Axle Lubricant - JeepForum.com
post #1 of 9 Old 09-22-2013, 10:15 AM Thread Starter
rneal55555
2006 WK
Axle Lubricant
Tried searching but wore my eyes out looking through I'm changing out the actuator in the rear differential $25 a quart. I'm going to do the frint end and transfer case while I'm unde there.
The question is he sold me the oil but no additive, I asked about it, he said I didn't need it. I was under the impression that I did any thoughts?
The guy had to have the VIN to look it up so you would think he's got it right but my gut is saying it's not.
rneal55555 is offline
post #2 of 9 Old 09-22-2013, 10:24 AM
Jeepforthewin
2010 JK Wrangler
Originally Posted by rneal55555
Tried searching but wore my eyes out looking through I'm changing out the actuator in the rear differential $25 a quart. I'm going to do the frint end and transfer case while I'm unde there. The question is he sold me the oil but no additive, I asked about it, he said I didn't need it. I was under the impression that I did any thoughts? The guy had to have the VIN to look it up so you would think he's got it right but my gut is saying it's not.
Which diff do you have?
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #3 of 9 Old 09-22-2013, 10:51 AM Thread Starter
rneal55555
2006 WK
corporate with Electronic Limited Slip
post #4 of 9 Old 09-22-2013, 11:07 AM
Walt
2008 WK
This should help: http://www.wkjeeps.com/wk_maintenance.htm#FAXLE
Need 2 qts of Mobil1 85W-140 synthetic gear oil and 1 bottle of MOPAR friction modifier (dealer-only item) per axle.
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline
post #5 of 9 Old 09-22-2013, 03:58 PM
BAH101
2008 WK
Originally Posted by Walt
This should help: http://www.wkjeeps.com/wk_maintenance.htm#FAXLE Need 2 qts of Mobil1 85W-140 synthetic gear oil and 1 bottle of MOPAR friction modifier (dealer-only item) per axle.
One of the 'few' inexpensive things from the dealer.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #6 of 9 Old 09-22-2013, 05:07 PM
marka2k
2006 WK
I use 75W140 (mobil 1 or Royal Purple) and 4oz of friction modifier/limited slip additive per axle from Autozone 140K miles and no issues, not sure where the 85W140 came from or maybe a typo?
Silver WK Club #46
06 WK Overland
04 Rubicon
2000 Grand Cherokee
2006 Commander Limited - Wife's
marka2k is offline
post #7 of 9 Old 09-22-2013, 05:55 PM
Walt
2008 WK
Originally Posted by marka2k View Post
......... not sure where the 85W140 came from or maybe a typo?
Sat on my shelf for a while and aged.........fat-fingered adjacent keys and didn't proof-read. The WK site is correct.
Mobil only makes one synthetic gear lubricant in this viscosity range. Here's the link:
http://www.mobiloil.com/USA-English/...75W-140LS.aspx I'm sure that there are other brands that are good also. I get the Mobil-1 at $14-15 per quart on sale.
I'm always mildly amused that MOPAR specifies synthetic lubricants for everything except the 5.7L HEMI lube oil, where dino oil is acceptable. My '08 HEMI came from the factory that way, so I used it as a break-in oil during the inital warranty period. After that, I switched to full synthetic.
Walt is offline
post #8 of 9 Old 09-22-2013, 10:07 PM
tjkj2002
2002 KJ Liberty
Syn gear oil is good for 3 things................
-MPG's,a whole 10th more(any to help achieve federal mpg standards)
-Causing axle seal leaks
-wasting diffs before or at around 100k if not changed very often if you tow or wheel
85w-140 dino gear oil,do both diffs for the price of 3/4 of one using syn and your diffs will love you for longer.
tjkj2002 is offline
post #9 of 9 Old 09-29-2013, 08:03 PM
Walt
2008 WK
-wasting diffs before or at around 100k if not changed very often if you tow or wheel....
...and there is a 4th one:
Maintaining the lifetime powertrain warranty. Jeep specifies synthetic gear oil for the differentials for my '08 WK with QTII. I maintain a record to show that I comply with that requirement.
Saved me when the rear driveshaft and pinion seal failed; it was all covered under the powertrain warranty because I was able to demonstrate that the maintenance requirements had been met. Repair bill would have been over $1,400.
Walt is offline
