Axle Nut Size - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Axle Nut Size
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 10-19-2014, 06:56 PM   #1
SSF556
SSF556's Avatar
2008 WK
Axle Nut Size
Axle nut size...anyone know what size socket is needed...front and rear?
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline   Reply With Quote Quick reply to this message
Unread 10-20-2014, 07:55 AM   #2
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
36mm should do the trick
~Mike~
My Build Thread WK
My Other Build Thread XJ
'01 XJ with some stuff
Sept 2013 Cherokee of the Month
'07 WK with some other stuff
~RED WK CLUB #7~
'11 KK with mostly stock stuff
'06WK our first Jeep with stock stuff - totalled and gone
JeepN4KC is offline   Reply With Quote Quick reply to this message
Unread 10-20-2014, 02:48 PM   #3
Hendrix9
2007 WK
I had found one guy on another forum say it's a 35mm for the front, but most people just use 36mm because it fits well enough. I'm personally going to get a 35 and a 36mm so I've got both just in case. I couldn't even get a 35mm at the Sears near me. Amazon it is.
2007 CRD QDII
4XGuard Matrix, GDE Eco Tune
DPF delete, RC 2.5 lift on 265/70/17s
Hendrix9 is offline   Reply With Quote Quick reply to this message
Unread 10-21-2014, 10:27 AM   #4
imthehink
2005 WK
Any auto parts house will have those sizes for a few bucks a piece. 35mm is the correct size btw, no need to get the 36mm.
imthehink is offline   Reply With Quote Quick reply to this message
Unread 10-21-2014, 12:34 PM   #5
DeChache
2003 WJ
Looks like I used a 35mm
His 2003 Limited 4.7 QD 145K
Hers 2008 Laredo 3.7 QT1 119K
DeChache is offline   Reply With Quote Quick reply to this message
Unread 10-22-2014, 11:14 AM   #6
tom19511
2006 WK
Dont forget to torque to 100 ft lbs
Tom19511
tchristopher1@wowway.com
2006 Grand Cherokee Laredo 3.7
2007 Liberty Sport 3.7
tom19511 is offline   Reply With Quote Quick reply to this message
