09:05 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Honestly it sounds like a tire balance or alignment issue specific to certain speeds. Does it happen at the same speeds consistently?
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #3 of 10 Old 09-28-2012, 09:10 PM
JRLT
2010 WK
The seized U-joint is usually in the rear drive shaft, not the front. Just do a search to find the related threads already started.
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
post #4 of 10 Old 09-28-2012, 09:33 PM Thread Starter
Mlove
Vibrations
It happens at all different speeds. tires still have all weights and appear to be freshly balanced. I have pulled, twisted, and turned the rear drive shaft it seems to be fine.
Mlove is offline
post #5 of 10 Old 09-28-2012, 09:54 PM
JeepN4KC
JeepN4KC's Avatar
Not sure what that means - tire balancing is a pretty minute measurement.
Have you been through any mud recently? Sometimes it can get caked behind the wheel and cause a pretty bad shimmy.
~Mike~
WK
XJ
JeepN4KC is offline
post #6 of 10 Old 09-29-2012, 10:31 PM Thread Starter
Mlove
More info
I took the jeep for a two hour ride today the vibration still comes and goes. Expect when I"m going down hill while its coasting it does not do it. the vibration changes in intensity from rapid to slow. speed makes no difference.
Mlove is offline
post #7 of 10 Old 01-07-2013, 05:40 PM
Jeepsweety
2005 WK
[FONT="Franklin Gothic Medium"]I'm having the same issue!!! It's the rear drivashaft gears! You need a new rear driveshaft!! quoted from $1200-$1300!!
*~Jeep sweety~*
Jeepsweety is offline
post #8 of 10 Old 01-08-2013, 09:18 AM
Radcrd
2007 WK
If you have MUD or SNOW packed in the wheels it will cause vibrations. Something to check.
2007 WK CRD QDII, GDE HOT tune. 275/55/18'' on Sahara's, SRT8 suspension.
2000 Jetta TDI (hers)
2006 Liberty CRD (sold)
3 VW TDI's (sold)
Radcrd is offline
post #9 of 10 Old 01-08-2013, 10:10 AM
LordEnki
2006 WK
Spend the $6 a wheel and have them all rebalanced first. Way cheaper than replacing the DS.
06 WK Limited
Bright Silver Metallic
4.7L, QDII, Class IV hitch
245/65R17 BFG Rugged Trail T/A
LordEnki is offline
post #10 of 10 Old 01-08-2013, 10:11 AM
LordEnki
2006 WK
Im pretty sure you cant jyst "eyeball" the wheel balance.
06 WK Limited
LordEnki is offline
drive shaft , torque converter , vibration , wheel bearings , wk
Vibrations after SYE 98gczj ZJ Grand Cherokee Forum 93 05-11-2012 03:33 PM
96 ZJ Vibrations at 55 plus vwilkins4 ZJ Grand Cherokee Forum 23 09-29-2011 04:03 PM
Vibrations between 60-70 mlsapio WK Grand Cherokee & XK Commander Forum 7 09-13-2011 09:42 PM
Vibrations, vibrations brianaryan ZJ Grand Cherokee Forum 8 08-04-2011 02:10 PM
Bad Vibrations ?? Claytonsguns ZJ Grand Cherokee Forum 5 03-16-2007 12:44 PM
